J’ai un soucis avec ma jeedom Luna.
je n’arrive pas à faire la mise à jour core.
Je suis en 4.3.17 et j’essai de mettre à jour vers la 4.3.21 mais cela ne fonctionne pas.
J’ai essayé les classiques « redémarrage » et « vidage de cache » mais toujours bloqué.
si quelqu’un a une idée, je suis preneur
ci-dessous le log de la tentative de mise à jour :
[START UPDATE]
****Update from 4.3.17 (2024-01-04 14:01:25)****
Parameters : {"preUpdate":"1","backup::before":"1","plugins":"1","core":"1","force":"0","update::reapply":""}
Send begin of update event | OK
Check update | OK
Check rights | OK
[START BACKUP]
***************Start of Jeedom backup at 2024-01-04 14:01:47***************
Send begin backup event | OK
Checking files rights | OK
Checking database | OK
Backing up database | OK
Cache persistence: | OK
Creating archive | OK
Cleaning old backup | OK
Limiting backup size to 500 Mb
Delete: /var/www/html/core/php///backup/backup-Corrençon-4.3.17-2024-01-04-03h27.tar.gz | OK
Backup name: /var/www/html/core/php///backup/backup-Corrençon-4.3.17-2024-01-04-14h01.tar.gz
Send end backup event | OK
Backup operation duration: 87s
***************Jeedom backup end***************
[END BACKUP SUCCESS]
Download url : https://github.com/jeedom/core/archive/V4-stable.zip
Download in progress--2024-01-04 13:03:15-- https://github.com/jeedom/core/archive/V4-stable.zip
Resolving github.com (github.com) 140.82.121.4
Connecting to github.com (github.com)|140.82.121.4|:443 connected.
HTTP request sent, awaiting response
302 Found
Location: https://codeload.github.com/jeedom/core/zip/refs/heads/V4-stable [following]
--2024-01-04 13:03:15-- https://codeload.github.com/jeedom/core/zip/refs/heads/V4-stable
Resolving codeload.github.com (codeload.github.com) 140.82.121.10
Connecting to codeload.github.com (codeload.github.com)|140.82.121.10|:443 connected.
HTTP request sent, awaiting response 200 | OK
Length: 82253287 (78M) [application/zip]
Saving to: '/tmp/jeedom/install/jeedom_update.zip'
0K
3% 1.84M 41s
3072K
7% 5.11M 27s
6144K
11% 3.65M 23s
9216K 15% 5.21M 20s
12288K
19% 5.05M 18s
15360K 22% 6.37M 16s
18432K
26% 4.14M 15s
21504K 30% 3.68M 14s
24576K
34% 5.33M 13s
27648K 38% 5.39M 12s
30720K
42% 4.10M 11s
33792K
45% 4.89M 10s
36864K 49% 6.07M 9s
39936K
53% 5.15M 8s
43008K 57% 3.46M 8s
46080K
61% 5.20M 7s
49152K 65% 4.17M 6s
52224K
68% 5.28M 6s
55296K 72% 6.51M 5s
58368K .
76% 5.38M 4s
61440K 80% 5.34M 3s
64512K
. 84% 6.61M 3s
67584K
87% 1.90M 2s
70656K
91% 5.19M 1s
73728K 95% 6.55M 1s
76800K 99% 5.39M 0s
79872K .
100% 6.28M=18s
2024-01-04 13:03:34 (4.41 MB/s) - '/tmp/jeedom/install/jeedom_update.zip' saved [82253287/82253287] | OK
Cleaning foldersrm: cannot remove '/tmp/jeedom_unzip/core-4-stable/core/img/pluginBands': Structure needs cleaning
rm: cannot remove '/tmp/jeedom_unzip/core-4-stable/core/img/pluginBands': Structure needs cleaning | OK
Create temporary folder | OK
Unzip in progress
Error during update : Can not unzip fileDetails : Array
[END UPDATE ERROR]
PHP Fatal error: Uncaught Exception: Can not unzip file in /var/www/html/install/update.php:160
Stack trace:
#0 {main}
thrown in /var/www/html/install/update.php on line 160
