le plugin modbus rtu ne remonte pas l’info de mon équipement depuis le 12/11.
La partie modbus fonctione bien avec d’autres applis
jeedom 4.2.5
RPPI 3B buster
voici les logs
[2021-11-18 17:30:50][DEBUG] : Handling RTU for PAC
[2021-11-18 17:30:50][DEBUG] : Handling local request read for PAC
[2021-11-18 17:30:50][DEBUG] : Command to execute sudo /usr/bin/python /var/www/html/plugins/modbusrtu/resources/modbusrtud/modbus_rtu.py --slave 1 --device auto --baud 9600 --byte 8 --parity none --stop 1 --register '{"listdevice":[{"datatype": "normal", "decimal": 0, "signed": "0", "nbregister": "", "functioncode": "", "location": "9", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "111,2", "tohex": "0"}, {"datatype": "normal", "decimal": 0, "signed": "0", "nbregister": "", "functioncode": "", "location": "61", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "71,2", "tohex": "0"}, {"datatype": "normal", "decimal": 0, "signed": "0", "nbregister": "", "functioncode": "", "location": "120", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "77,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "115,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "113,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "20,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "36,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "37,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "38,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "39,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "21,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "22,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "23,2", "tohex": "0"}, {"datatype": "normal", "decimal": "1", "signed": "0", "nbregister": "", "functioncode": "", "location": "125", "tohex": "0"}]}' --action read
[2021-11-18 17:30:51][DEBUG] :
[2021-11-18 17:30:51][DEBUG] : No JSON object could be decoded
[2021-11-18 17:30:55][DEBUG] : Handling RTU for PAC
[2021-11-18 17:30:55][DEBUG] : Handling local request read for PAC
[2021-11-18 17:30:55][DEBUG] : Command to execute sudo /usr/bin/python /var/www/html/plugins/modbusrtu/resources/modbusrtud/modbus_rtu.py --slave 1 --device auto --baud 9600 --byte 8 --parity none --stop 1 --register '{"listdevice":[{"datatype": "normal", "decimal": 0, "signed": "0", "nbregister": "", "functioncode": "", "location": "9", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "111,2", "tohex": "0"}, {"datatype": "normal", "decimal": 0, "signed": "0", "nbregister": "", "functioncode": "", "location": "61", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "71,2", "tohex": "0"}, {"datatype": "normal", "decimal": 0, "signed": "0", "nbregister": "", "functioncode": "", "location": "120", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "77,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "115,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "113,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "20,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "36,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "37,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "38,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "39,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "21,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "22,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "23,2", "tohex": "0"}, {"datatype": "normal", "decimal": "1", "signed": "0", "nbregister": "", "functioncode": "", "location": "125", "tohex": "0"}]}' --action read
[2021-11-18 17:30:56][DEBUG] :
[2021-11-18 17:30:56][DEBUG] : No JSON object could be decoded
[2021-11-18 17:31:00][DEBUG] : Handling RTU for PAC
[2021-11-18 17:31:00][DEBUG] : Handling local request read for PAC
[2021-11-18 17:31:00][DEBUG] : Command to execute sudo /usr/bin/python /var/www/html/plugins/modbusrtu/resources/modbusrtud/modbus_rtu.py --slave 1 --device auto --baud 9600 --byte 8 --parity none --stop 1 --register '{"listdevice":[{"datatype": "normal", "decimal": 0, "signed": "0", "nbregister": "", "functioncode": "", "location": "9", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "111,2", "tohex": "0"}, {"datatype": "normal", "decimal": 0, "signed": "0", "nbregister": "", "functioncode": "", "location": "61", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "71,2", "tohex": "0"}, {"datatype": "normal", "decimal": 0, "signed": "0", "nbregister": "", "functioncode": "", "location": "120", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "77,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "115,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "113,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "20,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "36,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "37,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "38,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "39,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "21,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "22,2", "tohex": "0"}, {"datatype": "normal", "decimal": "2", "signed": "0", "nbregister": "", "functioncode": "", "location": "23,2", "tohex": "0"}, {"datatype": "normal", "decimal": "1", "signed": "0", "nbregister": "", "functioncode": "", "location": "125", "tohex": "0"}]}' --action read
[2021-11-18 17:31:01][DEBUG] :
[2021-11-18 17:31:01][DEBUG] : No JSON object could be decoded
merci
