Impossible d’installer bluepy apparemment
Merci pour votre aide
* Installation des dépendances *
***** Commande: sudo apt-get update **********
Hit:1 http://deb.debian.org/debian buster InRelease
Hit:2 http://deb.debian.org/debian-security buster/updates InRelease
Hit:3 http://deb.debian.org/debian buster-updates InRelease
Hit:4 http://archive.raspberrypi.org/debian buster InRelease
Ign:5 http://download.webmin.com/download/repository sarge InRelease
Hit:6 http://download.webmin.com/download/repository sarge Release
Reading package lists...
***** Commande: sudo apt-get install -y python3 python3-pip **********
Building dependency tree...
Reading state information...
python3 is already the newest version (3.7.3-1).
python3-pip is already the newest version (18.1-5+rpt1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
***** Commande: sudo pip3 install requests **********
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: requests in /usr/lib/python3/dist-packages (2.21.0)
***** Commande: sudo pip3 install bluepy **********
Collecting bluepy
Using cached https://files.pythonhosted.org/packages/27/91/6cfca10bee9862f93015413cf9e6a52c3081a71f1518963396a055128f8e/bluepy-1.3.0.tar.gz
Building wheels for collected packages: bluepy
Running setup.py bdist_wheel for bluepy: started
Running setup.py bdist_wheel for bluepy: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-d1nhhho4/bluepy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-dw0gsxl_ --python-tag cp37:
running bdist_wheel
running build
running build_py
Working dir is /tmp/pip-install-d1nhhho4/bluepy
execute make -C ./bluepy clean
execute make -C bluepy -j1
Failed to compile bluepy-helper. Exiting install.
Command was 'make -C bluepy -j1' in /tmp/pip-install-d1nhhho4/bluepy
Return code was 2
Output was:
b"make: Entering directory '/tmp/pip-install-d1nhhho4/bluepy/bluepy'
tar xzf bluez-src.tgz
touch ./bluez-5.47/lib/bluetooth.c ./bluez-5.47/lib/hci.c ./bluez-5.47/lib/sdp.c ./bluez-5.47/lib/uuid.c ./bluez-5.47/attrib/att.c ./bluez-5.47/attrib/gatt.c ./bluez-5.47/attrib/gattrib.c ./bluez-5.47/attrib/utils.c ./bluez-5.47/btio/btio.c ./bluez-5.47/src/log.c ./bluez-5.47/src/shared/mgmt.c ./bluez-5.47/src/shared/crypto.c ./bluez-5.47/src/shared/att.c ./bluez-5.47/src/shared/queue.c ./bluez-5.47/src/shared/util.c ./bluez-5.47/src/shared/io-glib.c ./bluez-5.47/src/shared/timeout-glib.c
Package glib-2.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing `glib-2.0.pc'
to the PKG_CONFIG_PATH environment variable
No package 'glib-2.0' found
cc -L. -g -Wall -Os -DHAVE_CONFIG_H -I./bluez-5.47/attrib -I./bluez-5.47 -I./bluez-5.47/lib -I./bluez-5.47/src -I./bluez-5.47/gdbus -I./bluez-5.47/btio -I./bluez-5.47/sys -o bluepy-helper bluepy-helper.c ./bluez-5.47/lib/bluetooth.c ./bluez-5.47/lib/hci.c ./bluez-5.47/lib/sdp.c ./bluez-5.47/lib/uuid.c ./bluez-5.47/attrib/att.c ./bluez-5.47/attrib/gatt.c ./bluez-5.47/attrib/gattrib.c ./bluez-5.47/attrib/utils.c ./bluez-5.47/btio/btio.c ./bluez-5.47/src/log.c ./bluez-5.47/src/shared/mgmt.c ./bluez-5.47/src/shared/crypto.c ./bluez-5.47/src/shared/att.c ./bluez-5.47/src/shared/queue.c ./bluez-5.47/src/shared/util.c ./bluez-5.47/src/shared/io-glib.c ./bluez-5.47/src/shared/timeout-glib.c
bluepy-helper.c:33:10: fatal error: glib.h: No such file or directory
#include <glib.h>
compilation terminated.
./bluez-5.47/attrib/att.c:33:10: fatal error: glib.h: No such file or directory
#include <glib.h>
./bluez-5.47/attrib/gatt.c:32:10: fatal error: glib.h: No such file or directory
#include <glib.h>
./bluez-5.47/attrib/gattrib.c:34:10: fatal error: glib.h: No such file or directory
#include <glib.h>
./bluez-5.47/attrib/utils.c:30:10: fatal error: glib.h: No such file or directory
#include <glib.h>
./bluez-5.47/btio/btio.c:37:10: fatal error: glib.h: No such file or directory
#include <glib.h>
./bluez-5.47/src/log.c:38:10: fatal error: glib.h: No such file or directory
#include <glib.h>
./bluez-5.47/src/shared/io-glib.c:30:10: fatal error: glib.h: No such file or directory
#include <glib.h>
./bluez-5.47/src/shared/timeout-glib.c:22:10: fatal error: glib.h: No such file or directory
#include <glib.h>
make: *** [Makefile:30: bluepy-helper] Error 1
make: Leaving directory '/tmp/pip-install-d1nhhho4/bluepy/bluepy'
Failed building wheel for bluepy
Running setup.py clean for bluepy
Failed to build bluepy
Installing collected packages: bluepy
Running setup.py install for bluepy: started
Running setup.py install for bluepy: finished with status 'error'
');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-alotlshm/install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
Return code was 2
Output was:
#include <glib.h>
#include <glib.h>
#include <glib.h>
#include <glib.h>
#include <glib.h>
#include <glib.h>
#include <glib.h>
#include <glib.h>
#include <glib.h>
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-d1nhhho4/bluepy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-alotlshm/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-install-d1nhhho4/bluepy/
* Installation terminée *
