Monitoring2 en jeedom 4.5 Debian 12
Bonjour à tous
Je commence à tester ma conf sur Debian 12 et jeedom 4.5
Ca se passe plutôt bien dans l’ensemble, aucun souci de MAJ
Le cache semble OK, pas vu de problème pour le moment sur les commandes
J’ai un souci d’installation des dépendances du plugin Monitoring2
je pose le log, mais c’est juste pour info, aucune urgence
0000|+ echo '*******************Begin of package installation******************'
0002|+ touch /tmp/jeedom_install_in_progress_monitoring2
0003|+ echo 1
0004|+ echo 2
0005|+ sudo killall apt apt-get unattended-upgr
0006|apt: no process found
0007|apt-get: no process found
0008|unattended-upgr: no process found
0009|+ sudo rm /var/lib/apt/lists/lock
0010|+ sudo rm /var/cache/apt/archives/lock
0011|rm: cannot remove '/var/cache/apt/archives/lock': No such file or directory
0012|+ sudo rm /var/lib/dpkg/lock /var/lib/dpkg/lock-frontend
0013|+ sudo sudo dpkg --configure -a --force-confdef
0014|+ sudo apt update
0015|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0016|Hit:1 http://deb.debian.org/debian bookworm InRelease
0017|Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
0018|Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
0019|Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
0020|Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
0021|Reading package lists...
0022|Building dependency tree...
0023|Reading state information...
0024|83 packages can be upgraded. Run 'apt list --upgradable' to see them.
0025|+ echo 3
0026|+ sudo apt install -o Dpkg::Options::=--force-confdef -y php-snmp
0027|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0028|Reading package lists...
0029|Building dependency tree...
0030|Reading state information...
0031|php-snmp is already the newest version (2:8.2+93).
0032|0 upgraded, 0 newly installed, 0 to remove and 83 not upgraded.
0033|+ echo 4
0034|+ sudo apt install -o Dpkg::Options::=--force-confdef -y php-ssh2
0035|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0036|Reading package lists...
0037|Building dependency tree...
0038|Reading state information...
0039|php-ssh2 is already the newest version (1.3.1+0.13-7).
0040|0 upgraded, 0 newly installed, 0 to remove and 83 not upgraded.
0041|+ echo 5
0042|+ sudo apt install -o Dpkg::Options::=--force-confdef -y snmp
0043|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0044|Reading package lists...
0045|Building dependency tree...
0046|Reading state information...
0047|snmp is already the newest version (5.9.3+dfsg-2).
0048|0 upgraded, 0 newly installed, 0 to remove and 83 not upgraded.
0049|+ echo 6
0050|+ sudo apt install -o Dpkg::Options::=--force-confdef -y snmp-mibs-downloader
0051|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0052|Reading package lists...
0053|Building dependency tree...
0054|Reading state information...
0055|Package snmp-mibs-downloader is not available, but is referred to by another package.
0056|This may mean that the package is missing, has been obsoleted, or
0057|is only available from another source
0058|E: Package 'snmp-mibs-downloader' has no installation candidate
0059|+ echo 7
0060|+ sudo systemctl restart apache2
0061|+ echo 8
0062|+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end monitoring2
0063|+ echo 9
0064|+ rm /tmp/jeedom_install_in_progress_monitoring2
0065|+ echo '*******************End of package installation******************'
0066|*******************End of package installation******************
et plein d’alertes JS sur toutes mes Vues
http://192.168.1.84/index.php?v=d&p=view	0	Erreur de directive Content Security Policy sur la ressource "https://fonts.gstatic.com/s/audiowide/v7/l7gdbjpo0cum0ckerWCdmA_OIxo.woff2"
Déjà signalé et la solution à l’époque était de passer en béta.
La stable de la 4.5 n’existe pas encore ?
merci pour le lien de suivi des plugins
si le problème est déjà remonté, c’est parfait, les admins, vous pouvez supprimer mon post, merci
Non pas encore
