Depuis 12h20, j’ai le message "API_Erreur (code 400) at /token : invalid_client » qui est apparu dans la log. Je n’ai rien changé sur mes identifiants. J’ai refait le « reconnect netatmo » qui a été accepté (Liaison ok), mais la synchro échoue avec le même type de message.
[2023-08-06 12:10:04][INFO] : syncMeteoCmds Updating (Station Netatmo) data: {"_id":"70:ee:50:53:5a:3a","station_name":"DMJ Netatmo C","date_setup":1578924453,"last_setup":1578924453,"type":"NAMain","last_status_store":1691316346,"module_name":"Station Netatmo","firmware":201,"wifi_status":33,"user_owner":["50afa5fa187759bceb000b40"],"reachable":true,"alarm_config":{"default_alarm":[{"db_alarm_number":0},{"db_alarm_number":1},{"db_alarm_number":2},{"db_alarm_number":6},{"db_alarm_number":4,"desactivated":true},{"db_alarm_number":5},{"db_alarm_number":7}],"personnalized":[]},"co2_calibrating":false,"hardware_version":241,"customer_id":"C00011","data_type":["Temperature","CO2","Humidity","Noise","Pressure"],"place":{"altitude":3,"city":"Criel-sur-Mer","street":"D 222","country":"FR","timezone":"Europe\/Paris","location":[1.3146885366518575,50.0332704968653]},"public_ext_data":true,"air_quality_available":true,"access_code":"jbrpHwrpM7ZK","home_id":"5ed5166de790397835e9e766","home_name":"Appartement","name":"Station Netatmo","config":{"favorite":false,"parent_home":"5ed5166de790397835e9e766","parentName":"Appartement","naCat":"weather","cmdsType":["NAMain"],"roomType":"Station"},"time_utc":1691316343,"temperature":20.3,"co2":684,"humidity":64,"noise":38,"pressure":1017,"absolutepressure":1016.7,"min_temp":20.3,"max_temp":20.8,"date_max_temp":1691273097,"date_min_temp":1691310596,"temp_trend":"stable","pressure_trend":"up","eqmodules":"[{\"_id\":\"03:00:00:08:dc:98\",\"type\":\"NAModule4\",\"module_name\":\"Netatmo Chambre\",\"last_setup\":1601820973,\"data_type\":[\"Temperature\",\"CO2\",\"Humidity\"],\"pluvio_scale_auget_to_mm\":0.101,\"battery_percent\":54,\"battery_level\":\"medium\",\"reachable\":true,\"firmware\":53,\"last_message\":1691316343,\"last_seen\":1691316318,\"rf_status\":68,\"battery_vp\":5175,\"dashboard_data\":{\"time_utc\":1691316318,\"Temperature\":19.7,\"CO2\":393,\"Humidity\":68,\"min_temp\":19.7,\"max_temp\":20.1,\"date_max_temp\":1691273096,\"date_min_temp\":1691312062,\"temp_trend\":\"stable\"}},{\"_id\":\"02:00:00:70:1e:e0\",\"type\":\"NAModule1\",\"module_name\":\"Netatmo Jardinet\",\"last_setup\":1651744306,\"data_type\":[\"Temperature\",\"Humidity\"],\"pluvio_scale_auget_to_mm\":0.101,\"battery_percent\":67,\"battery_level\":\"high\",\"reachable\":true,\"firmware\":53,\"last_message\":1691316343,\"last_seen\":1691316318,\"rf_status\":64,\"battery_vp\":5404,\"dashboard_data\":{\"time_utc\":1691316318,\"Temperature\":16.3,\"Humidity\":77,\"min_temp\":14.8,\"max_temp\":16.7,\"date_max_temp\":1691273096,\"date_min_temp\":1691282120,\"temp_trend\":\"up\"}}]","modules":{"03:00:00:08:dc:98":"NAModule4","02:00:00:70:1e:e0":"NAModule1"}}
[2023-08-06 12:10:04][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 03:49:24 pour : Anémomètre
[2023-08-06 12:10:04][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 00:00:31 pour : Bureau
[2023-08-06 12:10:04][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 01:50:43 pour : Chambre
[2023-08-06 12:10:04][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 00:00:31 pour : Cuisine
[2023-08-06 12:10:04][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 00:04:56 pour : Netatmo Chambre
[2023-08-06 12:10:04][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 00:00:44 pour : Salon
[2023-08-06 12:10:04][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 00:04:57 pour : Station Netatmo
[2023-08-06 12:20:03][ERROR] : cronJob Erreur _Homefacility API_Erreur (code 400) at /token : invalid_client
[2023-08-06 12:20:04][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 03:49:24 pour : Anémomètre
[2023-08-06 12:20:04][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 00:00:31 pour : Bureau
[2023-08-06 12:20:04][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 01:50:43 pour : Chambre
[2023-08-06 12:20:04][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 00:00:31 pour : Cuisine
[2023-08-06 12:20:04][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 00:04:56 pour : Netatmo Chambre
[2023-08-06 12:20:04][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 00:00:44 pour : Salon
[2023-08-06 12:20:04][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 00:04:57 pour : Station Netatmo
[2023-08-06 12:30:04][ERROR] : cronJob Erreur _Homefacility API_Erreur (code 400) at /token : invalid_client
[2023-08-06 12:30:04][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 03:49:24 pour : Anémomètre
[2023-08-06 12:30:04][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 00:00:31 pour : Bureau
[2023-08-06 12:30:04][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 01:50:43 pour : Chambre
[2023-08-06 12:30:04][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 00:00:31 pour : Cuisine
[2023-08-06 12:30:04][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 00:04:56 pour : Netatmo Chambre
[2023-08-06 12:30:04][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 00:00:44 pour : Salon
[2023-08-06 12:30:04][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 00:04:57 pour : Station Netatmo
[2023-08-06 12:40:04][ERROR] : cronJob Erreur _Homefacility API_Erreur (code 400) at /token : invalid_client
[2023-08-06 12:40:04][WARNING] : |cronJob Attention plus de 3 d'echecs successifs
[2023-08-06 12:40:04][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 03:49:24 pour : Anémomètre
[2023-08-06 12:50:03][ERROR] : cronJob Erreur _Homefacility API_Erreur (code 400) at /token : invalid_client
[2023-08-06 12:50:03][WARNING] : |cronJob Attention plus de 3 d'echecs successifs
[2023-08-06 12:50:03][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 03:49:24 pour : Anémomètre
[2023-08-06 12:58:03][WARNING] : ******getDataMeteo API_Erreur (code 400) at /token : invalid_client
[2023-08-06 13:00:05][ERROR] : cronJob Erreur _Homefacility API_Erreur (code 400) at /token : invalid_client
[2023-08-06 13:00:05][WARNING] : |cronJob Attention plus de 3 d'echecs successifs
[2023-08-06 13:00:05][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 03:49:24 pour : Anémomètre
[2023-08-06 13:00:05][WARNING] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 11:59:35 pour : Jardin
[2023-08-06 13:02:31][WARNING] : na.code::params: {"client_id":"63e8dae2d86b020c8d0fa970","scope":"read_thermostat write_thermostat read_smarther write_smarther read_station read_clim write_clim","state":"e9341315d8d0826c02690bfe2396308c","redirect_uri":"http:\/\/192.168.1.62\/plugins\/naEnergie\/core\/whook\/na.code.php?apikey=FiPBaK3SAccmM6JKb2XH6dNxDuUEN8mnhbGVjQPkIb9X8t89TnwIktuaZId0VpSV"}
[2023-08-06 13:02:31][WARNING] : na.code::received code: 6dbdf99bec6f926898b7d921d28a3d55
[2023-08-06 13:02:49][WARNING] : getClient Erreur d'authentification : API_Erreur (code 400) at /token : invalid_client
[2023-08-06 13:03:15][WARNING] : na.code::params: {"client_id":"63e8dae2d86b020c8d0fa970","scope":"read_thermostat write_thermostat read_smarther write_smarther read_station read_clim write_clim","state":"ad30c98b2d7881d2347ddbe56c4f8bc4","redirect_uri":"http:\/\/192.168.1.62\/plugins\/naEnergie\/core\/whook\/na.code.php?apikey=FiPBaK3SAccmM6JKb2XH6dNxDuUEN8mnhbGVjQPkIb9X8t89TnwIktuaZId0VpSV"}
[2023-08-06 13:03:15][WARNING] : na.code::received code: a656a8b723874e12b6579b5ec32a1664
[2023-08-06 13:06:47][WARNING] : getClient Erreur d'authentification : API_Erreur (code 400) at /token : invalid_client
[2023-08-06 13:10:03][ERROR] : cronJob Erreur _Homefacility API_Erreur (code 400) at /token : invalid_client
[2023-08-06 13:10:03][WARNING] : |cronJob Attention plus de 3 d'echecs successifs
[2023-08-06 13:10:03][ERROR] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 03:49:24 pour : Anémomètre
[2023-08-06 13:10:03][WARNING] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 11:59:35 pour : Jardin
[2023-08-06 13:10:03][WARNING] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 12:05:18 pour : Netatmo Jardinet
[2023-08-06 13:10:03][WARNING] : | ⚠️cronJob Attention Aucune communication détectée depuis: 2023-08-06 12:00:14 pour : Pluviomètre
