Netatmo Incoming_push wrong apikey
Depuis 2 jours j’ai ce message d’erreur dans mes logs. (j’ai attendu que le crondaily comme indiqué dans Erreur syncFromWeb Erreur 503 - #10 par doudou-z ). Mes thermostats marchent normalement.
J’ai vérifier la connexion via
Une idée ?
Merci de votre aide
Log du plug-in
4931|[2026-11-02 15:20:26] ERROR  cronJob  Erreur _Homefacility HTTP 500 (Internal Server Error) error at homesdata - Oauth2 server error | api_code=11(Internal error)
4932|[2026-11-02 15:30:27] ERROR  cronJob  Erreur _Homefacility HTTP 500 (Internal Server Error) error at homesdata - Oauth2 server error | api_code=11(Internal error)
4933|[2026-11-02 16:21:06] ERROR  cronJob  Erreur _Homefacility HTTP 500 (Internal Server Error) error at homesdata - Request to the backend service timed out | api_code=11(Internal error)
4934|[2026-11-02 16:30:35] ERROR  cronJob  Erreur _Homefacility HTTP 502 (Bad Gateway) error at homesdata - <html>
4935|<head><title>502 Bad Gateway</title></head>
4936|<body>
4937|<center><h1>502 Bad Gateway</h1></center>
4938|<hr><center>nginx/1.30.2</center>
4939|</body>
4940|</html>
4941|[2026-11-02 16:41:06] ERROR  cronJob  Erreur _Homefacility HTTP 500 (Internal Server Error) error at homesdata - Request to the backend service timed out | api_code=11(Internal error)
4942|[2026-11-02 16:50:08] ERROR  cronJob  Erreur _Homefacility HTTP 503 (Service Unavailable) error at homesdata - upstream connect error or disconnect/reset before headers. retried and the latest reset reason: connection timeout
4943|[2026-11-02 17:00:29] ERROR  cronJob  Erreur _Homefacility HTTP 502 (Bad Gateway) error at homesdata - <html>
4944|<head><title>502 Bad Gateway</title></head>
4945|<body>
4946|<center><h1>502 Bad Gateway</h1></center>
4947|<hr><center>nginx/1.30.2</center>
4948|</body>
4949|</html>
4950|[2026-11-02 17:10:48] ERROR  cronJob  Erreur _Homefacility HTTP 502 (Bad Gateway) error at homesdata - <html>
4951|<head><title>502 Bad Gateway</title></head>
4952|<body>
4953|<center><h1>502 Bad Gateway</h1></center>
4954|<hr><center>nginx/1.30.2</center>
4955|</body>
4956|</html>
4957|[2026-11-02 22:00:27] ERROR  cronJob  Erreur _Homefacility HTTP 500 (Internal Server Error) error at homesdata - Oauth2 server error | api_code=11(Internal error)
4958|[2026-11-03 15:30:27] ERROR  cronJob  Erreur _Homefacility HTTP 500 (Internal Server Error) error at homesdata - Oauth2 server error | api_code=11(Internal error)
4959|[2026-11-05 12:09:49] ERROR  incoming_push wrong apikey
4960|[2026-11-05 12:26:15] ERROR  incoming_push wrong apikey
4961|[2026-11-05 12:44:32] ERROR  incoming_push wrong apikey
4962|[2026-11-05 12:59:36] ERROR  incoming_push wrong apikey
4963|[2026-11-05 13:18:36] ERROR  incoming_push wrong apikey
4964|[2026-11-05 13:39:01] ERROR  incoming_push wrong apikey
4965|[2026-11-05 13:57:20] ERROR  incoming_push wrong apikey
4966|[2026-11-05 14:20:18] ERROR  incoming_push wrong apikey
4967|[2026-11-05 14:36:27] ERROR  incoming_push wrong apikey
4968|[2026-11-05 14:52:35] ERROR  incoming_push wrong apikey
4969|[2026-11-05 15:10:52] ERROR  incoming_push wrong apikey
4970|[2026-11-05 15:28:31] ERROR  incoming_push wrong apikey
4971|[2026-11-05 15:45:18] ERROR  incoming_push wrong apikey
4972|[2026-11-05 16:01:26] ERROR  incoming_push wrong apikey
4973|[2026-11-05 16:18:40] ERROR  incoming_push wrong apikey
4974|[2026-11-05 16:44:28] ERROR  incoming_push wrong apikey
4975|[2026-11-05 17:00:11] ERROR  incoming_push wrong apikey
4976|[2026-11-05 17:15:56] ERROR  incoming_push wrong apikey
4977|[2026-11-05 17:31:23] ERROR  incoming_push wrong apikey
4978|[2026-11-05 17:49:19] ERROR  incoming_push wrong apikey
4979|[2026-11-05 18:17:16] ERROR  incoming_push wrong apikey
4980|[2026-11-05 18:42:49] ERROR  incoming_push wrong apikey
4981|[2026-11-05 19:20:28] ERROR  incoming_push wrong apikey
4982|[2026-11-05 19:37:58] ERROR  incoming_push wrong apikey
4983|[2026-11-05 19:54:27] ERROR  incoming_push wrong apikey
4984|[2026-11-05 20:17:47] ERROR  incoming_push wrong apikey
4985|[2026-11-05 20:41:48] ERROR  incoming_push wrong apikey
4986|[2026-11-05 21:11:12] ERROR  incoming_push wrong apikey
4987|[2026-11-05 21:11:12] ERROR  incoming_push wrong apikey
4988|[2026-11-05 21:30:39] ERROR  incoming_push wrong apikey
4989|[2026-11-05 21:53:32] ERROR  incoming_push wrong apikey
4990|[2026-11-05 22:17:32] ERROR  incoming_push wrong apikey
4991|[2026-11-05 23:00:14] ERROR  incoming_push wrong apikey
4992|[2026-11-05 23:17:46] ERROR  incoming_push wrong apikey
4993|[2026-11-05 23:54:50] ERROR  incoming_push wrong apikey
4994|[2026-11-06 00:40:01] ERROR  incoming_push wrong apikey
4995|[2026-11-06 00:59:40] ERROR  incoming_push wrong apikey
4996|[2026-11-06 01:34:53] ERROR  incoming_push wrong apikey
4997|[2026-11-06 01:51:19] ERROR  incoming_push wrong apikey
4998|[2026-11-06 02:22:13] ERROR  incoming_push wrong apikey
4999|[2026-11-06 02:48:19] ERROR  incoming_push wrong apikey
5000|[2026-11-06 03:18:44] ERROR  incoming_push wrong apikey
5001|[2026-11-06 03:48:35] ERROR  incoming_push wrong apikey
5002|[2026-11-06 04:09:17] ERROR  incoming_push wrong apikey
5003|[2026-11-06 04:42:23] ERROR  incoming_push wrong apikey
5004|[2026-11-06 05:06:19] ERROR  incoming_push wrong apikey
5005|[2026-11-06 05:25:08] ERROR  incoming_push wrong apikey
5006|[2026-11-06 05:51:14] ERROR  incoming_push wrong apikey
5007|[2026-11-06 06:08:42] ERROR  incoming_push wrong apikey
5008|[2026-11-06 06:26:26] ERROR  incoming_push wrong apikey
5009|[2026-11-06 06:45:01] ERROR  incoming_push wrong apikey
5010|[2026-11-06 07:00:53] ERROR  incoming_push wrong apikey
5011|[2026-11-06 07:21:36] ERROR  incoming_push wrong apikey
5012|[2026-11-06 07:45:32] ERROR  incoming_push wrong apikey
5013|[2026-11-06 08:11:06] ERROR  incoming_push wrong apikey
5014|[2026-11-06 08:41:27] ERROR  incoming_push wrong apikey
5015|[2026-11-06 08:58:15] ERROR  incoming_push wrong apikey
5016|[2026-11-06 09:17:32] ERROR  incoming_push wrong apikey
5017|[2026-11-06 09:36:21] ERROR  incoming_push wrong apikey
5018|[2026-11-06 10:16:27] ERROR  incoming_push wrong apikey
5019|[2026-11-06 10:37:38] ERROR  incoming_push wrong apikey
5020|[2026-11-06 10:37:38] ERROR  incoming_push wrong apikey
5021|[2026-11-06 11:40:03] ERROR  incoming_push wrong apikey
5022|[2026-11-06 11:55:25] ERROR  incoming_push wrong apikey
5023|[2026-11-06 12:13:43] ERROR  incoming_push wrong apikey
Informations Jeedom
Core : 4.6.2 (master)
DNS Jeedom : non
Plugin : Netatmo Energie
Version : 2026-11-02 01:29:12 (stable)
Santé
🟢 Matériel : RPI 5
🟢 Système à jour : OK
🟢 Cron actif : OK
🟢 Scénario actif : OK
🟢 Démarré : OK 2026-10-27 13:16:02
🟢 Date système (dernière heure enregistrée) : OK 2026-11-06 13:03:26 (2026-11-06 12:20:02)
🟢 Droits sudo : OK
🟢 Version Jeedom : 4.6.2
🟢 Version OS : debian 12.15
🟢 Version PHP : 8.2.35
🟢 Nombre de processus Apache : 14
🟢 Version OS : Linux JeedomPI5 6.12.96+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.96-1+rpt1 (2026-07-24) aarch64 GNU/Linux  [12.15]
🟢 Version database : 10.11.19-MariaDB-0+deb12u1
🟢 Espace disque libre : 87 %
🟢 Connexion active/max/autorisée : 14/64/151
🟢 Taille base de données : 316.02 MB
🟢 Espace disque libre tmp : 54 %
🟢 Mémoire disponible : 77 % (Total 8063 Mo)
🟢 Mémoire suffisante : 0
🟢 Erreur I/O : 0
🟢 Swap disponible : 100 % (Total 512 Mo)
🟢 Swappiness : 10 %
🟢 Charge : 0.23 - 0.32 - 0.36
🟢 Node : v22.23.2
🟢 Python : Python 3.11.2
🟢 Python 3 : Python 3.11.2
🟢 Persistance du cache : OK
🟢 Apache private tmp : OK
Tu as fait une mise à jour ?
Ça devrait se régler à la prochaine MAJ
Edit: c’est un bug Netatmo qui n’envoie plus la clé API du plugin, du coup les pushs sont refusés et pas traités par le plugin. Je regarde si c’est temporaire ou dû aux évolutions des webhooks.
J’ai fait la mise à jour du plug-in il y a qq jours quand la version s’est présentée.
Ok, si une nouvelle mise à jour arrive, j’attends, c’est fonctionnel à par ces messages
tu as testé la dernière MAJ ?
Je viens de l’installer, je te fais un retour d’ici un ou deux jours.
