Mqtt2 n'aime pas les accents dans les topics
J’ai des topics avec des accès et ces derniers ne sont pas pris en compte lorsque le plugin recoit des informations avec le message suivant dans les logs
[2024-12-01 18:28:25] DEBUG  Message reçu sans prise en charge par un plugin : {"homeassistant":{"cover":{"vlx-baie-\u00e9tage-droit":{"config":{"name":"","state_topic":"homeassistant\/cover\/vlx-baie-\u00e9tage-droit\/state","availability_topic":"homeassistant\/cover\/vlx-baie-\u00e9tage-droit\/available","unique_id":"vlx-baie-\u00e9tage-droit","device":{"name":"Baie \u00e9tage droit","identifiers":["vlx-baie-\u00e9tage-droit"]},"position_topic":"homeassistant\/cover\/vlx-baie-\u00e9tage-droit\/position","command_topic":"homeassistant\/cover\/vlx-baie-\u00e9tage-droit\/set","set_position_topic":"homeassistant\/cover\/vlx-baie-\u00e9tage-droit\/set","position_open":0,"position_closed":100,"device_class":"shutter"},"available":"online","position":100,"state":"closed"},"vlx-baie-piscine":{"config":{"name":"","state_topic":"homeassistant\/cover\/vlx-baie-piscine\/state","availability_topic":"homeassistant\/cover\/vlx-baie-piscine\/available","unique_id":"vlx-baie-piscine","device":{"name":"Baie piscine","identifiers":["vlx-baie-piscine"]},"position_topic":"homeassistant\/cover\/vlx-baie-piscine\/position","command_topic":"homeassistant\/cover\/vlx-baie-piscine\/set","set_position_topic":"homeassistant\/cover\/vlx-baie-piscine\/set","position_open":0,"position_closed":100,"device_class":"shutter"},"available":"online"},"vlx-baie-\u00e9tage-centre":{"config":{"name":"","state_topic":"homeassistant\/cover\/vlx-baie-\u00e9tage-centre\/state","availability_topic":"homeassistant\/cover\/vlx-baie-\u00e9tage-centre\/available","unique_id":"vlx-baie-\u00e9tage-centre","device":{"name":"Baie \u00e9tage centre","identifiers":["vlx-baie-\u00e9tage-centre"]},"position_topic":"homeassistant\/cover\/vlx-baie-\u00e9tage-centre\/position","command_topic":"homeassistant\/cover\/vlx-baie-\u00e9tage-centre\/set","set_position_topic":"homeassistant\/cover\/vlx-baie-\u00e9tage-centre\/set","position_open":0,"position_closed":100,"device_class":"shutter"},"available":"online"},"vlx-baie-\u00e9tage-gauche":{"config":{"name":"","state_topic":"homeassistant\/cover\/vlx-baie-\u00e9tage-gauche\/state","availability_topic":"homeassistant\/cover\/vlx-baie-\u00e9tage-gauche\/available","unique_id":"vlx-baie-\u00e9tage-gauche","device":{"name":"Baie \u00e9tage gauche","identifiers":["vlx-baie-\u00e9tage-gauche"]},"position_topic":"homeassistant\/cover\/vlx-baie-\u00e9tage-gauche\/position","command_topic":"homeassistant\/cover\/vlx-baie-\u00e9tage-gauche\/set","set_position_topic":"homeassistant\/cover\/vlx-baie-\u00e9tage-gauche\/set","position_open":0,"position_closed":100,"device_class":"shutter"},"available":"online"}},"switch":{"vlx-baie-\u00e9tage-droit-keepopen":{"config":{"name":"Keep open","state_topic":"homeassistant\/switch\/vlx-baie-\u00e9tage-droit-keepopen\/state","availability_topic":"homeassistant\/switch\/vlx-baie-\u00e9tage-droit-keepopen\/available","unique_id":"vlx-baie-\u00e9tage-droit-keepopen","device":{"name":"Baie \u00e9tage droit","identifiers":["vlx-baie-\u00e9tage-droit"]},"icon":"mdi:lock-outline","command_topic":"homeassistant\/switch\/vlx-baie-\u00e9tage-droit-keepopen\/set","payload_off":"off","payload_on":"on"},"available":"online","state":"off"},"vlx-baie-piscine-keepopen":{"config":{"name":"Keep open","state_topic":"homeassistant\/switch\/vlx-baie-piscine-keepopen\/state","availability_topic":"homeassistant\/switch\/vlx-baie-piscine-keepopen\/available","unique_id":"vlx-baie-piscine-keepopen","device":{"name":"Baie piscine","identifiers":["vlx-baie-piscine"]},"icon":"mdi:lock-outline","command_topic":"homeassistant\/switch\/vlx-baie-piscine-keepopen\/set","payload_off":"off","payload_on":"on"},"available":"online","state":"off"},"vlx-baie-\u00e9tage-centre-keepopen":{"config":{"name":"Keep open","state_topic":"homeassistant\/switch\/vlx-baie-\u00e9tage-centre-keepopen\/state","availability_topic":"homeassistant\/switch\/vlx-baie-\u00e9tage-centre-keepopen\/available","unique_id":"vlx-baie-\u00e9tage-centre-keepopen","device":{"name":"Baie \u00e9tage centre","identifiers":["vlx-baie-\u00e9tage-centre"]},"icon":"mdi:lock-outline","command_topic":"homeassistant\/switch\/vlx-baie-\u00e9tage-centre-keepopen\/set","payload_off":"off","payload_on":"on"},"available":"online","state":"off"},"vlx-baie-\u00e9tage-gauche-keepopen":{"config":{"name":"Keep open","state_topic":"homeassistant\/switch\/vlx-baie-\u00e9tage-gauche-keepopen\/state","availability_topic":"homeassistant\/switch\/vlx-baie-\u00e9tage-gauche-keepopen\/available","unique_id":"vlx-baie-\u00e9tage-gauche-keepopen","device":{"name":"Baie \u00e9tage gauche","identifiers":["vlx-baie-\u00e9tage-gauche"]},"icon":"mdi:lock-outline","command_topic":"homeassistant\/switch\/vlx-baie-\u00e9tage-gauche-keepopen\/set","payload_off":"off","payload_on":"on"},"available":"online","state":"off"}}}}
[2024-12-01 18:28:26] DEBUG  Message reçu sans prise en charge par un plugin : {"homeassistant":{"cover":{"vlx-baie-piscine":{"position":100,"state":"closed"}},"switch":{"vlx-baie-piscine-keepopen":{"state":"off"}}}}
[2024-12-01 18:28:27] DEBUG  Message reçu sans prise en charge par un plugin : {"homeassistant":{"cover":{"vlx-baie-\u00e9tage-centre":{"position":100,"state":"closed"}},"switch":{"vlx-baie-\u00e9tage-centre-keepopen":{"state":"on"}}}}
le topic est le suivant :
Par contre, pas de souci lors de l’envoi d’un payload, il est bien reçu et interprété par mosquito dans le bon topic
Norbert
Non les accents ne sont pas géré ainsi que pas mal de caractères spéciaux.
