Bonjour, j’ai remarqué ceci dans les logs de maillistener ?
Est ce normal ?
(node:1610248) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification.
(Use `nodejs --trace-warnings ...` to show where the warning was created)
imapConnected
(node:1611773) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification.
imapConnected
(node:1613511) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification.
imapConnected
contact Jeedom avec retour : 200
