Suite à un crash de mon ESXi j’ai remonté une VM en Debian 10 (la version de mon ESXi nécessite un upgrade pour passer en version 11 ou 12) et depuis j’ai des soucis pour faire remonter les infos de mon roborock S7… je ne comprend bien d’où cela peut bien venir le robot est bien détecté mais aucune commande ne remonte… (je précise que ça fonctionnait au poil avant mon crash).
Voici les lois à toutes fins utiles :
[2024-01-31 18:26:15][DEBUG] : ============================ DISCOVER ============================
[2024-01-31 18:26:16][DEBUG] : ["[{\"did\": \"535464230\", \"token\": \"xxxxx\", \"longitude\": \"0.0\", \"latitude\": \"0.0\", \"name\": \"Roborock S7 MaxV\", \"pid\": \"0\", \"localip\": \"192.168.15.20\", \"mac\": \"B0:4A:39:48:CA:26\", \"ssid\": \"OrbiLab\", \"bssid\": \"0E:36:C9:1E:BC:2E\", \"parent_id\": \"\", \"parent_model\": \"\", \"show_mode\": 1, \"model\": \"roborock.vacuum.a27\", \"adminFlag\": 1, \"shareFlag\": 0, \"permitLevel\": 16, \"isOnline\": true, \"desc\": \"Device online \", \"extra\": {\"isSetPincode\": 0, \"pincodeType\": 0, \"fw_version\": \"4.3.5_5840\", \"needVerifyCode\": 0, \"isPasswordEncrypt\": 0}, \"uid\": 8185725052, \"pd_id\": 72166, \"password\": \"\", \"p2p_id\": \"\", \"rssi\": -55, \"family_id\": 0, \"reset_flag\": 0}]"]
[2024-01-31 18:26:16][DEBUG] : [{"did":"535464230","token":"xxxxx","longitude":"0.0","latitude":"0.0","name":"Roborock S7 MaxV","pid":"0","localip":"192.168.15.20","mac":"B0:4A:39:48:CA:26","ssid":"OrbiLab","bssid":"0E:36:C9:1E:BC:2E","parent_id":"","parent_model":"","show_mode":1,"model":"roborock.vacuum.a27","adminFlag":1,"shareFlag":0,"permitLevel":16,"isOnline":true,"desc":"Device online ","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"4.3.5_5840","needVerifyCode":0,"isPasswordEncrypt":0},"uid":8185725052,"pd_id":72166,"password":"","p2p_id":"","rssi":-55,"family_id":0,"reset_flag":0}]
[2024-01-31 18:26:16][DEBUG] : Nouvel Equipement, ajout en cours.
[2024-01-31 18:26:16][DEBUG] : ============================ CREATING CMD ============================
[2024-01-31 18:26:16][DEBUG] : GENERATE CMD FROM CONFIG FILE : /var/www/html/plugins/mirobot/core/class/../conf/genericmiot.json
[2024-01-31 18:26:16][DEBUG] : CMD BY genericmiot => sudo /var/www/html/plugins/mirobot/core/class/../../resources/venv/bin/miiocli -o json_pretty genericmiot --ip 192.168.15.20 --token xxxxx status >&1 2>/var/www/html/plugins/mirobot/core/class/../../data/exec/error_4238.txt
[2024-01-31 18:26:16][DEBUG] : CMD result null
[2024-01-31 18:26:32][DEBUG] : removing all commands
[2024-01-31 18:26:32][DEBUG] : ============================ CREATING CMD ============================
[2024-01-31 18:26:32][DEBUG] : GENERATE CMD FROM CONFIG FILE : /var/www/html/plugins/mirobot/core/class/../conf/roborockvacuum.json
[2024-01-31 18:26:32][DEBUG] : CMD BY roborockvacuum => sudo /var/www/html/plugins/mirobot/core/class/../../resources/venv/bin/miiocli -o json_pretty roborockvacuum --ip 192.168.15.20 --token xxxxx status >&1 2>/var/www/html/plugins/mirobot/core/class/../../data/exec/error_4238.txt
[2024-01-31 18:26:33][DEBUG] : CMD result null
[2024-01-31 18:26:33][DEBUG] : CMD BY roborockvacuum => sudo /var/www/html/plugins/mirobot/core/class/../../resources/venv/bin/miiocli -o json_pretty roborockvacuum --ip 192.168.15.20 --token xxxxx get_room_mapping >&1 2>/var/www/html/plugins/mirobot/core/class/../../data/exec/error_4238.txt
[2024-01-31 18:27:02][DEBUG] : ============================ UPDATING CMD ============================
[2024-01-31 18:27:02][DEBUG] : GENERATE CMD FROM CONFIG FILE : /var/www/html/plugins/mirobot/core/class/../conf/roborockvacuum.json
[2024-01-31 18:27:02][DEBUG] : CMD BY roborockvacuum => sudo /var/www/html/plugins/mirobot/core/class/../../resources/venv/bin/miiocli -o json_pretty roborockvacuum --ip 192.168.15.20 --token xxxxx status >&1 2>/var/www/html/plugins/mirobot/core/class/../../data/exec/error_4238.txt
[2024-01-31 18:27:03][DEBUG] : CMD result null
[2024-01-31 18:28:01][DEBUG] : ============================ UPDATING CMD ============================
[2024-01-31 18:28:01][DEBUG] : GENERATE CMD FROM CONFIG FILE : /var/www/html/plugins/mirobot/core/class/../conf/roborockvacuum.json
[2024-01-31 18:28:01][DEBUG] : CMD BY roborockvacuum => sudo /var/www/html/plugins/mirobot/core/class/../../resources/venv/bin/miiocli -o json_pretty roborockvacuum --ip 192.168.15.20 --token xxxxx status >&1 2>/var/www/html/plugins/mirobot/core/class/../../data/exec/error_4238.txt
[2024-01-31 18:28:02][DEBUG] : CMD result null
[2024-01-31 18:29:02][DEBUG] : ============================ UPDATING CMD ============================
[2024-01-31 18:29:02][DEBUG] : GENERATE CMD FROM CONFIG FILE : /var/www/html/plugins/mirobot/core/class/../conf/roborockvacuum.json
[2024-01-31 18:29:02][DEBUG] : CMD BY roborockvacuum => sudo /var/www/html/plugins/mirobot/core/class/../../resources/venv/bin/miiocli -o json_pretty roborockvacuum --ip 192.168.15.20 --token xxxxx status >&1 2>/var/www/html/plugins/mirobot/core/class/../../data/exec/error_4238.txt
[2024-01-31 18:29:02][DEBUG] : CMD result null
[2024-01-31 18:30:46][DEBUG] : ============================ UPDATING CMD ============================
[2024-01-31 18:30:46][DEBUG] : GENERATE CMD FROM CONFIG FILE : /var/www/html/plugins/mirobot/core/class/../conf/roborockvacuum.json
[2024-01-31 18:30:46][DEBUG] : CMD BY roborockvacuum => sudo /var/www/html/plugins/mirobot/core/class/../../resources/venv/bin/miiocli -o json_pretty roborockvacuum --ip 192.168.15.20 --token xxxxx status >&1 2>/var/www/html/plugins/mirobot/core/class/../../data/exec/error_4238.txt
[2024-01-31 18:30:47][DEBUG] : CMD result null
Le fichier d’erreur
File "/var/www/html/plugins/mirobot/core/class/../../resources/venv/bin/miiocli", line 5, in <module>
from miio.cli import create_cli
File "/var/www/html/plugins/mirobot/resources/venv/lib/python3.8/site-packages/miio/__init__.py", line 96, in <module>
from miio.discovery import Discovery
File "/var/www/html/plugins/mirobot/resources/venv/lib/python3.8/site-packages/miio/discovery.py", line 6, in <module>
import zeroconf
File "/var/www/html/plugins/mirobot/resources/venv/lib/python3.8/site-packages/zeroconf/__init__.py", line 25, in <module>
from ._cache import DNSCache # noqa # import needed for backwards compat
File "src/zeroconf/_cache.py", line 1, in init zeroconf._cache
File "src/zeroconf/_protocol/incoming.py", line 1, in init zeroconf._protocol.incoming
File "src/zeroconf/_protocol/outgoing.py", line 1, in init zeroconf._protocol.outgoing
File "src/zeroconf/_dns.py", line 28, in init zeroconf._dns
File "/var/www/html/plugins/mirobot/resources/venv/lib/python3.8/site-packages/zeroconf/_utils/net.py", line 31, in <module>
import ifaddr
File "/var/www/html/plugins/mirobot/resources/venv/lib/python3.8/site-packages/ifaddr/__init__.py", line 24, in <module>
from ifaddr._shared import Adapter, IP
File "/var/www/html/plugins/mirobot/resources/venv/lib/python3.8/site-packages/ifaddr/_shared.py", line 22, in <module>
import ctypes
File "/usr/local/lib/python3.8/ctypes/__init__.py", line 7, in <module>
from _ctypes import Union, Structure, Array
ModuleNotFoundError: No module named '_ctypes'
Si quelqu’un a la solution je suis preneur!! Merci
