J’ai mis à jour le plug in openzwave et relancé l’installation des dépendances mais ca bloque. Ca fait 15 minutes que ca tourne et j’ai toujours ceci dans les logs et ca n’avance plus…
Merci pour votre aide
Lancement de l'installation/mise à jour des dépendances openzwave
Get:1 http://security.debian.org stretch/updates InRelease [53.0 kB]
Ign:4 http://ftp.debian.org/debian stretch InRelease
Get:5 http://ftp.debian.org/debian stretch-updates InRelease [93.6 kB]
Hit:6 https://deb.nodesource.com/node_12.x stretch InRelease
Get:7 http://ftp.debian.org/debian stretch-backports InRelease [91.8 kB]
Get:8 http://ftp.debian.org/debian stretch-proposed-updates InRelease [96.3 kB]
Hit:3 https://www.deb-multimedia.org stretch InRelease
Hit:9 http://ftp.debian.org/debian stretch Release
Get:10 http://security.debian.org stretch/updates/main Sources [243 kB]
Get:11 https://oph.mdrjr.net/meveric all InRelease [19.4 kB]
Get:12 http://security.debian.org stretch/updates/main arm64 Packages [545 kB]
Get:13 http://security.debian.org stretch/updates/main Translation-en [253 kB]
Hit:14 https://oph.mdrjr.net/meveric stretch InRelease
Get:16 https://oph.mdrjr.net/meveric all/c2 arm64 Packages [6906 B]
Ign:2 https://repo.jeedom.com/odroid stable InRelease
Get:17 https://repo.jeedom.com/odroid stable Release [932 B]
Get:18 https://repo.jeedom.com/odroid stable Release.gpg [659 B]
Fetched 1403 kB in 5s (243 kB/s)
Reading package lists...
Installation des dependances
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.3).
g++ is already the newest version (4:6.3.0-4).
gcc is already the newest version (4:6.3.0-4).
git is already the newest version (1:2.11.0-3+deb9u7).
python-louie is already the newest version (1.1-2.1).
python-lxml is already the newest version (3.7.1-1).
make is already the newest version (4.1-9.1).
python-serial is already the newest version (3.2.1-1).
python-dev is already the newest version (2.7.13-2).
python-pip is already the newest version (9.0.1-2+deb9u1).
python-setuptools is already the newest version (33.1.1-1).
python-pyudev is already the newest version (0.21.0-1).
python-requests is already the newest version (2.12.4-1).
libudev-dev is already the newest version (232-25+deb9u12).
unzip is already the newest version (6.0-21+deb9u2).
The following packages were automatically installed and are no longer required:
pciutils python-lockfile
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libjpeg62-turbo libjpeg62-turbo-dev
The following packages will be upgraded:
libjpeg-dev libjpeg62-turbo libjpeg62-turbo-dev
3 upgraded, 0 newly installed, 0 to remove and 193 not upgraded.
26 not fully installed or removed.
Need to get 352 kB of archives.
After this operation, 3072 B of additional disk space will be used.
Get:1 http://security.debian.org stretch/updates/main arm64 libjpeg62-turbo-dev arm64 1:1.5.1-2+deb9u1 [184 kB]
Get:2 http://security.debian.org stretch/updates/main arm64 libjpeg62-turbo arm64 1:1.5.1-2+deb9u1 [112 kB]
Get:3 http://security.debian.org stretch/updates/main arm64 libjpeg-dev all 1:1.5.1-2+deb9u1 [56.5 kB]
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
Fetched 352 kB in 0s (3023 kB/s)
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 65281 files and directories currently installed.)
Preparing to unpack .../libjpeg62-turbo-dev_1%3a1.5.1-2+deb9u1_arm64.deb ...
Unpacking libjpeg62-turbo-dev:arm64 (1:1.5.1-2+deb9u1) over (1:1.5.1-2) ...
Preparing to unpack .../libjpeg62-turbo_1%3a1.5.1-2+deb9u1_arm64.deb ...
Unpacking libjpeg62-turbo:arm64 (1:1.5.1-2+deb9u1) over (1:1.5.1-2) ...
Preparing to unpack .../libjpeg-dev_1%3a1.5.1-2+deb9u1_all.deb ...
Unpacking libjpeg-dev (1:1.5.1-2+deb9u1) over (1:1.5.1-2) ...
Setting up libsnmp30:arm64 (5.7.3+dfsg-1.7+deb9u3) ...
Setting up libjpeg62-turbo:arm64 (1:1.5.1-2+deb9u1) ...
Setting up snmp (5.7.3+dfsg-1.7+deb9u3) ...
Processing triggers for libc-bin (2.24-11+deb9u3) ...
Processing triggers for systemd (232-25+deb9u2) ...
Processing triggers for man-db (2.7.6.1-2) ...
Setting up libjpeg62-turbo-dev:arm64 (1:1.5.1-2+deb9u1) ...
Setting up php7.0-common (7.0.33-0+deb9u9) ...
Setting up php7.0-snmp (7.0.33-0+deb9u9) ...
Setting up php7.0-xml (7.0.33-0+deb9u9) ...
Setting up php7.0-intl (7.0.33-0+deb9u9) ...
Setting up php7.0-soap (7.0.33-0+deb9u9) ...
Setting up php7.0-mysql (7.0.33-0+deb9u9) ...
Setting up php7.0-gmp (7.0.33-0+deb9u9) ...
Setting up php7.0-ldap (7.0.33-0+deb9u9) ...
Setting up php7.0-readline (7.0.33-0+deb9u9) ...
Setting up php7.0-opcache (7.0.33-0+deb9u9) ...
Setting up php7.0-mbstring (7.0.33-0+deb9u9) ...
Setting up php7.0-gd (7.0.33-0+deb9u9) ...
Setting up php7.0-mcrypt (7.0.33-0+deb9u9) ...
Setting up php7.0-curl (7.0.33-0+deb9u9) ...
Setting up php7.0-zip (7.0.33-0+deb9u9) ...
Setting up php7.0-xmlrpc (7.0.33-0+deb9u9) ...
Setting up php-ldap (1:7.0+49) ...
Setting up libjpeg-dev (1:1.5.1-2+deb9u1) ...
Setting up php7.0-sqlite3 (7.0.33-0+deb9u9) ...
Setting up php7.0-imap (7.0.33-0+deb9u9) ...
Setting up php7.0-json (7.0.33-0+deb9u9) ...
Setting up php7.0-cli (7.0.33-0+deb9u9) ...
Modified configuration file
A new version (/usr/lib/php/7.0/php.ini-production.cli) of configuration file
/etc/php/7.0/cli/php.ini is available, but the version installed currently has
been locally modified.
1. install the package maintainer's version
2. keep the local version currently installed
3. show the differences between the versions
4. show a side-by-side difference between the versions
5. start a new shell to examine the situation
What do you want to do about modified configuration file php.ini?
il n’y avait pas d’intérêt
