Depuis quelque temps j’ai le message d’erreur suivant :
Erreur sur Diagral_eOne::pull() : Exception Object ( [message:protected] => sessionId is not in the response -- {"message":"OOM command not allowed when used memory > 'maxmemory'.; nested exception is redis.clients.jedis.exceptions.JedisDataException: OOM command not allowed when used memory > 'maxmemory'.","details":null} [string:Exception:private] => [code:protected] => 30 [file:protected] => /var/www/html/plugins/Diagral_eOne/3rparty/Diagral-eOne-API-PHP/class/Diagral/Diagral_eOne.class.php [line:protected] => 180 [trace:Exception:private] => Array ( [0] => Array ( [file] => /var/www/html/plugins/Diagral_eOne/core/class/Diagral_eOne.class.php [line] => 895 [function] => login [class] => Mguyard\Diagral\Diagral_eOne [type] => -> [args] => Array ( ) ) [1] => Array ( [file] => /var/www/html/plugins/Diagral_eOne/core/class/Diagral_eOne.class.php [line] => 929 [function] => setDiagralEnv [class] => Diagral_eOne [type] => -> [args] => Array ( ) ) [2] => Array ( [file] => /var/www/html/core/php/jeeCron.php [line] => 78 [function] => pull [class] => Diagral_eOne [type] => :: [args] => Array ( ) ) ) [previous:Exception:private] => )
Cordialement
