Je sais que ce n’est pas vraiment lié au plug in mais je rencontre un problème en voulant mettre a jour portainer sur proxmox…
Je ne comprends pas le problème il y a un problème de base de données mais je ne sais pas comment le regler
root@docker:~# docker logs 17cc73b9fb35
2024/05/04 08:46PM INF github.com/portainer/portainer/api/cmd/portainer/main.go:369 > encryption key file not present | filename=portainer
2024/05/04 08:46PM INF github.com/portainer/portainer/api/cmd/portainer/main.go:392 > proceeding without encryption key |
2024/05/04 08:46PM INF github.com/portainer/portainer/api/database/boltdb/db.go:125 > loading PortainerDB | filename=portainer.db
2024/05/04 08:46PM FTL github.com/portainer/portainer/api/cmd/portainer/main.go:403 > The database schema version does not align with the server version. Please consider reverting to the previous server version or addressing the database migration issue. |
2024/05/04 08:47PM FTL github.com/portainer/portainer/api/cmd/portainer/main.go:403 > The database schema version does not align with the server version. Please consider reverting to the previous server version or addressing the database migration issue. |
2024/05/04 08:47PM INF github.com/portainer/portainer/api/cmd/portainer/main.go:369 > encryption key file not present | filename=portainer
2024/05/04 08:47PM INF github.com/portainer/portainer/api/cmd/portainer/main.go:392 > proceeding without encryption key |
2024/05/04 08:47PM INF github.com/portainer/portainer/api/database/boltdb/db.go:125 > loading PortainerDB | filename=portainer.db
2024/05/04 08:48PM INF github.com/portainer/portainer/api/cmd/portainer/main.go:369 > encryption key file not present | filename=portainer
2024/05/04 08:48PM INF github.com/portainer/portainer/api/cmd/portainer/main.go:392 > proceeding without encryption key |
2024/05/04 08:48PM INF github.com/portainer/portainer/api/database/boltdb/db.go:125 > loading PortainerDB | filename=portainer.db
2024/05/04 08:48PM FTL github.com/portainer/portainer/api/cmd/portainer/main.go:403 > The database schema version does not align with the server version. Please consider reverting to the previous server version or addressing the database migration issue. |
J’ai fait ceci pour mettre a jour
docker stop portainer
docker rm portainer
docker pull portainer/portainer-ce:latest
docker run -d -p 8000:8000 -p 9443:9443 --name=portainer --restart=always -v /var/run/docker.sock:/var/run/docker.sock -v portainer_data:/data portainer/portainer-ce:latest
Quelqu’un peut il m’aider ? merci d’avance
