Moes UFO-R11
Suite à l’article parue sur domadoo (Contrôlez vos équipements IR en Zigbee avec Jeedom !) j’ai acheté le Moes UFO-R11 croyant qu’il allait marcher directement sur jeedom je n’avais pas vu que le plugin utilisé dans l’article était JeeZigbee et non celui que j’ai le plugin Zigbee.
seriez vous comment je dois procéder pour le faire focntionner sur le plugin Zigbee ?
information Brute :
    "ieee": "18:7a:3e:ff:fe:2f:1a:e5",
    "nwk": 43778,
    "status": 2,
    "lqi": "168",
    "rssi": "-58",
    "last_seen": "1691577785.236873",
    "node_descriptor": "02:40:80:02:10:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 61440,
            "profile_id": 260,
            "manufacturer": "_TZ3290_ot6ewjvmejq5ekhl",
            "model": "TS1201",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 67
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZ3290_ot6ewjvmejq5ekhl"
                            "id": 5,
                            "name": "model",
                            "value": "TS1201"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 3
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 1,
                    "name": "Power Configuration",
                    "attributes": []
                    "id": 60672,
                    "name": "Cluster",
                    "attributes": []
                    "id": 57348,
                    "name": "Cluster",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
    "signature": {
        "model": "TS1201",
        "node_desc": {
            "logical_type": 2,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 128,
            "manufacturer_code": 4098,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 82,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 82,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "input_clusters": [
                    0,
                    4,
                    5,
                    3,
                    1,
                    60672,
                    57348,
                    6
                    25,
                    10
    "class": "zigpy.device"
reconnu sur zigbeemqtt : Moes UFO-R11 control via MQTT | Zigbee2MQTT
Par avance merci à vous
Alors le plugin zigbee n’est plus maintenu et il est remplacé par jeezigbee.
Donc si tu veux utiliser cette télécommande et de futurs appareils zigbee, il te faut penser à transférer ton installation vers jeezigbee ou un autre plugin zigbee compatible avec ta clé.
@Tonio16 Ouaaa merci pour cette info assée cruciale, je vais prévoir la bascule
merci
