Mise à jour des dépendances Z2M version 2.1.2 en erreur
Idem de mon coté pour l’installation de la version 2.1.2 sur un jeedom 4.4.19 en debian 11.11
Comment fait on repasser en 2.1.1 sans tout réinstaller ?
Merci de votre aide.
Mathieu
Log de l installation des dépendances :
[2025-03-02 09:35:25] INFO  : ##### Synchronisation du temps avant l'installation des dépendances...
[2025-03-02 09:35:33] INFO  : ##### Synchronisation du temps terminée, lancement des dépendances.
#    INSTALL : Zigbee2mqtt                            #
##### apt-get update in progress
Hit:1 http://deb.debian.org/debian bullseye InRelease
Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
Reading package lists...
##### Install or update Git
Building dependency tree...
Reading state information...
g++ is already the newest version (4:10.2.1-1).
gcc is already the newest version (4:10.2.1-1).
make is already the newest version (4.3-4.1).
git is already the newest version (1:2.30.2-1+deb11u4).
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
##### Install or update NodeJs
NodeJs 20 already installed : Nothing to do !
pnpm install version 9.15.6
changed 1 package in 1s
1 package is looking for funding
run `npm fund` for details
#    INSTALLING : Mosquitto for Php                   #
Mosquitto for Php is already installed, nothing to do
##### Z2M BRANCH version to install : master
##### Install Socat
Socat is already installed, nothing to do
##### Install yaml php and restart apache
Yaml is already installed, nothing to do
#####    Stopping Zigbee2mqtt deamon                  #
## Supprime l'installation dans /opt/zigbee2mqtt
##### Complete installation : Download Zigbee2mqtt git
Cloning into '/opt/zigbee2mqtt'...
##### Install/Update Zigbee2mqtt
Lockfile is up to date, resolution step is skipped
Progress: resolved 1, reused 0, downloaded 0, added 0
Packages: +363
Progress: resolved 363, reused 363, downloaded 0, added 51
Progress: resolved 363, reused 363, downloaded 0, added 363, done
.../node_modules/sd-notify install$ node-gyp rebuild
.../node_modules/sd-notify install: gyp info it worked if it ends with ok
.../node_modules/sd-notify install: gyp info using node-gyp@10.2.0
.../node_modules/sd-notify install: gyp info using node@20.18.3 | linux | x64
.../node_modules/sd-notify install: gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
.../node_modules/sd-notify install: gyp http GET https://nodejs.org/download/release/v20.18.3/node-v20.18.3-headers.tar.gz
.../node_modules/sd-notify install: gyp http 200 https://nodejs.org/download/release/v20.18.3/node-v20.18.3-headers.tar.gz
.../node_modules/sd-notify install: gyp http GET https://nodejs.org/download/release/v20.18.3/SHASUMS256.txt
.../node_modules/sd-notify install: gyp http 200 https://nodejs.org/download/release/v20.18.3/SHASUMS256.txt
.../node_modules/sd-notify install: gyp info spawn /usr/bin/python3
.../node_modules/sd-notify install: gyp info spawn args [
.../node_modules/sd-notify install: gyp info spawn args '/usr/lib/node_modules/pnpm/dist/node_modules/node-gyp/gyp/gyp_main.py',
.../node_modules/sd-notify install: gyp info spawn args 'binding.gyp',
.../node_modules/sd-notify install: gyp info spawn args '-f',
.../node_modules/sd-notify install: gyp info spawn args 'make',
.../node_modules/sd-notify install: gyp info spawn args '-I',
.../node_modules/sd-notify install: gyp info spawn args '/opt/zigbee2mqtt/node_modules/.pnpm/sd-notify@2.8.0/node_modules/sd-notify/build/config.gypi',
.../node_modules/sd-notify install: gyp info spawn args '/usr/lib/node_modules/pnpm/dist/node_modules/node-gyp/addon.gypi',
.../node_modules/sd-notify install: gyp info spawn args '/root/.cache/node-gyp/20.18.3/include/node/common.gypi',
.../node_modules/sd-notify install: gyp info spawn args '-Dlibrary=shared_library',
.../node_modules/sd-notify install: gyp info spawn args '-Dvisibility=default',
.../node_modules/sd-notify install: gyp info spawn args '-Dnode_root_dir=/root/.cache/node-gyp/20.18.3',
.../node_modules/sd-notify install: gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/pnpm/dist/node_modules/node-gyp',
.../node_modules/sd-notify install: gyp info spawn args '-Dnode_lib_file=/root/.cache/node-gyp/20.18.3/<(target_arch)/node.lib',
.../node_modules/sd-notify install: gyp info spawn args '-Dmodule_root_dir=/opt/zigbee2mqtt/node_modules/.pnpm/sd-notify@2.8.0/node_modules/sd-notify',
.../node_modules/sd-notify install: gyp info spawn args '-Dnode_engine=v8',
.../node_modules/sd-notify install: gyp info spawn args '--depth=.',
.../node_modules/sd-notify install: gyp info spawn args '--no-parallel',
.../node_modules/sd-notify install: gyp info spawn args '--generator-output',
.../node_modules/sd-notify install: gyp info spawn args 'build',
.../node_modules/sd-notify install: gyp info spawn args '-Goutput_dir=.'
.../node_modules/sd-notify install: gyp info spawn args ]
.../node_modules/sd-notify install: gyp info spawn make
.../node_modules/sd-notify install: gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
.../node_modules/sd-notify install: make: Entering directory '/opt/zigbee2mqtt/node_modules/.pnpm/sd-notify@2.8.0/node_modules/sd-notify/build'
.../node_modules/sd-notify install:   CXX(target) Release/obj.target/notify/notify.o
.../node_modules/sd-notify install: ../notify.cc:5:10: fatal error: systemd/sd-daemon.h: No such file or directory
.../node_modules/sd-notify install:     5 | #include <systemd/sd-daemon.h>
.../node_modules/sd-notify install:       |          ^~~~~~~~~~~~~~~~~~~~~
.../node_modules/sd-notify install: compilation terminated.
.../node_modules/sd-notify install: make: *** [notify.target.mk:106: Release/obj.target/notify/notify.o] Error 1
.../node_modules/sd-notify install: make: Leaving directory '/opt/zigbee2mqtt/node_modules/.pnpm/sd-notify@2.8.0/node_modules/sd-notify/build'
.../node_modules/sd-notify install: gyp ERR! build error
.../node_modules/sd-notify install: gyp ERR! stack Error: `make` failed with exit code: 2
.../node_modules/sd-notify install: gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/pnpm/dist/node_modules/node-gyp/lib/build.js:216:23)
.../node_modules/sd-notify install: gyp ERR! System Linux 5.10.0-27-amd64
.../node_modules/sd-notify install: gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/pnpm/dist/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
.../node_modules/sd-notify install: gyp ERR! cwd /opt/zigbee2mqtt/node_modules/.pnpm/sd-notify@2.8.0/node_modules/sd-notify
.../node_modules/sd-notify install: gyp ERR! node -v v20.18.3
.../node_modules/sd-notify install: gyp ERR! node-gyp -v v10.2.0
.../node_modules/sd-notify install: gyp ERR! not ok
.../node_modules/sd-notify install: Failed
dependencies:
+ ajv 8.17.1
+ bind-decorator 1.0.11
+ debounce 2.2.0
+ express-static-gzip 2.2.0
+ fast-deep-equal 3.1.3
+ finalhandler 1.3.1
+ git-last-commit 1.0.1
+ humanize-duration 3.32.1
+ js-yaml 4.1.0
+ json-stable-stringify-without-jsonify 1.0.1
+ jszip 3.10.1
+ moment 2.30.1
+ mqtt 5.10.3
+ object-assign-deep 0.4.0
+ rimraf 6.0.1
+ semver 7.7.1
+ source-map-support 0.5.21
+ throttleit 2.1.0
+ winston 3.17.0
+ winston-syslog 2.7.1
+ winston-transport 4.9.0
+ ws 8.18.1
+ zigbee-herdsman 3.2.7
+ zigbee-herdsman-converters 23.2.0
+ zigbee2mqtt-frontend 0.9.4
optionalDependencies:
+ sd-notify 2.8.0
devDependencies:
+ @eslint/core 0.12.0
+ @eslint/js 9.21.0
+ @ianvs/prettier-plugin-sort-imports 4.4.1
+ @types/finalhandler 1.2.3
+ @types/humanize-duration 3.27.4
+ @types/js-yaml 4.0.9
+ @types/node 22.13.5
+ @types/object-assign-deep 0.4.3
+ @types/readable-stream 4.0.18
+ @types/sd-notify 2.8.2
+ @types/serve-static 1.15.7
+ @types/ws 8.5.14
+ @vitest/coverage-v8 3.0.7
+ eslint 9.21.0
+ eslint-config-prettier 10.0.1
+ prettier 3.5.2
+ tmp 0.2.3
+ typescript 5.7.3
+ typescript-eslint 8.25.0
+ vitest 3.0.7
Done in 4.9s using pnpm v9.15.6
zigbee2mqtt@2.1.3 build /opt/zigbee2mqtt
tsc && node index.js writehash
>##### Configure deamon and start it
#                         END                         #
