Depuis ce matin, plus précisément à 2 heures au passage à l’heure d’été, mysensors a cessé de fonctionner…
Impossible de relancer le démon
A noter que mon jeedom n’a subit aucune mise à jour et aucun ajout de plugin depuis quelques mois.
Sun Mar 27 2022 09:50:08 GMT+0200 (Central European Summer Time) - Jeedom url : http://127.0.0.1:80/plugins/mySensors/core/api/jeeSensors.php?apikey=XXXXXXX&gateway=master, gwAddress : /dev/ttyUSB1
Connection type serial
/var/www/html/plugins/mySensors/resources/node_modules/bindings/bindings.js:121
throw e;
Error: The module '/var/www/html/plugins/mySensors/resources/node_modules/@serialport/bindings/build/Release/bindings.node'
was compiled against a different Node.js version using
NODE_MODULE_VERSION 72. This version of Node.js requires
NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
the module (for instance, using `npm rebuild` or `npm install`).
at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
at Module.load (internal/modules/cjs/loader.js:950:32)
at Function.Module._load (internal/modules/cjs/loader.js:790:12)
at Module.require (internal/modules/cjs/loader.js:974:19)
at require (internal/modules/cjs/helpers.js:93:18)
at bindings (/var/www/html/plugins/mySensors/resources/node_modules/bindings/bindings.js:112:48)
at Object.<anonymous> (/var/www/html/plugins/mySensors/resources/node_modules/@serialport/bindings/lib/linux.js:2:36)
at Module._compile (internal/modules/cjs/loader.js:1085:14)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
at Module.load (internal/modules/cjs/loader.js:950:32) {
code: 'ERR_DLOPEN_FAILED'
Sun Mar 27 2022 09:55:08 GMT+0200 (Central European Summer Time) - Jeedom url : http://127.0.0.1:80/plugins/mySensors/core/api/jeeSensors.php?apikey=XXXXXX&gateway=master, gwAddress : /dev/ttyUSB1
throw e;
Une solution a été trouvée sur le forum, merci @EtienneM
Erreur connexion gateway
Le protocole mysensors comme tout protocole de communication est vital pour nos systèmes domotique (cde de chauffage, de volets, …, capteurs de températures, de position, …)
Cela amène quelques questions :
- comment expliquer cet arrêt de fonctionnement pour un simple passage à l’heure d’été ?
- le plugin mysensors est-il toujours maintenu par son développeur ?
- va t’il fonctionner au passage à jeedom v4.2 ?
- va t’il fonctionner sur les prochaines version linux ?
- comment rendre le système pérenne ?
