[2026-09-28 15:03:21]WARNING : Unexpected disconnection from MQTT
[2026-09-28 15:03:22] INFO : Successfully connected to MQTT server
[2026-09-28 15:03:22] INFO : Successfully subscribed to discovery topic homeassistant
[2026-09-28 15:03:22] INFO : Successfully subscribed to Myfox2mqtt
[2026-09-28 15:03:22] INFO : Successfully subscribed to zigbee2mqtt_Nano
[2026-09-28 15:03:22] INFO : Successfully subscribed to myfox2mqtt
[2026-09-28 15:03:22] INFO : Sending batch of 496 changes; 132 remaining
[2026-09-28 15:07:32] INFO : Sending batch of 132 changes; 208 remaining
[2026-09-28 15:08:40] INFO : Sending batch of 86 changes; 123 remaining
[2026-09-28 15:03:21] INFO Nouvelle découverte, résumé des configuations:
[2026-09-28 15:03:21] INFO - Importées: 0
[2026-09-28 15:03:21] INFO - Auto-création inactive: 0
[2026-09-28 15:03:21] INFO - Topic ignoré: 0
[2026-09-28 15:03:21] INFO - Erronées: 0
[2026-09-28 15:03:21] INFO - Non supportées: 0
[2026-09-28 15:03:21] INFO - Total reçues: 0
[2026-09-28 15:07:32] INFO Nouvelle découverte, résumé des configuations:
[2026-09-28 15:07:32] INFO - Importées: 476
[2026-09-28 15:07:32] INFO - Auto-création inactive: 10
[2026-09-28 15:07:32] INFO - Topic ignoré: 9
[2026-09-28 15:07:32] INFO - Erronées: 0
[2026-09-28 15:07:32] INFO - Non supportées: 0
[2026-09-28 15:07:32] INFO - Total reçues: 495
[2026-09-28 15:08:35]WARNING Component event not yet supported: {"availability":[{"topic":"zigbee2mqtt_Nano\/bridge\/state","value_template":"{{ value_json.state }}"},{"topic":"zigbee2mqtt_Nano\/Bouton Ikea Palier\/availability","value_template":"{{ value_json.state }}"}],"availability_mode":"all","default_entity_id":"event.bouton_ikea_palier_action","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xbc33acfffeaa71f9"],"manufacturer":"IKEA","model":"TRADFRI on\/off switch","model_id":"E1743","name":"Bouton Ikea Palier","sw_version":"24.4.6","via_device":"zigbee2mqtt_bridge_0xbc8d7efffe2638bb"},"event_types":["on","off","brightness_move_up","brightness_move_down","brightness_stop"],"icon":"mdi:gesture-double-tap","name":"Action","object_id":"bouton_ikea_palier_action","origin":{"name":"Zigbee2MQTT","sw":"2.13.0","url":"https:\/\/www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt_Nano\/Bouton Ikea Palier","unique_id":"0xbc33acfffeaa71f9_action_zigbee2mqtt_Nano","value_template":"{% set patterns = [\n{\"pattern\": '^(?P<button>(?:button_)?[a-z0-9]+)_(?P<action>(?:press|hold)(?:_release)?)$', \"groups\": [\"button\", \"action\"]},\n{\"pattern\": '^(?P<action>recall|scene)_(?P<scene>[0-2][0-9]{0,2})$', \"groups\": [\"action\", \"scene\"]},\n{\"pattern\": '^(?P<actionPrefix>region_)(?P<region>[1-9]|10)_(?P<action>enter|leave|occupied|unoccupied)$', \"groups\": [\"actionPrefix\", \"region\", \"action\"]},\n{\"pattern\": '^(?P<action>dial_rotate)_(?P<direction>left|right)_(?P<speed>step|slow|fast)$', \"groups\": [\"action\", \"direction\", \"speed\"]},\n{\"pattern\": '^(?P<action>brightness_step)(?:_(?P<direction>up|down))?$', \"groups\": [\"action\", \"direction\"]}\n] %}\n{% set action_value = value_json.action|default('') %}\n{% set ns = namespace(r=[('action', action_value)]) %}\n{% for p in patterns %}\n {% set m = action_value|regex_findall(p.pattern) %}\n {% if m[0] is undefined %}{% continue %}{% endif %}\n {% for key, value in zip(p.groups, m[0]) %}\n {% set ns.r = ns.r|rejectattr(0, 'eq', key)|list + [(key, value)] %}\n {% endfor %}\n{% endfor %}\n{% if (ns.r|selectattr(0, 'eq', 'actionPrefix')|first) is defined %}\n {% set ns.r = ns.r|rejectattr(0, 'eq', 'action')|list + [('action', ns.r|selectattr(0, 'eq', 'actionPrefix')|map(attribute=1)|first + ns.r|selectattr(0, 'eq', 'action')|map(attribute=1)|first)] %}\n{% endif %}\n{% set ns.r = ns.r + [('event_type', ns.r|selectattr(0, 'eq', 'action')|map(attribute=1)|first)] %}\n{{dict.from_keys(ns.r|rejectattr(0, 'in', ('action', 'actionPrefix'))|reject('eq', ('event_type', None))|reject('eq', ('event_type', '')))|to_json}}"}
[2026-09-28 15:08:35]WARNING Component event not yet supported: {"availability":[{"topic":"zigbee2mqtt_Nano\/bridge\/state","value_template":"{{ value_json.state }}"},{"topic":"zigbee2mqtt_Nano\/Bouton IKEA tradfri\/availability","value_template":"{{ value_json.state }}"}],"availability_mode":"all","default_entity_id":"event.bouton_ikea_tradfri_action","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0x287681fffee33a55"],"manufacturer":"IKEA","model":"STYRBAR remote control","model_id":"E2001\/E2002\/E2313","name":"Bouton IKEA tradfri","sw_version":"2.4.16","via_device":"zigbee2mqtt_bridge_0xbc8d7efffe2638bb"},"event_types":["on","off","brightness_move_up","brightness_move_down","brightness_stop","arrow_left_click","arrow_left_hold","arrow_left_release","arrow_right_click","arrow_right_hold","arrow_right_release"],"icon":"mdi:gesture-double-tap","name":"Action","object_id":"bouton_ikea_tradfri_action","origin":{"name":"Zigbee2MQTT","sw":"2.13.0","url":"https:\/\/www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt_Nano\/Bouton IKEA tradfri","unique_id":"0x287681fffee33a55_action_zigbee2mqtt_Nano","value_template":"{% set patterns = [\n{\"pattern\": '^(?P<button>(?:button_)?[a-z0-9]+)_(?P<action>(?:press|hold)(?:_release)?)$', \"groups\": [\"button\", \"action\"]},\n{\"pattern\": '^(?P<action>recall|scene)_(?P<scene>[0-2][0-9]{0,2})$', \"groups\": [\"action\", \"scene\"]},\n{\"pattern\": '^(?P<actionPrefix>region_)(?P<region>[1-9]|10)_(?P<action>enter|leave|occupied|unoccupied)$', \"groups\": [\"actionPrefix\", \"region\", \"action\"]},\n{\"pattern\": '^(?P<action>dial_rotate)_(?P<direction>left|right)_(?P<speed>step|slow|fast)$', \"groups\": [\"action\", \"direction\", \"speed\"]},\n{\"pattern\": '^(?P<action>brightness_step)(?:_(?P<direction>up|down))?$', \"groups\": [\"action\", \"direction\"]}\n] %}\n{% set action_value = value_json.action|default('') %}\n{% set ns = namespace(r=[('action', action_value)]) %}\n{% for p in patterns %}\n {% set m = action_value|regex_findall(p.pattern) %}\n {% if m[0] is undefined %}{% continue %}{% endif %}\n {% for key, value in zip(p.groups, m[0]) %}\n {% set ns.r = ns.r|rejectattr(0, 'eq', key)|list + [(key, value)] %}\n {% endfor %}\n{% endfor %}\n{% if (ns.r|selectattr(0, 'eq', 'actionPrefix')|first) is defined %}\n {% set ns.r = ns.r|rejectattr(0, 'eq', 'action')|list + [('action', ns.r|selectattr(0, 'eq', 'actionPrefix')|map(attribute=1)|first + ns.r|selectattr(0, 'eq', 'action')|map(attribute=1)|first)] %}\n{% endif %}\n{% set ns.r = ns.r + [('event_type', ns.r|selectattr(0, 'eq', 'action')|map(attribute=1)|first)] %}\n{{dict.from_keys(ns.r|rejectattr(0, 'in', ('action', 'actionPrefix'))|reject('eq', ('event_type', None))|reject('eq', ('event_type', '')))|to_json}}"}
[2026-09-28 15:08:35]WARNING Component event not yet supported: {"availability":[{"topic":"zigbee2mqtt_Nano\/bridge\/state","value_template":"{{ value_json.state }}"},{"topic":"zigbee2mqtt_Nano\/Bouton tv\/availability","value_template":"{{ value_json.state }}"}],"availability_mode":"all","default_entity_id":"event.bouton_tv_action","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xbc33acfffea517aa"],"manufacturer":"IKEA","model":"TRADFRI on\/off switch","model_id":"E1743","name":"Bouton tv","sw_version":"24.4.6","via_device":"zigbee2mqtt_bridge_0xbc8d7efffe2638bb"},"event_types":["on","off","brightness_move_up","brightness_move_down","brightness_stop"],"icon":"mdi:gesture-double-tap","name":"Action","object_id":"bouton_tv_action","origin":{"name":"Zigbee2MQTT","sw":"2.13.0","url":"https:\/\/www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt_Nano\/Bouton tv","unique_id":"0xbc33acfffea517aa_action_zigbee2mqtt_Nano","value_template":"{% set patterns = [\n{\"pattern\": '^(?P<button>(?:button_)?[a-z0-9]+)_(?P<action>(?:press|hold)(?:_release)?)$', \"groups\": [\"button\", \"action\"]},\n{\"pattern\": '^(?P<action>recall|scene)_(?P<scene>[0-2][0-9]{0,2})$', \"groups\": [\"action\", \"scene\"]},\n{\"pattern\": '^(?P<actionPrefix>region_)(?P<region>[1-9]|10)_(?P<action>enter|leave|occupied|unoccupied)$', \"groups\": [\"actionPrefix\", \"region\", \"action\"]},\n{\"pattern\": '^(?P<action>dial_rotate)_(?P<direction>left|right)_(?P<speed>step|slow|fast)$', \"groups\": [\"action\", \"direction\", \"speed\"]},\n{\"pattern\": '^(?P<action>brightness_step)(?:_(?P<direction>up|down))?$', \"groups\": [\"action\", \"direction\"]}\n] %}\n{% set action_value = value_json.action|default('') %}\n{% set ns = namespace(r=[('action', action_value)]) %}\n{% for p in patterns %}\n {% set m = action_value|regex_findall(p.pattern) %}\n {% if m[0] is undefined %}{% continue %}{% endif %}\n {% for key, value in zip(p.groups, m[0]) %}\n {% set ns.r = ns.r|rejectattr(0, 'eq', key)|list + [(key, value)] %}\n {% endfor %}\n{% endfor %}\n{% if (ns.r|selectattr(0, 'eq', 'actionPrefix')|first) is defined %}\n {% set ns.r = ns.r|rejectattr(0, 'eq', 'action')|list + [('action', ns.r|selectattr(0, 'eq', 'actionPrefix')|map(attribute=1)|first + ns.r|selectattr(0, 'eq', 'action')|map(attribute=1)|first)] %}\n{% endif %}\n{% set ns.r = ns.r + [('event_type', ns.r|selectattr(0, 'eq', 'action')|map(attribute=1)|first)] %}\n{{dict.from_keys(ns.r|rejectattr(0, 'in', ('action', 'actionPrefix'))|reject('eq', ('event_type', None))|reject('eq', ('event_type', '')))|to_json}}"}
[2026-09-28 15:08:35]WARNING Component event not yet supported: {"availability":[{"topic":"zigbee2mqtt_Nano\/bridge\/state","value_template":"{{ value_json.state }}"},{"topic":"zigbee2mqtt_Nano\/Vibration BaL\/availability","value_template":"{{ value_json.state }}"}],"availability_mode":"all","default_entity_id":"event.vibration_bal_action","device":{"identifiers":["zigbee2mqtt_0x00158d0002a48e43"],"manufacturer":"Aqara","model":"Vibration sensor","model_id":"DJT11LM","name":"Vibration BaL","via_device":"zigbee2mqtt_bridge_0xbc8d7efffe2638bb"},"event_types":["vibration","tilt","drop"],"icon":"mdi:gesture-double-tap","name":"Action","object_id":"vibration_bal_action","origin":{"name":"Zigbee2MQTT","sw":"2.13.0","url":"https:\/\/www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt_Nano\/Vibration BaL","unique_id":"0x00158d0002a48e43_action_zigbee2mqtt_Nano","value_template":"{% set patterns = [\n{\"pattern\": '^(?P<button>(?:button_)?[a-z0-9]+)_(?P<action>(?:press|hold)(?:_release)?)$', \"groups\": [\"button\", \"action\"]},\n{\"pattern\": '^(?P<action>recall|scene)_(?P<scene>[0-2][0-9]{0,2})$', \"groups\": [\"action\", \"scene\"]},\n{\"pattern\": '^(?P<actionPrefix>region_)(?P<region>[1-9]|10)_(?P<action>enter|leave|occupied|unoccupied)$', \"groups\": [\"actionPrefix\", \"region\", \"action\"]},\n{\"pattern\": '^(?P<action>dial_rotate)_(?P<direction>left|right)_(?P<speed>step|slow|fast)$', \"groups\": [\"action\", \"direction\", \"speed\"]},\n{\"pattern\": '^(?P<action>brightness_step)(?:_(?P<direction>up|down))?$', \"groups\": [\"action\", \"direction\"]}\n] %}\n{% set action_value = value_json.action|default('') %}\n{% set ns = namespace(r=[('action', action_value)]) %}\n{% for p in patterns %}\n {% set m = action_value|regex_findall(p.pattern) %}\n {% if m[0] is undefined %}{% continue %}{% endif %}\n {% for key, value in zip(p.groups, m[0]) %}\n {% set ns.r = ns.r|rejectattr(0, 'eq', key)|list + [(key, value)] %}\n {% endfor %}\n{% endfor %}\n{% if (ns.r|selectattr(0, 'eq', 'actionPrefix')|first) is defined %}\n {% set ns.r = ns.r|rejectattr(0, 'eq', 'action')|list + [('action', ns.r|selectattr(0, 'eq', 'actionPrefix')|map(attribute=1)|first + ns.r|selectattr(0, 'eq', 'action')|map(attribute=1)|first)] %}\n{% endif %}\n{% set ns.r = ns.r + [('event_type', ns.r|selectattr(0, 'eq', 'action')|map(attribute=1)|first)] %}\n{{dict.from_keys(ns.r|rejectattr(0, 'in', ('action', 'actionPrefix'))|reject('eq', ('event_type', None))|reject('eq', ('event_type', '')))|to_json}}"}
[2026-09-28 15:08:35]WARNING Component event not yet supported: {"availability":[{"topic":"zigbee2mqtt_Nano\/bridge\/state","value_template":"{{ value_json.state }}"},{"topic":"zigbee2mqtt_Nano\/Bouton chati\u00e8re\/availability","value_template":"{{ value_json.state }}"}],"availability_mode":"all","default_entity_id":"event.bouton_chati\u00e8re_action","device":{"identifiers":["zigbee2mqtt_0x00158d0002136542"],"manufacturer":"Aqara","model":"Wireless mini switch","model_id":"WXKG11LM","name":"Bouton chati\u00e8re","via_device":"zigbee2mqtt_bridge_0xbc8d7efffe2638bb"},"event_types":["single","double","triple","quadruple","hold","release"],"icon":"mdi:gesture-double-tap","name":"Action","object_id":"bouton_chati\u00e8re_action","origin":{"name":"Zigbee2MQTT","sw":"2.13.0","url":"https:\/\/www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt_Nano\/Bouton chati\u00e8re","unique_id":"0x00158d0002136542_action_zigbee2mqtt_Nano","value_template":"{% set patterns = [\n{\"pattern\": '^(?P<button>(?:button_)?[a-z0-9]+)_(?P<action>(?:press|hold)(?:_release)?)$', \"groups\": [\"button\", \"action\"]},\n{\"pattern\": '^(?P<action>recall|scene)_(?P<scene>[0-2][0-9]{0,2})$', \"groups\": [\"action\", \"scene\"]},\n{\"pattern\": '^(?P<actionPrefix>region_)(?P<region>[1-9]|10)_(?P<action>enter|leave|occupied|unoccupied)$', \"groups\": [\"actionPrefix\", \"region\", \"action\"]},\n{\"pattern\": '^(?P<action>dial_rotate)_(?P<direction>left|right)_(?P<speed>step|slow|fast)$', \"groups\": [\"action\", \"direction\", \"speed\"]},\n{\"pattern\": '^(?P<action>brightness_step)(?:_(?P<direction>up|down))?$', \"groups\": [\"action\", \"direction\"]}\n] %}\n{% set action_value = value_json.action|default('') %}\n{% set ns = namespace(r=[('action', action_value)]) %}\n{% for p in patterns %}\n {% set m = action_value|regex_findall(p.pattern) %}\n {% if m[0] is undefined %}{% continue %}{% endif %}\n {% for key, value in zip(p.groups, m[0]) %}\n {% set ns.r = ns.r|rejectattr(0, 'eq', key)|list + [(key, value)] %}\n {% endfor %}\n{% endfor %}\n{% if (ns.r|selectattr(0, 'eq', 'actionPrefix')|first) is defined %}\n {% set ns.r = ns.r|rejectattr(0, 'eq', 'action')|list + [('action', ns.r|selectattr(0, 'eq', 'actionPrefix')|map(attribute=1)|first + ns.r|selectattr(0, 'eq', 'action')|map(attribute=1)|first)] %}\n{% endif %}\n{% set ns.r = ns.r + [('event_type', ns.r|selectattr(0, 'eq', 'action')|map(attribute=1)|first)] %}\n{{dict.from_keys(ns.r|rejectattr(0, 'in', ('action', 'actionPrefix'))|reject('eq', ('event_type', None))|reject('eq', ('event_type', '')))|to_json}}"}
[2026-09-28 15:08:35]WARNING Component event not yet supported: {"availability":[{"topic":"zigbee2mqtt_Nano\/bridge\/state","value_template":"{{ value_json.state }}"},{"topic":"zigbee2mqtt_Nano\/bouton machine a laver\/availability","value_template":"{{ value_json.state }}"}],"availability_mode":"all","default_entity_id":"event.bouton_machine_a_laver_action","device":{"identifiers":["zigbee2mqtt_0x00158d0001e18f5f"],"manufacturer":"Xiaomi","model":"Mi wireless switch","model_id":"WXKG01LM","name":"bouton machine a laver","via_device":"zigbee2mqtt_bridge_0xbc8d7efffe2638bb"},"event_types":["single","double","triple","quadruple","hold","release","many"],"icon":"mdi:gesture-double-tap","name":"Action","object_id":"bouton_machine_a_laver_action","origin":{"name":"Zigbee2MQTT","sw":"2.13.0","url":"https:\/\/www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt_Nano\/bouton machine a laver","unique_id":"0x00158d0001e18f5f_action_zigbee2mqtt_Nano","value_template":"{% set patterns = [\n{\"pattern\": '^(?P<button>(?:button_)?[a-z0-9]+)_(?P<action>(?:press|hold)(?:_release)?)$', \"groups\": [\"button\", \"action\"]},\n{\"pattern\": '^(?P<action>recall|scene)_(?P<scene>[0-2][0-9]{0,2})$', \"groups\": [\"action\", \"scene\"]},\n{\"pattern\": '^(?P<actionPrefix>region_)(?P<region>[1-9]|10)_(?P<action>enter|leave|occupied|unoccupied)$', \"groups\": [\"actionPrefix\", \"region\", \"action\"]},\n{\"pattern\": '^(?P<action>dial_rotate)_(?P<direction>left|right)_(?P<speed>step|slow|fast)$', \"groups\": [\"action\", \"direction\", \"speed\"]},\n{\"pattern\": '^(?P<action>brightness_step)(?:_(?P<direction>up|down))?$', \"groups\": [\"action\", \"direction\"]}\n] %}\n{% set action_value = value_json.action|default('') %}\n{% set ns = namespace(r=[('action', action_value)]) %}\n{% for p in patterns %}\n {% set m = action_value|regex_findall(p.pattern) %}\n {% if m[0] is undefined %}{% continue %}{% endif %}\n {% for key, value in zip(p.groups, m[0]) %}\n {% set ns.r = ns.r|rejectattr(0, 'eq', key)|list + [(key, value)] %}\n {% endfor %}\n{% endfor %}\n{% if (ns.r|selectattr(0, 'eq', 'actionPrefix')|first) is defined %}\n {% set ns.r = ns.r|rejectattr(0, 'eq', 'action')|list + [('action', ns.r|selectattr(0, 'eq', 'actionPrefix')|map(attribute=1)|first + ns.r|selectattr(0, 'eq', 'action')|map(attribute=1)|first)] %}\n{% endif %}\n{% set ns.r = ns.r + [('event_type', ns.r|selectattr(0, 'eq', 'action')|map(attribute=1)|first)] %}\n{{dict.from_keys(ns.r|rejectattr(0, 'in', ('action', 'actionPrefix'))|reject('eq', ('event_type', None))|reject('eq', ('event_type', '')))|to_json}}"}
[2026-09-28 15:08:35]WARNING Component event not yet supported: {"availability":[{"topic":"zigbee2mqtt_Nano\/bridge\/state","value_template":"{{ value_json.state }}"},{"topic":"zigbee2mqtt_Nano\/Interrupteur escalier cave\/availability","value_template":"{{ value_json.state }}"}],"availability_mode":"all","default_entity_id":"event.interrupteur_escalier_cave_action","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0x842e14fffefe998a"],"manufacturer":"IKEA","model":"TRADFRI on\/off switch","model_id":"E1743","name":"Interrupteur escalier cave","sw_version":"24.4.6","via_device":"zigbee2mqtt_bridge_0xbc8d7efffe2638bb"},"event_types":["on","off","brightness_move_up","brightness_move_down","brightness_stop"],"icon":"mdi:gesture-double-tap","name":"Action","object_id":"interrupteur_escalier_cave_action","origin":{"name":"Zigbee2MQTT","sw":"2.13.0","url":"https:\/\/www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt_Nano\/Interrupteur escalier cave","unique_id":"0x842e14fffefe998a_action_zigbee2mqtt_Nano","value_template":"{% set patterns = [\n{\"pattern\": '^(?P<button>(?:button_)?[a-z0-9]+)_(?P<action>(?:press|hold)(?:_release)?)$', \"groups\": [\"button\", \"action\"]},\n{\"pattern\": '^(?P<action>recall|scene)_(?P<scene>[0-2][0-9]{0,2})$', \"groups\": [\"action\", \"scene\"]},\n{\"pattern\": '^(?P<actionPrefix>region_)(?P<region>[1-9]|10)_(?P<action>enter|leave|occupied|unoccupied)$', \"groups\": [\"actionPrefix\", \"region\", \"action\"]},\n{\"pattern\": '^(?P<action>dial_rotate)_(?P<direction>left|right)_(?P<speed>step|slow|fast)$', \"groups\": [\"action\", \"direction\", \"speed\"]},\n{\"pattern\": '^(?P<action>brightness_step)(?:_(?P<direction>up|down))?$', \"groups\": [\"action\", \"direction\"]}\n] %}\n{% set action_value = value_json.action|default('') %}\n{% set ns = namespace(r=[('action', action_value)]) %}\n{% for p in patterns %}\n {% set m = action_value|regex_findall(p.pattern) %}\n {% if m[0] is undefined %}{% continue %}{% endif %}\n {% for key, value in zip(p.groups, m[0]) %}\n {% set ns.r = ns.r|rejectattr(0, 'eq', key)|list + [(key, value)] %}\n {% endfor %}\n{% endfor %}\n{% if (ns.r|selectattr(0, 'eq', 'actionPrefix')|first) is defined %}\n {% set ns.r = ns.r|rejectattr(0, 'eq', 'action')|list + [('action', ns.r|selectattr(0, 'eq', 'actionPrefix')|map(attribute=1)|first + ns.r|selectattr(0, 'eq', 'action')|map(attribute=1)|first)] %}\n{% endif %}\n{% set ns.r = ns.r + [('event_type', ns.r|selectattr(0, 'eq', 'action')|map(attribute=1)|first)] %}\n{{dict.from_keys(ns.r|rejectattr(0, 'in', ('action', 'actionPrefix'))|reject('eq', ('event_type', None))|reject('eq', ('event_type', '')))|to_json}}"}
[2026-09-28 15:08:35]WARNING Component event not yet supported: {"availability":[{"topic":"zigbee2mqtt_Nano\/bridge\/state","value_template":"{{ value_json.state }}"},{"topic":"zigbee2mqtt_Nano\/Interrupteur, armoire, cave\/availability","value_template":"{{ value_json.state }}"}],"availability_mode":"all","default_entity_id":"event.interrupteur,_armoire,_cave_action","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0x680ae2fffef74b93"],"manufacturer":"IKEA","model":"TRADFRI on\/off switch","model_id":"E1743","name":"Interrupteur, armoire, cave","sw_version":"24.4.6","via_device":"zigbee2mqtt_bridge_0xbc8d7efffe2638bb"},"event_types":["on","off","brightness_move_up","brightness_move_down","brightness_stop"],"icon":"mdi:gesture-double-tap","name":"Action","object_id":"interrupteur,_armoire,_cave_action","origin":{"name":"Zigbee2MQTT","sw":"2.13.0","url":"https:\/\/www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt_Nano\/Interrupteur, armoire, cave","unique_id":"0x680ae2fffef74b93_action_zigbee2mqtt_Nano","value_template":"{% set patterns = [\n{\"pattern\": '^(?P<button>(?:button_)?[a-z0-9]+)_(?P<action>(?:press|hold)(?:_release)?)$', \"groups\": [\"button\", \"action\"]},\n{\"pattern\": '^(?P<action>recall|scene)_(?P<scene>[0-2][0-9]{0,2})$', \"groups\": [\"action\", \"scene\"]},\n{\"pattern\": '^(?P<actionPrefix>region_)(?P<region>[1-9]|10)_(?P<action>enter|leave|occupied|unoccupied)$', \"groups\": [\"actionPrefix\", \"region\", \"action\"]},\n{\"pattern\": '^(?P<action>dial_rotate)_(?P<direction>left|right)_(?P<speed>step|slow|fast)$', \"groups\": [\"action\", \"direction\", \"speed\"]},\n{\"pattern\": '^(?P<action>brightness_step)(?:_(?P<direction>up|down))?$', \"groups\": [\"action\", \"direction\"]}\n] %}\n{% set action_value = value_json.action|default('') %}\n{% set ns = namespace(r=[('action', action_value)]) %}\n{% for p in patterns %}\n {% set m = action_value|regex_findall(p.pattern) %}\n {% if m[0] is undefined %}{% continue %}{% endif %}\n {% for key, value in zip(p.groups, m[0]) %}\n {% set ns.r = ns.r|rejectattr(0, 'eq', key)|list + [(key, value)] %}\n {% endfor %}\n{% endfor %}\n{% if (ns.r|selectattr(0, 'eq', 'actionPrefix')|first) is defined %}\n {% set ns.r = ns.r|rejectattr(0, 'eq', 'action')|list + [('action', ns.r|selectattr(0, 'eq', 'actionPrefix')|map(attribute=1)|first + ns.r|selectattr(0, 'eq', 'action')|map(attribute=1)|first)] %}\n{% endif %}\n{% set ns.r = ns.r + [('event_type', ns.r|selectattr(0, 'eq', 'action')|map(attribute=1)|first)] %}\n{{dict.from_keys(ns.r|rejectattr(0, 'in', ('action', 'actionPrefix'))|reject('eq', ('event_type', None))|reject('eq', ('event_type', '')))|to_json}}"}
[2026-09-28 15:08:35]WARNING Component event not yet supported: {"availability":[{"topic":"zigbee2mqtt_Nano\/bridge\/state","value_template":"{{ value_json.state }}"},{"topic":"zigbee2mqtt_Nano\/Sonnette\/availability","value_template":"{{ value_json.state }}"}],"availability_mode":"all","default_entity_id":"event.sonnette_action","device":{"identifiers":["zigbee2mqtt_0x00158d0001a3fc56"],"manufacturer":"Xiaomi","model":"Mi wireless switch","model_id":"WXKG01LM","name":"Sonnette","via_device":"zigbee2mqtt_bridge_0xbc8d7efffe2638bb"},"event_types":["single","double","triple","quadruple","hold","release","many"],"icon":"mdi:gesture-double-tap","name":"Action","object_id":"sonnette_action","origin":{"name":"Zigbee2MQTT","sw":"2.13.0","url":"https:\/\/www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt_Nano\/Sonnette","unique_id":"0x00158d0001a3fc56_action_zigbee2mqtt_Nano","value_template":"{% set patterns = [\n{\"pattern\": '^(?P<button>(?:button_)?[a-z0-9]+)_(?P<action>(?:press|hold)(?:_release)?)$', \"groups\": [\"button\", \"action\"]},\n{\"pattern\": '^(?P<action>recall|scene)_(?P<scene>[0-2][0-9]{0,2})$', \"groups\": [\"action\", \"scene\"]},\n{\"pattern\": '^(?P<actionPrefix>region_)(?P<region>[1-9]|10)_(?P<action>enter|leave|occupied|unoccupied)$', \"groups\": [\"actionPrefix\", \"region\", \"action\"]},\n{\"pattern\": '^(?P<action>dial_rotate)_(?P<direction>left|right)_(?P<speed>step|slow|fast)$', \"groups\": [\"action\", \"direction\", \"speed\"]},\n{\"pattern\": '^(?P<action>brightness_step)(?:_(?P<direction>up|down))?$', \"groups\": [\"action\", \"direction\"]}\n] %}\n{% set action_value = value_json.action|default('') %}\n{% set ns = namespace(r=[('action', action_value)]) %}\n{% for p in patterns %}\n {% set m = action_value|regex_findall(p.pattern) %}\n {% if m[0] is undefined %}{% continue %}{% endif %}\n {% for key, value in zip(p.groups, m[0]) %}\n {% set ns.r = ns.r|rejectattr(0, 'eq', key)|list + [(key, value)] %}\n {% endfor %}\n{% endfor %}\n{% if (ns.r|selectattr(0, 'eq', 'actionPrefix')|first) is defined %}\n {% set ns.r = ns.r|rejectattr(0, 'eq', 'action')|list + [('action', ns.r|selectattr(0, 'eq', 'actionPrefix')|map(attribute=1)|first + ns.r|selectattr(0, 'eq', 'action')|map(attribute=1)|first)] %}\n{% endif %}\n{% set ns.r = ns.r + [('event_type', ns.r|selectattr(0, 'eq', 'action')|map(attribute=1)|first)] %}\n{{dict.from_keys(ns.r|rejectattr(0, 'in', ('action', 'actionPrefix'))|reject('eq', ('event_type', None))|reject('eq', ('event_type', '')))|to_json}}"}
[2026-09-28 15:08:35]WARNING Component event not yet supported: {"availability":[{"topic":"zigbee2mqtt_Nano\/bridge\/state","value_template":"{{ value_json.state }}"},{"topic":"zigbee2mqtt_Nano\/Bouton Ikea Ch Verte\/availability","value_template":"{{ value_json.state }}"}],"availability_mode":"all","default_entity_id":"event.bouton_ikea_ch_verte_action","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0x000d6ffffee84181"],"manufacturer":"IKEA","model":"TRADFRI on\/off switch","model_id":"E1743","name":"Bouton Ikea Ch Verte","sw_version":"2.3.079","via_device":"zigbee2mqtt_bridge_0xbc8d7efffe2638bb"},"event_types":["on","off","brightness_move_up","brightness_move_down","brightness_stop"],"icon":"mdi:gesture-double-tap","name":"Action","object_id":"bouton_ikea_ch_verte_action","origin":{"name":"Zigbee2MQTT","sw":"2.13.0","url":"https:\/\/www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt_Nano\/Bouton Ikea Ch Verte","unique_id":"0x000d6ffffee84181_action_zigbee2mqtt_Nano","value_template":"{% set patterns = [\n{\"pattern\": '^(?P<button>(?:button_)?[a-z0-9]+)_(?P<action>(?:press|hold)(?:_release)?)$', \"groups\": [\"button\", \"action\"]},\n{\"pattern\": '^(?P<action>recall|scene)_(?P<scene>[0-2][0-9]{0,2})$', \"groups\": [\"action\", \"scene\"]},\n{\"pattern\": '^(?P<actionPrefix>region_)(?P<region>[1-9]|10)_(?P<action>enter|leave|occupied|unoccupied)$', \"groups\": [\"actionPrefix\", \"region\", \"action\"]},\n{\"pattern\": '^(?P<action>dial_rotate)_(?P<direction>left|right)_(?P<speed>step|slow|fast)$', \"groups\": [\"action\", \"direction\", \"speed\"]},\n{\"pattern\": '^(?P<action>brightness_step)(?:_(?P<direction>up|down))?$', \"groups\": [\"action\", \"direction\"]}\n] %}\n{% set action_value = value_json.action|default('') %}\n{% set ns = namespace(r=[('action', action_value)]) %}\n{% for p in patterns %}\n {% set m = action_value|regex_findall(p.pattern) %}\n {% if m[0] is undefined %}{% continue %}{% endif %}\n {% for key, value in zip(p.groups, m[0]) %}\n {% set ns.r = ns.r|rejectattr(0, 'eq', key)|list + [(key, value)] %}\n {% endfor %}\n{% endfor %}\n{% if (ns.r|selectattr(0, 'eq', 'actionPrefix')|first) is defined %}\n {% set ns.r = ns.r|rejectattr(0, 'eq', 'action')|list + [('action', ns.r|selectattr(0, 'eq', 'actionPrefix')|map(attribute=1)|first + ns.r|selectattr(0, 'eq', 'action')|map(attribute=1)|first)] %}\n{% endif %}\n{% set ns.r = ns.r + [('event_type', ns.r|selectattr(0, 'eq', 'action')|map(attribute=1)|first)] %}\n{{dict.from_keys(ns.r|rejectattr(0, 'in', ('action', 'actionPrefix'))|reject('eq', ('event_type', None))|reject('eq', ('event_type', '')))|to_json}}"}
la ca a fonctionné ! ca a mis du temps mais c’est reparti .
