Bonjour à tous
J’utilise cet excellent plugin depuis un moment mais je n’arrive pas à me débarrasser d’une alerte qui semble récurrent :
Tous les jours : 2x à la même heure 19h32
2023-08-21 19:32:59 stockexchange incorrect data received:{"Note":"Thank you for using Alpha Vantage! Our standard API call frequency is 5 calls per minute and 100 calls per day. Please visit https:\/\/www.alphavantage.co\/premium\/ if you would like to target a higher API call frequency."} 2
0000|[2023-08-20 19:31:55]ERROR : incorrect data received:{"Note":"Thank you for using Alpha Vantage! Our standard API call frequency is 5 calls per minute and 100 calls per day. Please visit https:\/\/www.alphavantage.co\/premium\/ if you would like to target a higher API call frequency."}
0001|[2023-08-20 19:32:58]ERROR : incorrect data received:{"Note":"Thank you for using Alpha Vantage! Our standard API call frequency is 5 calls per minute and 100 calls per day. Please visit https:\/\/www.alphavantage.co\/premium\/ if you would like to target a higher API call frequency."}
0002|[2023-08-21 19:31:57]ERROR : incorrect data received:{"Note":"Thank you for using Alpha Vantage! Our standard API call frequency is 5 calls per minute and 100 calls per day. Please visit https:\/\/www.alphavantage.co\/premium\/ if you would like to target a higher API call frequency."}
0003|[2023-08-21 19:32:59]ERROR : incorrect data received:{"Note":"Thank you for using Alpha Vantage! Our standard API call frequency is 5 calls per minute and 100 calls per day. Please visit https:\/\/www.alphavantage.co\/premium\/ if you would like to target a higher API call frequency."}
j’ai 20 équipements et j’utilise 2 ID différents de Alpha Vantage.
la synchro est configurée différemment pour chaque équipement, avec un décalage de 10mn entre chaque équipement du même ID.
0 18 * * 1-5
10 18 * * 1-5
20 18 * * 1-5
l’équipement qui se synchronisait à 19h30, je l’ai décalé à 19h50, je n’ai donc pas de synchro entre 19h20 et 19h40
mais j’ai toujours l’alerte
je viens de passer le plugin en mode debug voir il donne plus d’info.
si vous avez une idée du prb.
