BOnjour,
J’ai ces message dans le log http.error pour le plugin thermostat alter view. Cela ne gène en rien le mode de fonctionnement.
0006|#0 /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php(437): thermoAlternateView::getLinkCalendar(NULL)
0007|#1 /var/www/html/plugins/thermoAlternateView/core/ajax/thermoAlternateView.ajax.php(31): thermoAlternateView::getNextEventCalendar(NULL, false)
0008|#2 {main}
0009|thrown in /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php on line 549, referer: https://mch.eu.jeedom.link/index.php?v=m&p=home
0010|[Sat Feb 19 23:00:04.891717 2022] [php7:error] [pid 11721] [client 88.127.233.5:0] PHP Fatal error: Uncaught Error: Call to a member function getCmd() on null in /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php:549
0011|Stack trace:
0012|#0 /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php(437): thermoAlternateView::getLinkCalendar(NULL)
0013|#1 /var/www/html/plugins/thermoAlternateView/core/ajax/thermoAlternateView.ajax.php(31): thermoAlternateView::getNextEventCalendar(NULL, false)
0014|#2 {main}
0015|thrown in /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php on line 549, referer: https://mch.eu.jeedom.link/index.php?v=m&p=home
0016|[Sun Feb 20 18:30:04.017902 2022] [php7:error] [pid 20524] [client 92.184.108.31:0] PHP Fatal error: Uncaught Error: Call to a member function getCmd() on null in /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php:549
0017|Stack trace:
0018|#0 /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php(437): thermoAlternateView::getLinkCalendar(NULL)
0019|#1 /var/www/html/plugins/thermoAlternateView/core/ajax/thermoAlternateView.ajax.php(31): thermoAlternateView::getNextEventCalendar(NULL, false)
0020|#2 {main}
0021|thrown in /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php on line 549, referer: https://mch.eu.jeedom.link/index.php?v=m&p=home
0022|[Sun Feb 20 18:30:04.756371 2022] [php7:error] [pid 20227] [client 92.184.108.31:0] PHP Fatal error: Uncaught Error: Call to a member function getCmd() on null in /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php:549
0023|Stack trace:
0024|#0 /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php(437): thermoAlternateView::getLinkCalendar(NULL)
0025|#1 /var/www/html/plugins/thermoAlternateView/core/ajax/thermoAlternateView.ajax.php(31): thermoAlternateView::getNextEventCalendar(NULL, false)
0026|#2 {main}
Problème toujours présent. Les calendrier sont bien lié pourtant.
0001|[Fri Apr 22 07:41:54.458445 2022] [php7:error] [pid 29398] [client xxxxxxxx] PHP Fatal error: Uncaught Error: Call to a member function getCmd() on null in /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php:549
0002|Stack trace:
0003|#0 /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php(437): thermoAlternateView::getLinkCalendar(NULL)
0004|#1 /var/www/html/plugins/thermoAlternateView/core/ajax/thermoAlternateView.ajax.php(31): thermoAlternateView::getNextEventCalendar(NULL, false)
0005|#2 {main}
0006|thrown in /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php on line 549, referer: https://xxxxxxx
0007|[Fri Apr 22 07:42:10.355655 2022] [php7:error] [pid 29395] [client xxxxxxx] PHP Fatal error: Uncaught Error: Call to a member function getCmd() on null in /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php:549
0008|Stack trace:
0009|#0 /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php(437): thermoAlternateView::getLinkCalendar(NULL)
0010|#1 /var/www/html/plugins/thermoAlternateView/core/ajax/thermoAlternateView.ajax.php(31): thermoAlternateView::getNextEventCalendar(NULL, false)
0011|#2 {main}
0012|thrown in /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php on line 549, referer: https://xxxxxx
0013|[Fri Apr 22 07:42:10.356164 2022] [php7:error] [pid 18360] [client xxxxxxxxxx] PHP Fatal error: Uncaught Error: Call to a member function getCmd() on null in /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php:549
0014|Stack trace:
0015|#0 /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php(437): thermoAlternateView::getLinkCalendar(NULL)
0016|#1 /var/www/html/plugins/thermoAlternateView/core/ajax/thermoAlternateView.ajax.php(31): thermoAlternateView::getNextEventCalendar(NULL, false)
0017|#2 {main}
0018|thrown in /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php on line 549, referer: https://xxxxxxxx
0019|[Fri Apr 22 07:42:15.048012 2022] [php7:error] [pid 29399] [client xxxxxxxx] PHP Fatal error: Uncaught Error: Call to a member function getCmd() on null in /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php:549
0020|Stack trace:
0021|#0 /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php(437): thermoAlternateView::getLinkCalendar(NULL)
0022|#1 /var/www/html/plugins/thermoAlternateView/core/ajax/thermoAlternateView.ajax.php(31): thermoAlternateView::getNextEventCalendar(NULL, false)
0023|#2 {main}
0024|thrown in /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php on line 549, referer: https://xxxxxxx
0025|[Fri Apr 22 07:42:15.048113 2022] [php7:error] [pid 18683] [client xxxxx] PHP Fatal error: Uncaught Error: Call to a member function getCmd() on null in /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php:549
0026|Stack trace:
0027|#0 /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php(437): thermoAlternateView::getLinkCalendar(NULL)
0028|#1 /var/www/html/plugins/thermoAlternateView/core/ajax/thermoAlternateView.ajax.php(31): thermoAlternateView::getNextEventCalendar(NULL, false)
0029|#2 {main}
0030|thrown in /var/www/html/plugins/thermoAlternateView/core/class/thermoAlternateView.class.php on line 549, referer: https://xxxxxxx
Tu peux essayer de remplacer le fichier plugins\thermoAlternateView\core\ajax\thermoAlternateView.ajax.php par celui que je te joint.
thermoAlternateView.ajax.php.txt (1,4 Ko)
(Bien penser à enlever l’extention .txt avant de faire le remplacement)
Merci superbricolo. Je n’ai plus le problème mais s’il revient j’appliquerais ta methode.
Tu reprends le plugin ?
