* Installing additional libraries *
Reading package lists...
Building dependency tree...
Reading state information...
autoconf is already the newest version (2.69-10).
automake is already the newest version (1:1.15-6).
libtool is already the newest version (2.4.6-2).
0 upgraded, 0 newly installed, 0 to remove and 165 not upgraded.
pkg-config is already the newest version (0.29-4+b1).
Package libpng12-dev is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libpng12-dev' has no installation candidate
libjpeg62-turbo-dev is already the newest version (1:1.5.1-2).
Package libtiff4-dev is not available, but is referred to by another package.
However the following packages replace it:
libtiff5-dev
E: Package 'libtiff4-dev' has no installation candidate
zlib1g-dev is already the newest version (1:1.2.8.dfsg-5).
git is already the newest version (1:2.11.0-3+deb9u7).
git-core is already the newest version (1:2.11.0-3+deb9u7).
cmake is already the newest version (3.7.2-1).
liblog4cplus-dev is already the newest version (1.1.2-3.2).
libcurl4-openssl-dev is already the newest version (7.52.1-5+deb9u10).
uuid-dev is already the newest version (2.29.2-1+deb9u1).
build-essential is already the newest version (12.3).
Package libjpeg8-dev is not available, but is referred to by another package.
libjpeg62-turbo-dev
E: Package 'libjpeg8-dev' has no installation candidate
E: Unable to locate package libjasper-dev
libgtk2.0-dev is already the newest version (2.24.31-2).
libavcodec-dev is already the newest version (7:3.2.14-1~deb9u1).
libavformat-dev is already the newest version (7:3.2.14-1~deb9u1).
libswscale-dev is already the newest version (7:3.2.14-1~deb9u1).
libv4l-dev is already the newest version (1.12.3-1).
libatlas-base-dev is already the newest version (3.10.3-1+b1).
gfortran is already the newest version (4:6.3.0-4).
python2.7-dev is already the newest version (2.7.13-2+deb9u3).
libopencv-dev is already the newest version (2.4.9.1+dfsg1-2).
libtesseract-dev is already the newest version (3.04.01-5).
libleptonica-dev is already the newest version (1.74.1-1).
beanstalkd is already the newest version (1.10-4).
* Compile openalpr: *
Cloning into 'openalpr'...
-- The C compiler identification is GNU 6.3.0
-- The CXX compiler identification is GNU 6.3.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Found Tesseract
-- Found CURL: /usr/lib/x86_64-linux-gnu/libcurl.so (found version "7.52.1")
-- Found log4cplus
-- Could NOT find JNI (missing: JAVA_INCLUDE_PATH JAVA_INCLUDE_PATH2 JAVA_AWT_INCLUDE_PATH)
JAVA JNI library not found, skipping openalprjni compilation
-- Configuring done
-- Generating done
-- Build files have been written to: /usr/local/src/openalpr/openalpr/src/build
Scanning dependencies of target support
[ 1%] Building CXX object openalpr/support/CMakeFiles/support.dir/filesystem.cpp.o
[ 1%] Building CXX object openalpr/support/CMakeFiles/support.dir/timing.cpp.o
[ 2%] Building CXX object openalpr/support/CMakeFiles/support.dir/tinythread.cpp.o
[ 2%] Building CXX object openalpr/support/CMakeFiles/support.dir/platform.cpp.o
[ 3%] Building CXX object openalpr/support/CMakeFiles/support.dir/utf8.cpp.o
[ 4%] Building CXX object openalpr/support/CMakeFiles/support.dir/version.cpp.o
[ 4%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/bitstate.cc.o
[ 5%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/compile.cc.o
[ 6%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/dfa.cc.o
[ 6%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/filtered_re2.cc.o
[ 7%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/mimics_pcre.cc.o
[ 8%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/nfa.cc.o
[ 8%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/onepass.cc.o
[ 9%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/parse.cc.o
[ 10%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/perl_groups.cc.o
[ 10%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/prefilter.cc.o
[ 11%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/prefilter_tree.cc.o
[ 12%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/prog.cc.o
[ 12%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/re2.cc.o
[ 13%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/regexp.cc.o
[ 14%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/set.cc.o
[ 14%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/simplify.cc.o
[ 15%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/stringpiece.cc.o
[ 16%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/tostring.cc.o
[ 16%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/unicode_casefold.cc.o
[ 17%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/unicode_groups.cc.o
[ 18%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/util/hash.cc.o
[ 18%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/util/stringprintf.cc.o
[ 19%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/util/rune.cc.o
[ 20%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/util/strutil.cc.o
[ 20%] Building CXX object openalpr/support/CMakeFiles/support.dir/re2/util/valgrind.cc.o
[ 21%] Linking CXX static library libsupport.a
[ 21%] Built target support
Scanning dependencies of target video
[ 22%] Building CXX object video/CMakeFiles/video.dir/videobuffer.cpp.o
[ 23%] Linking CXX static library libvideo.a
[ 23%] Built target video
Scanning dependencies of target openalpr
[ 24%] Building CXX object openalpr/CMakeFiles/openalpr.dir/alpr.cpp.o
[ 24%] Building CXX object openalpr/CMakeFiles/openalpr.dir/alpr_impl.cpp.o
[ 25%] Building CXX object openalpr/CMakeFiles/openalpr.dir/alpr_c.cpp.o
[ 26%] Building CXX object openalpr/CMakeFiles/openalpr.dir/config.cpp.o
[ 26%] Building CXX object openalpr/CMakeFiles/openalpr.dir/config_helper.cpp.o
[ 27%] Building CXX object openalpr/CMakeFiles/openalpr.dir/detection/detector.cpp.o
[ 28%] Building CXX object openalpr/CMakeFiles/openalpr.dir/detection/detectorcpu.cpp.o
[ 28%] Building CXX object openalpr/CMakeFiles/openalpr.dir/detection/detectorcuda.cpp.o
[ 29%] Building CXX object openalpr/CMakeFiles/openalpr.dir/detection/detectorocl.cpp.o
[ 30%] Building CXX object openalpr/CMakeFiles/openalpr.dir/detection/detectorfactory.cpp.o
[ 30%] Building CXX object openalpr/CMakeFiles/openalpr.dir/detection/detectormorph.cpp.o
[ 31%] Building CXX object openalpr/CMakeFiles/openalpr.dir/detection/detectormask.cpp.o
[ 32%] Building CXX object openalpr/CMakeFiles/openalpr.dir/licenseplatecandidate.cpp.o
[ 32%] Building CXX object openalpr/CMakeFiles/openalpr.dir/utility.cpp.o
/usr/local/src/openalpr/openalpr/src/openalpr/utility.cpp: In function 'cv::Mat alpr::addLabel(cv::Mat, std::__cxx11::string)':
/usr/local/src/openalpr/openalpr/src/openalpr/utility.cpp:89:73: error: 'FILLED' was not declared in this scope
rectangle(newImage, Point(0,0), Point(input.cols, extraHeight), bg, FILLED);
/usr/local/src/openalpr/openalpr/src/openalpr/utility.cpp: In function 'float alpr::getContourAreaPercentInsideMask(cv::Mat, std::vector<std::vector<cv::Point_<int> > >, std::vector<cv::Vec<int, 4> >, int)':
/usr/local/src/openalpr/openalpr/src/openalpr/utility.cpp:568:18: error: 'FILLED' was not declared in this scope
FILLED,
openalpr/CMakeFiles/openalpr.dir/build.make:374: recipe for target 'openalpr/CMakeFiles/openalpr.dir/utility.cpp.o' failed
make[2]: *** [openalpr/CMakeFiles/openalpr.dir/utility.cpp.o] Error 1
CMakeFiles/Makefile2:623: recipe for target 'openalpr/CMakeFiles/openalpr.dir/all' failed
make[1]: *** [openalpr/CMakeFiles/openalpr.dir/all] Error 2
Makefile:149: recipe for target 'all' failed
make: *** [all] Error 2
[ 23%] Building CXX object openalpr/CMakeFiles/openalpr.dir/utility.cpp.o
FILLED,
* Fin de l'installation *
ca donne ca…
Merci encore de tes réponses… !
