bonjour
depuis 2 jours, je ne peux plus mettre à jour les plugins
quand je clique sur le bouton général en haut à droite
ou sur la ligne des plugins, les plugins ne se mettent pas à jour
voici le log que j’ai quand je clique sur le bouton en haut à droite
Log :
[START UPDATE]
****Update from 4.3.15 (2023-02-17 16:46:47)****
Parameters : {"preUpdate":"0","backup::before":"1","plugins":"1","core":"1","force":"0","update::reapply":""}
Send begin of update event | OK
Check update | OK
Check rights | OK
[START BACKUP]
***************Start of Jeedom backup at 2023-02-17 16:46:49***************
Send begin backup event | OK
Checking files rights | OK
Checking database | OK
Backing up database | OK
Cache persistence: | OK
Creating archive | OK
Cleaning old backup | OK
Limiting backup size to 500 Mb
Delete: /var/www/html/core/php///backup/backup-Jeedom_VM_Synology-4.3.15-2023-02-13-01h44.tar.gz | OK
Backup name: /var/www/html/core/php///backup/backup-Jeedom_VM_Synology-4.3.15-2023-02-17-16h46.tar.gz
Send end backup event | OK
Backup operation duration: 65s
***************Jeedom backup end***************
[END BACKUP SUCCESS]
Download url : https://github.com/jeedom/core/archive/V4-stable.zip
Download in progress--2023-02-17 16:47:54-- https://github.com/jeedom/core/archive/V4-stable.zip
Resolving github.com (github.com) 140.82.121.3
Connecting to github.com (github.com)|140.82.121.3|:443 connected.
302 Found
Location: https://codeload.github.com/jeedom/core/zip/refs/heads/V4-stable [following]
--2023-02-17 16:47:55-- https://codeload.github.com/jeedom/core/zip/refs/heads/V4-stable
Resolving codeload.github.com (codeload.github.com) 140.82.121.9
Connecting to codeload.github.com (codeload.github.com)|140.82.121.9|:443 connected.
HTTP request sent, awaiting response 200 | OK
Length: 82249335 (78M) [application/zip]
Saving to: '/tmp/jeedom/install/jeedom_update.zip'
0K
3% 1.12M 67s
3072K
. 7% 1.08M 66s
6144K
11% 1.09M 63s
9216K
. 15% 1.14M 60s
12288K
. 19% 1.13M 57s
15360K
22% 1.15M 54s
18432K
26% 1.11M 51s
21504K
30% 1.15M 49s
24576K
34% 1.15M 46s
27648K
38% 1.16M 43s
30720K .
42% 1.15M 40s
33792K
45% 1.16M 37s
36864K
. 49% 1.16M 35s
39936K
53% 1.14M 32s
43008K
57% 1.19M 29s
46080K
61% 1.16M 27s
49152K .
65% 1.14M 24s
52224K
68% 1.16M 21s
55296K
. 72% 1.16M 19s
58368K
76% 1.16M 16s
61440K
80% 1.16M 13s
64512K
84% 1.16M 11s
67584K .
87% 1.15M 8s
70656K
91% 1.16M 6s
73728K
95% 1.16M 3s
76800K
99% 1.16M 0s
79872K
100% 1.17M=68s
2023-02-17 16:49:03 (1.15 MB/s) - '/tmp/jeedom/install/jeedom_update.zip' saved [82249335/82249335] | OK
Cleaning folders | OK
Create temporary folder | OK
Unzip in progress | OK
Clean temporary files (tmp) | OK
Disable all task | OK
Disable all scenario | OK
Moving filesIgnore file /tmp/jeedom_unzip/core-4-stable///docs/de_DE/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-4-stable///docs/en_US/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-4-stable///docs/es_ES/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-4-stable///docs/fr_FR/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-4-stable///docs/pt_PT/noteVersion.md because size is 0 | OK
Remove temporary files | OK
Remove useless files
Cleaning 3rdparty
Cleaning desktop
Cleaning mobile
Cleaning core
Cleaning docs
Cleaning install
Cleaning script
find: '/var/www/html/install//script/*': No such file or directory
Cleaning vendor
Check jeedom consistency
[START CONSISTENCY]
[START CHECK AND FIX DB]
[END CHECK AND FIX DB]
Check jeedom package | OK
Check jeedom database | OK
Check crons
Check filesystem right | OK
Flush cache widget
Check jeedom object | OK
Check jeedom cmd | OK
Set cache hour | OK
[END CONSISTENCY] | OK
Check update | OK
***************Jeedom is up to date in 4.3.15***************
***************Update plugins***************
***************Update plugin successfully***************
Check update | OK
Enable scenario : | OK
Enable task : | OK
Launch cron dependancy plugins | OK
Send end of update event | OK
Update duration : 159s
[END UPDATE SUCCESS]
la dernière modification que j’ai faite, c’est le changement du répertoire des sauvegardes jeedom (voir mon post de ce jour) à un moment çà bloquait car il voulait sauvegarder mais il ne trouvait pas le bon répertoire, mais maintenant c’est bon normalement, je pense avoir remis le répertoire par défaut
