Depuis la MAJ Débian 11, mon plugin EUFY ne fonctionne plus. Ci-dessous les LOG lorsque je veux installer le DOCKER.
[2025-03-02 18:47:28] INFO : >>> Début de l'opération install du service Eufy
[2025-03-02 18:47:28] DEBUG : images installées:
[2025-03-02 18:47:28] DEBUG : container actif:
[2025-03-02 18:47:28] DEBUG : hardware arch: aarch64
[2025-03-02 18:47:28] DEBUG : DOCKER_DEFAULT_PLATFORM=linux/arm64 docker pull bropat/eufy-security-ws:latest
sudo: docker: command not found
[2025-03-02 18:47:28] INFO : >>> Fin de l'opération install du service Eufy
[2025-03-02 18:47:28] INFO : >>> Début de l'opération start du service Eufy
[2025-03-02 18:47:28]WARNING : >>> start du service Eufy: L'image n'est pas installée`
`eufy.ajax.php Installation de docker, merci de patienter eufy.ajax.php
Hit:1 http://deb.debian.org/debian bullseye InRelease
Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
Reading package lists...
Building dependency tree...
Reading state information...
ca-certificates is already the newest version (20210119).
curl is already the newest version (7.74.0-1.3+deb11u14).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Package docker-ce is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
Package docker-ce-cli is not available, but is referred to by another package.
E: Package 'docker-ce' has no installation candidate
E: Package 'docker-ce-cli' has no installation candidate
E: Unable to locate package containerd.io
E: Couldn't find any package by glob 'containerd.io'
E: Couldn't find any package by regex 'containerd.io'
E: Unable to locate package docker-compose-plugin
eufy.ajax.php Installation de docker terminée eufy.ajax.php
