Message d'erreurs depuis maj du 26/1
Depuis cette mise à jour, j’ai une douzaine de messages par jour du genre:
	2024-01-31 12:16:06	Monitoring	[GetInfos] Exception Trace :: [{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4015,"function":"get_binary_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[true]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":2949,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1,false]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":2818,"function":"openChannel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/core\/class\/Monitoring.class.php","line":744,"function":"exec","class":"phpseclib3\\Net\\SSH2","type":"->","args":["lscpu 2>\/dev\/null | grep Architecture | awk '{ print $2 }'"]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/core\/class\/Monitoring.class.php","line":47,"function":"getInformations","class":"Monitoring","type":"->","args":[]},{"file":"\/var\/www\/html\/core\/php\/jeeCron.php","line":78,"function":"pull","class":"Monitoring","type":"::","args":[]}]
Je ne sais pas à quel équipement ça correspond.
Comment supprimer ces messages
Config :
Jeedom 4.3.22 sur RPI4 Bulleyes
Merci pour votre aide.
Ce qui est sûr, ce que s’il affiche des traces, c’est que quelque chose se passe mal et le plugin te le fait savoir :stuck_out_tongue:
Pourrais tu mettre à minima quelques lignes au dessus de ce message d’erreur et quelques ligne en dessous stp ? que j’ai un peu plus de visu sur ce qui pourrait se passer ?
et préciser si tu es en stable ? beta ? et numéro de version (dispo sur la page de configuration du plugin :slight_smile:
TiTidom.
Merci pour ta réponse
Ci joint copie les messages reçus cet après midi
2024-01-31 17:33:09	blea	connexion SSH KO for picam1		161
2024-01-31 17:31:26	Monitoring	[GetInfos] Exception Trace :: [{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4015,"function":"get_binary_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[true]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":2949,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1,false]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":2818,"function":"openChannel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/core\/class\/Monitoring.class.php","line":744,"function":"exec","class":"phpseclib3\\Net\\SSH2","type":"->","args":["lscpu 2>\/dev\/null | grep Architecture | awk '{ print $2 }'"]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/core\/class\/Monitoring.class.php","line":47,"function":"getInformations","class":"Monitoring","type":"->","args":[]},{"file":"\/var\/www\/html\/core\/php\/jeeCron.php","line":78,"function":"pull","class":"Monitoring","type":"::","args":[]}]
2024-01-31 17:31:26	Monitoring	[GetInfos] Exception (Line 3516) :: No data received from server		4
2024-01-31 17:30:09	Monitoring	[SSH-Login] Authentification SSH :: Picam1 :: Error reading from socket		7
2024-01-31 17:29:16	Monitoring	[GetInfos] Exception Trace :: [{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":2949,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1,false]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":2818,"function":"openChannel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/core\/class\/Monitoring.class.php","line":746,"function":"exec","class":"phpseclib3\\Net\\SSH2","type":"->","args":["awk -F'=' '\/VERSION_ID\/ {print $2}' \/etc\/*-release 2>\/dev\/null | tr -d '\"'"]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/core\/class\/Monitoring.class.php","line":47,"function":"getInformations","class":"Monitoring","type":"->","args":[]},{"file":"\/var\/www\/html\/core\/php\/jeeCron.php","line":78,"function":"pull","class":"Monitoring","type":"::","args":[]}]
2024-01-31 17:29:16	Monitoring	[GetInfos] Exception (Line 4024) :: Connection closed by server		4
2024-01-31 17:26:58	Monitoring	[GetInfos] Exception Trace :: [{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":2949,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1,false]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":2818,"function":"openChannel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/core\/class\/Monitoring.class.php","line":860,"function":"exec","class":"phpseclib3\\Net\\SSH2","type":"->","args":["cat \/sys\/class\/thermal\/thermal_zone0\/temp 2>\/dev\/null"]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/core\/class\/Monitoring.class.php","line":47,"function":"getInformations","class":"Monitoring","type":"->","args":[]},{"file":"\/var\/www\/html\/core\/php\/jeeCron.php","line":78,"function":"pull","class":"Monitoring","type":"::","args":[]}]
2024-01-31 16:48:07	Monitoring	[GetInfos] Exception Trace :: [{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4015,"function":"get_binary_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[true]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":2949,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1,false]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":2818,"function":"openChannel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/core\/class\/Monitoring.class.php","line":746,"function":"exec","class":"phpseclib3\\Net\\SSH2","type":"->","args":["awk -F'=' '\/VERSION_ID\/ {print $2}' \/etc\/*-release 2>\/dev\/null | tr -d '\"'"]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/core\/class\/Monitoring.class.php","line":47,"function":"getInformations","class":"Monitoring","type":"->","args":[]},{"file":"\/var\/www\/html\/core\/php\/jeeCron.php","line":78,"function":"pull","class":"Monitoring","type":"::","args":[]}]
2024-01-31 16:39:18	Monitoring	[GetInfos] Exception Trace :: [{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":2949,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1,false]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":2818,"function":"openChannel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/core\/class\/Monitoring.class.php","line":860,"function":"exec","class":"phpseclib3\\Net\\SSH2","type":"->","args":["cat \/sys\/class\/thermal\/thermal_zone0\/temp 2>\/dev\/null"]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/core\/class\/Monitoring.class.php","line":47,"function":"getInformations","class":"Monitoring","type":"->","args":[]},{"file":"\/var\/www\/html\/core\/php\/jeeCron.php","line":78,"function":"pull","class":"Monitoring","type":"::","args":[]}]		2
2024-01-31 15:31:35	Monitoring	[GetInfos] Exception (Line 197) :: An integer was expected.
2024-01-31 15:31:35	Monitoring	[GetInfos] Exception Trace :: [{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":2855,"function":"packSSH2","class":"phpseclib3\\Common\\Functions\\Strings","type":"::","args":["CNsCs",98,null,"exec",1,"lscpu 2>\/dev\/null | grep Architecture | awk '{ print $2 }'"]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/core\/class\/Monitoring.class.php","line":744,"function":"exec","class":"phpseclib3\\Net\\SSH2","type":"->","args":["lscpu 2>\/dev\/null | grep Architecture | awk '{ print $2 }'"]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/core\/class\/Monitoring.class.php","line":47,"function":"getInformations","class":"Monitoring","type":"->","args":[]},{"file":"\/var\/www\/html\/core\/php\/jeeCron.php","line":78,"function":"pull","class":"Monitoring","type":"::","args":[]}]
2024-01-31 15:17:08	Monitoring	[GetInfos] Exception Trace :: [{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4015,"function":"get_binary_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[true]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":2949,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1,false]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":2818,"function":"openChannel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/core\/class\/Monitoring.class.php","line":744,"function":"exec","class":"phpseclib3\\Net\\SSH2","type":"->","args":["lscpu 2>\/dev\/null | grep Architecture | awk '{ print $2 }'"]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/core\/class\/Monitoring.class.php","line":47,"function":"getInformations","class":"Monitoring","type":"->","args":[]},{"file":"\/var\/www\/html\/core\/php\/jeeCron.php","line":78,"function":"pull","class":"Monitoring","type":"::","args":[]}]
2024-01-31 13:46:23	Monitoring	[GetInfos] Exception Trace :: [{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4015,"function":"get_binary_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[true]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4533,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":4018,"function":"close_channel","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/vendor\/phpseclib\/phpseclib\/phpseclib\/Net\/SSH2.php","line":2866,"function":"get_channel_packet","class":"phpseclib3\\Net\\SSH2","type":"->","args":[1]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/core\/class\/Monitoring.class.php","line":750,"function":"exec","class":"phpseclib3\\Net\\SSH2","type":"->","args":["cat \/proc\/net\/dev 2>\/dev\/null | grep eth0 | awk '{print $1,$2,$10}' | tr -d ':'"]},{"file":"\/var\/www\/html\/plugins\/Monitoring\/core\/class\/Monitoring.class.php","line":47,"function":"getInformations","class":"Monitoring","type":"->","args":[]},{"file":"\/var\/www\/html\/core\/php\/jeeCron.php","line":78,"function":"pull","class":"Monitoring","type":"::","args":[]}]
et copie de la page de config
Merci pour ces logs et copie d’écran.
Alors pour info, dans les dernières versions, j’ai ajouté des logs (et des traces que tu vois ici) pour aider à l’investigation si besoin.
Dans ton cas, le message important est celui-ci :
Et tout le reste en découle, il « explique » dans les traces le « pourquoi » (même si dans ce cas, cela parait simple).
Il faudrait regarder pourquoi ton device « Picam1 » n’est pas accessible au moment où le plugin essaie de le joindre.
TiTidom.
Merci de ta réactivité
Le Picam1 est planté, donc ok pour le message correspondant.
Par contre tout le détail des traces peut il être validé par une case à cocher dans la conf?
Le but serait de la valider uniquement quand on cherche des détails.
Re,
Ces traces ne sont affichées que lorsque le niveau de log du plugin est en debug. Si tu passes en niveau info par exemple, elles ne seront plus affichées. (C’est même conseillé de ne pas rester en niveau debug en temps normal, mais de n’y passer que lorsque tu as un soucis).
TiTidom.
EDIT : autant pour moi, il y a une coquille dans le code, les log « trace » sortent en « error » et pas en « debug », méa culpa :frowning: ce sera corrigé dans la version qui sortira cette nuit (en stable et en béta)
C’est corrigé en version béta (dispo dès maintenant) et ce sera disponible en stable demain matin.
Désolé pour cette coquille dans les logs :face_with_raised_eyebrow:
Bonne soirée,
TiTidom.
Merci pour ton efficacité
On attendra demain…
