Merci, voici un peu de matière pour vous aider :
La page santé :
La santé du plugin RFXCOM :
pour info le RFXCOM communique bien avec mon poêle lorsqu’il est connecté au pc.
Le log en mode debug suite à la tentative d’installation des dépendances :
+ touch /tmp/jeedom_install_in_progress_rfxcom
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../plugins/rfxcom/resources/pre-install.sh
+ sudo /var/www/html/core/class/../../plugins/rfxcom/resources/pre-install.sh
Launch pre-install of rfxcom dependancy
File "/usr/bin/pip3", line 33, in <module>
sys.exit(load_entry_point('pip==20.3.4', 'console_scripts', 'pip3')())
File "/usr/bin/pip3", line 25, in importlib_load_entry_point
return next(matches).load()
File "/usr/lib/python3.9/importlib/metadata.py", line 77, in load
module = import_module(match.group('module'))
File "/usr/lib/python3.9/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 790, in exec_module
File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
File "/usr/lib/python3/dist-packages/pip/_internal/cli/main.py", line 10, in <module>
from pip._internal.cli.autocompletion import autocomplete
File "/usr/lib/python3/dist-packages/pip/_internal/cli/autocompletion.py", line 9, in <module>
from pip._internal.cli.main_parser import create_main_parser
File "/usr/lib/python3/dist-packages/pip/_internal/cli/main_parser.py", line 7, in <module>
from pip._internal.cli import cmdoptions
File "/usr/lib/python3/dist-packages/pip/_internal/cli/cmdoptions.py", line 23, in <module>
from pip._vendor.packaging.utils import canonicalize_name
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 94, in <module>
vendored("requests.packages.urllib3.contrib.pyopenssl")
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
__import__(modulename, globals(), locals(), level=0)
File "<frozen importlib._bootstrap>", line 664, in _load_unlocked
File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible
File "<frozen zipimport>", line 259, in load_module
File "/usr/share/python-wheels/urllib3-1.26.5-py2.py3-none-any.whl/urllib3/contrib/pyopenssl.py", line 50, in <module>
File "/usr/lib/python3/dist-packages/OpenSSL/__init__.py", line 8, in <module>
from OpenSSL import crypto, SSL
File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 1556, in <module>
class X509StoreFlags(object):
File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 1577, in X509StoreFlags
CB_ISSUER_CHECK = _lib.X509_V_FLAG_CB_ISSUER_CHECK
AttributeError: module 'lib' has no attribute 'X509_V_FLAG_CB_ISSUER_CHECK'
Lecture des listes de paquets…
Construction de l'arbre des dépendances…
Lecture des informations d'état…
Le paquet « python3-serial » n'est pas installé, et ne peut donc être supprimé
0 mis à jour, 0 nouvellement installés, 0 à enlever et 0 non mis à jour.
+ echo 3
++ awk '$1 <= 4'
++ find /usr/local/lib/python2.7/dist-packages/ /usr/local/lib/python3.9/dist-packages/ -mindepth 1 -maxdepth 1 -type d -exec du -ks '{}' +
++ cut -f 2-
+ RESULTTODELETE=
++ echo ''
++ sed 's, ,\ ,g'
+ RESULTTODELETE2=
+ echo ''
+ xargs rm -rf
+ echo 4
+ sudo pip3 cache purge
+ echo 5
+ sudo pip3 install --upgrade pip
+ echo 6
+ sudo pip3 install --force-reinstall --upgrade six
+ echo 7
+ sudo pip3 install --force-reinstall --upgrade requests
+ echo 8
+ sudo pip3 install --force-reinstall --upgrade setuptools
+ echo 9
+ sudo pip3 install --force-reinstall --upgrade pyudev
+ echo 10
+ sudo pip3 install --force-reinstall --upgrade pyserial
+ echo 11
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end rfxcom
+ rm /tmp/jeedom_install_in_progress_rfxcom
Si besoin d’autres info je peux fournir, avec plaisir
