En étant déconnecté de Jeedom j’ai réussi à déclencher cette erreur coté zigbee2mqtt
info 2025-01-12 22:40:06z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa49e69fffec16bf6', payload '{"device":{"applicationVersion":3,"dateCode":"2021","friendlyName":"0xa49e69fffec16bf6","hardwareVersion":20,"ieeeAddr":"0xa49e69fffec16bf6","manufacturerID":4727,"manufacturerName":"Adeo","model":"SIN-4-FP-21_EQU","networkAddress":51888,"powerSource":"Mains (single phase)","stackVersion":103,"type":"Router","zclVersion":8},"energy":410.77,"last_seen":"2025-01-12T21:39:50.795Z","linkquality":255,"pilot_wire_mode":"off","power":0,"state":"ON","update":{"installed_version":66562,"latest_version":66562,"state":"idle"},"update_available":false}'
error 2025-01-12 22:40:28z2m: Publish 'set' 'pilot_wire_mode' to '0xa49e69fffec16bf6' failed: 'Error: ZCL command 0xa49e69fffec16bf6/1 manuSpecificNodOnPilotWire.setMode({"mode":2}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"manufacturerCode":4747,"writeUndiv":false}) failed (no response received (12) Error: waiting for response TIMEOUT)'
info 2025-01-12 22:40:28z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"Publish 'set' 'pilot_wire_mode' to '0xa49e69fffec16bf6' failed: 'Error: ZCL command 0xa49e69fffec16bf6/1 manuSpecificNodOnPilotWire.setMode({\"mode\":2}, {\"timeout\":10000,\"disableResponse\":false,\"disableRecovery\":false,\"disableDefaultResponse\":false,\"direction\":0,\"reservedBits\":0,\"manufacturerCode\":4747,\"writeUndiv\":false}) failed (no response received (12) Error: waiting for response TIMEOUT)'","meta":{"friendly_name":"0xa49e69fffec16bf6"},"type":"zigbee_publish_error"}'
Je rappel que cette erreur n’apparait pas lorsque la commande est lancée manuellement.
