Je viens de m’apercevoir que j’ai un message d’erreur lors d’un changement de valeur de consigne sur la tuile:
API_Erreur at /api/setminormode : setpoint_endtime in past(21)
Pour info:
Jeedom version 4.3.11
Plugin MigoThermostat date du 20220928
les logs MigoThermostat:
0481|[2022-12-07 18:40:45]DEBUG : connectMigo Start...
0482|[2022-12-07 18:40:46]DEBUG : getClient Api access_token=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
0483|[2022-12-07 18:40:47]DEBUG : postSave started *****************
0484|[2022-12-07 18:40:47]DEBUG : syncFromWeb thermdata {"devices":[{"_id":"70:ee:50:65:9d:48","type":"NAVaillant","date_setup":{"sec":1601464386,"usec":313000},"house_model":{"hc_gefs":{"pivot_x":20,"pivot_y":20,"max_ext_temp":20,"min_flow_set_point":39.6,"base_external_temp":-7,"slope":13,"temp_shift":19.6,"max_flow_set_point":74.7},"in_use":"gefs","ca":{"te":2,"ti":1670432981,"so":"meteogroup"},"algo_type":"pid_algo","first_anticipate_avail":false,"gefs":{"lag_up":71,"tau":186001,"off_overshoot":0.8,"lag_down":10,"pk":40,"on_overshoot":0},"pid_algo":{"gain":123,"ti":20,"td":5,"period":10},"time_pid_computed":1669503360,"prediction_activated":true},"last_setup":1601464386,"admin_access_code":["xxxxxxxxxxxxxxxx"],"udp_conn":true,"boiler_oem_serial":"21195000100xxxxxxxxxxxxxxxxxxxxx","dhw":55,"firmware":1029,"oem_serial":"212016002xxxxxxxxxxxxxxxxxxxxx","dhw_max":60,"dhw_min":38,"hot_water_anticipating":false,"last_status_store":1670434807,"wifi_status":54,"home_id":"xxxxxxxxxxxxxxxxxxxxxx","migration_netcomv2_vaillant":true,"boiler_error":[],"boiler_id":"xxxxxxxxxxxxxxxxx","dhw_enabled":false,"ebus_error":false,"emf_avail":true,"station_name":"HomeLolo","setpoint_default_duration":180,"place":{"altitude":70,"city":"Champagne-sur-Oise","continent":"Europe","country":"FR","country_name":"France","location":[xxxx,xxxxxx],"street":"xxxxx","timezone":"Europe\/Paris"},"heating_system":{"heating_system_window_seen":true,"heating_type":"radiator"},"last_plug_seen":1670434807,"outdoor_temperature":{"te":2,"ti":1670432981},"system_mode":"winter","setpoint_hwb":{"setpoint_activate":false},"modules":[{"_id":"07:00:00:xx:xx:xx","type":"NAThermVaillant","module_name":"Thermostat","anticipating":true,"id":"xx:xx:xx:xx:xx:xx","last_setup":{"sec":1601464432,"usec":715000},"date_setup":{"sec":1601464432,"usec":715000},"name":"Thermostat","firmware":14,"last_message":1670434805,"rf_status":61,"battery_vp":4023,"boiler_status":true,"radio_id":2,"reachable":true,"last_fw_update":1641933041,"battery_percent":68,"last_therm_seen":1670434805,"setpoint_away":{"setpoint_activate":false},"setpoint_manual":{"setpoint_activate":false},"therm_program_list":[{"timetable":[{"m_offset":0,"id":1},{"m_offset":300,"id":0},{"m_offset":450,"id":4},{"m_offset":1050,"id":0},{"m_offset":1080,"id":1},{"m_offset":1740,"id":0},{"m_offset":1890,"id":4},{"m_offset":2490,"id":0},{"m_offset":2520,"id":1},{"m_offset":3180,"id":0},{"m_offset":3330,"id":4},{"m_offset":3930,"id":0},{"m_offset":3960,"id":1},{"m_offset":4620,"id":0},{"m_offset":4770,"id":4},{"m_offset":5370,"id":0},{"m_offset":5400,"id":1},{"m_offset":6060,"id":0},{"m_offset":6210,"id":4},{"m_offset":6810,"id":0},{"m_offset":6840,"id":1},{"m_offset":7500,"id":0},{"m_offset":8280,"id":1},{"m_offset":8940,"id":0},{"m_offset":9720,"id":1}],"zones":[{"id":0,"type":0,"temp":20,"hw":true},{"id":1,"type":1,"temp":17,"hw":false},{"id":4,"type":5,"temp":18,"hw":false},{"type":3,"id":2,"temp":7,"hw":false}],"name":"Default","program_id":"5f7468700eb7f94e84050f25"},{"timetable":[{"m_offset":0,"id":1},{"m_offset":315,"id":0},{"m_offset":1080,"id":1},{"m_offset":1755,"id":0},{"m_offset":2520,"id":1},{"m_offset":3195,"id":0},{"m_offset":3960,"id":1},{"m_offset":4635,"id":0},{"m_offset":5400,"id":1},{"m_offset":6075,"id":0},{"m_offset":6840,"id":1},{"m_offset":7605,"id":0},{"m_offset":8190,"id":1},{"m_offset":9045,"id":0},{"m_offset":9630,"id":1}],"zones":[{"name":"Absent","id":2,"type":5,"modules":[],"temp":17,"hw":true},{"name":"\u00c0 la maison","id":0,"type":0,"modules":[],"temp":19,"hw":false},{"name":"Nuit","id":1,"type":1,"modules":[],"temp":17,"hw":false},{"type":3,"id":3,"temp":7,"hw":false}],"name":"Present","program_id":"xxxxxxxxxxxxxxxxxxx"},{"timetable":[{"m_offset":0,"id":1},{"m_offset":360,"id":0},{"m_offset":420,"id":4},{"m_offset":1200,"id":0},{"m_offset":1380,"id":1},{"m_offset":1800,"id":0},{"m_offset":1860,"id":4},{"m_offset":2640,"id":0},{"m_offset":2820,"id":1},{"m_offset":3240,"id":0},{"m_offset":3300,"id":4},{"m_offset":4080,"id":0},{"m_offset":4260,"id":1},{"m_offset":4680,"id":0},{"m_offset":4740,"id":4},{"m_offset":5520,"id":0},{"m_offset":5700,"id":1},{"m_offset":6120,"id":0},{"m_offset":6180,"id":4},{"m_offset":6960,"id":0},{"m_offset":7140,"id":1},{"m_offset":7560,"id":0},{"m_offset":8580,"id":1},{"m_offset":9000,"id":0},{"m_offset":10020,"id":1}],"zones":[{"id":1,"type":1,"modules":[],"temp":18,"hw":false},{"id":4,"type":5,"modules":[],"temp":18,"hw":false},{"name":"\u00c0 la maison","id":0,"type":0,"modules":[],"temp":20,"hw":true},{"type":3,"id":2,"temp":7,"hw":false}],"name":"Absent","program_id":"xxxxxxxxxxxx","selected":true},{"timetable":[{"m_offset":0,"id":0},{"m_offset":15,"id":4},{"m_offset":1410,"id":0},{"m_offset":1425,"id":1},{"m_offset":1440,"id":0},{"m_offset":1455,"id":4},{"m_offset":2850,"id":0},{"m_offset":2865,"id":1},{"m_offset":2880,"id":0},{"m_offset":2895,"id":4},{"m_offset":4290,"id":0},{"m_offset":4305,"id":1},{"m_offset":4320,"id":0},{"m_offset":4335,"id":4},{"m_offset":5730,"id":0},{"m_offset":5745,"id":1},{"m_offset":5760,"id":0},{"m_offset":5775,"id":4},{"m_offset":7170,"id":0},{"m_offset":7185,"id":1},{"m_offset":7200,"id":0},{"m_offset":7215,"id":4},{"m_offset":8610,"id":0},{"m_offset":8625,"id":1},{"m_offset":8640,"id":0},{"m_offset":8655,"id":4},{"m_offset":9360,"id":0},{"m_offset":10065,"id":1}],"zones":[{"id":1,"type":1,"modules":[],"temp":16,"hw":false},{"id":4,"type":5,"modules":[],"temp":16,"hw":false},{"name":"\u00c0 la maison","id":0,"type":0,"modules":[],"temp":20,"hw":true},{"type":3,"id":2,"temp":7,"hw":false}],"name":"Weekend","program_id":"xxxxxxxxxxxxxxxxxx"}],"measured":{"time":1670434791,"temperature":18.9,"setpoint_temp":20,"est_setpoint_temp":18}}],"last_sync_asked":1670434848,"syncing":true,"ebus_status":{"ebus_error":false,"boiler_error":false,"maintenance_status":false,"refill_water":false,"emf_avail":true}}],"user":{"mail":"xxxx@xxx","administrative":{"lang":"fr","reg_locale":"fr","country":"FR","unit":0,"windunit":0,"pressureunit":0,"feel_like_algo":0},"pending_user_consent":true,"app_telemetry":false}}
0485|[2022-12-07 18:40:47]DEBUG : syncFromWeb mesuresNow: {"Temperature":18.9,"Sp_Temperature":20,"BoilerOn":606,"BoilerOff":0,"flow_setpoint":69,"energy_gaz_heating":0,"energy_gaz_hot_water":0,"energy_elec_heating":0,"energy_elec_hot_water":0,"tx_on":100,"infos":{"function":"getNowMeasures","date_begin":null,"date_end":"last","units":"\u00b0C,\u00b0C,min,min,Wh,Wh,Wh,Wh","data_type":{"min_temp":"\u00b0C","max_temp":"\u00b0C","sum_boiler_on":"sec","sum_boiler_off":"sec","sum_energy_gaz_heating":"wh","sum_energy_gaz_hot_water":"wh","sum_energy_elec_heating":"wh","sum_energy_elec_hot_water":"wh","tx_on":"%","duree_on":"min"},"types":"Temperature,Sp_Temperature,BoilerOn,BoilerOff,flow_setpoint,energy_gaz_heating,energy_gaz_hot_water,energy_elec_heating,energy_elec_hot_water"}}
0486|[2022-12-07 18:40:47]DEBUG : syncFromWeb calendar {"nowplanning":"Absent","nowplanid":"xxxxxxxxxxx","listplanning":"xxxxxxxxxxxxxxx|Default;xxxxxxxxxxxxxx|Present;xxxxxxxxxxx|Absent;xxxxxxxxxxxxxxxxxx|Weekend","listprofil":"Nuit;18|Absent;18|\u00c0 la maison;20|HG;7","nowprofil":"Absent","nowprofil_temp":"18","nextprofil":"\u00c0 la maison","nextprofil_temp":"20","profil_endtime":"1670439600","profil_hwb":false}
0487|[2022-12-07 18:40:47]DEBUG : syncFromWeb mode program
0488|[2022-12-07 18:40:47]DEBUG : fin sync
0489|[2022-12-07 18:40:47]DEBUG : cron10 started *****************
0490|[2022-12-07 18:40:47]DEBUG : syncFromWeb thermdata {"devices":[{"_id":"xx:xx:xx:xx:xx:xx","type":"NAVaillant","date_setup":{"sec":1601464386,"usec":313000},"house_model":{"hc_gefs":{"pivot_x":20,"pivot_y":20,"max_ext_temp":20,"min_flow_set_point":39.6,"base_external_temp":-7,"slope":13,"temp_shift":19.6,"max_flow_set_point":74.7},"in_use":"gefs","ca":{"te":2,"ti":1670432981,"so":"meteogroup"},"algo_type":"pid_algo","first_anticipate_avail":false,"gefs":{"lag_up":71,"tau":186001,"off_overshoot":0.8,"lag_down":10,"pk":40,"on_overshoot":0},"pid_algo":{"gain":123,"ti":20,"td":5,"period":10},"time_pid_computed":1669503360,"prediction_activated":true},"last_setup":1601464386,"admin_access_code":["xxxxxxxxxx"],"udp_conn":true,"boiler_oem_serial":"xxxxxxxxxxxxxxxx","dhw":55,"firmware":1029,"oem_serial":"xxxxxxxxxx","dhw_max":60,"dhw_min":38,"hot_water_anticipating":false,"last_status_store":1670434847,"wifi_status":54,"home_id":"xxxxxxxxxxx","migration_netcomv2_vaillant":true,"boiler_error":[],"boiler_id":"xxxxxxxxxxxxx","dhw_enabled":false,"ebus_error":false,"emf_avail":true,"station_name":"HomeLolo","setpoint_default_duration":180,"place":{"altitude":70,"city":"Champagne-sur-Oise","continent":"Europe","country":"FR","country_name":"France","location":[xx,xx],"street":"xxxx","timezone":"Europe\/Paris"},"heating_system":{"heating_system_window_seen":true,"heating_type":"radiator"},"last_plug_seen":1670434847,"outdoor_temperature":{"te":2,"ti":1670432981},"system_mode":"winter","setpoint_hwb":{"setpoint_activate":false},"modules":[{"_id":"07:00:00:65:e4:8e","type":"NAThermVaillant","module_name":"Thermostat","anticipating":true,"id":"xx:xx:xx:xx:xx:xx","last_setup":{"sec":1601464432,"usec":715000},"date_setup":{"sec":1601464432,"usec":715000},"name":"Thermostat","firmware":14,"last_message":1670434837,"rf_status":61,"battery_vp":4024,"boiler_status":true,"radio_id":2,"reachable":true,"last_fw_update":1641933041,"battery_percent":68,"last_therm_seen":1670434837,"setpoint_away":{"setpoint_activate":false},"setpoint_manual":{"setpoint_activate":false},"therm_program_list":[{"timetable":[{"m_offset":0,"id":1},{"m_offset":300,"id":0},{"m_offset":450,"id":4},{"m_offset":1050,"id":0},{"m_offset":1080,"id":1},{"m_offset":1740,"id":0},{"m_offset":1890,"id":4},{"m_offset":2490,"id":0},{"m_offset":2520,"id":1},{"m_offset":3180,"id":0},{"m_offset":3330,"id":4},{"m_offset":3930,"id":0},{"m_offset":3960,"id":1},{"m_offset":4620,"id":0},{"m_offset":4770,"id":4},{"m_offset":5370,"id":0},{"m_offset":5400,"id":1},{"m_offset":6060,"id":0},{"m_offset":6210,"id":4},{"m_offset":6810,"id":0},{"m_offset":6840,"id":1},{"m_offset":7500,"id":0},{"m_offset":8280,"id":1},{"m_offset":8940,"id":0},{"m_offset":9720,"id":1}],"zones":[{"id":0,"type":0,"temp":20,"hw":true},{"id":1,"type":1,"temp":17,"hw":false},{"id":4,"type":5,"temp":18,"hw":false},{"type":3,"id":2,"temp":7,"hw":false}],"name":"Default","program_id":"xxxxxxxxxxxxxx"},{"timetable":[{"m_offset":0,"id":1},{"m_offset":315,"id":0},{"m_offset":1080,"id":1},{"m_offset":1755,"id":0},{"m_offset":2520,"id":1},{"m_offset":3195,"id":0},{"m_offset":3960,"id":1},{"m_offset":4635,"id":0},{"m_offset":5400,"id":1},{"m_offset":6075,"id":0},{"m_offset":6840,"id":1},{"m_offset":7605,"id":0},{"m_offset":8190,"id":1},{"m_offset":9045,"id":0},{"m_offset":9630,"id":1}],"zones":[{"name":"Absent","id":2,"type":5,"modules":[],"temp":17,"hw":true},{"name":"\u00c0 la maison","id":0,"type":0,"modules":[],"temp":19,"hw":false},{"name":"Nuit","id":1,"type":1,"modules":[],"temp":17,"hw":false},{"type":3,"id":3,"temp":7,"hw":false}],"name":"Present","program_id":"xxxxxxxxxxxx"},{"timetable":[{"m_offset":0,"id":1},{"m_offset":360,"id":0},{"m_offset":420,"id":4},{"m_offset":1200,"id":0},{"m_offset":1380,"id":1},{"m_offset":1800,"id":0},{"m_offset":1860,"id":4},{"m_offset":2640,"id":0},{"m_offset":2820,"id":1},{"m_offset":3240,"id":0},{"m_offset":3300,"id":4},{"m_offset":4080,"id":0},{"m_offset":4260,"id":1},{"m_offset":4680,"id":0},{"m_offset":4740,"id":4},{"m_offset":5520,"id":0},{"m_offset":5700,"id":1},{"m_offset":6120,"id":0},{"m_offset":6180,"id":4},{"m_offset":6960,"id":0},{"m_offset":7140,"id":1},{"m_offset":7560,"id":0},{"m_offset":8580,"id":1},{"m_offset":9000,"id":0},{"m_offset":10020,"id":1}],"zones":[{"id":1,"type":1,"modules":[],"temp":18,"hw":false},{"id":4,"type":5,"modules":[],"temp":18,"hw":false},{"name":"\u00c0 la maison","id":0,"type":0,"modules":[],"temp":20,"hw":true},{"type":3,"id":2,"temp":7,"hw":false}],"name":"Absent","program_id":"5f7700ed409b8c5a7b454fea","selected":true},{"timetable":[{"m_offset":0,"id":0},{"m_offset":15,"id":4},{"m_offset":1410,"id":0},{"m_offset":1425,"id":1},{"m_offset":1440,"id":0},{"m_offset":1455,"id":4},{"m_offset":2850,"id":0},{"m_offset":2865,"id":1},{"m_offset":2880,"id":0},{"m_offset":2895,"id":4},{"m_offset":4290,"id":0},{"m_offset":4305,"id":1},{"m_offset":4320,"id":0},{"m_offset":4335,"id":4},{"m_offset":5730,"id":0},{"m_offset":5745,"id":1},{"m_offset":5760,"id":0},{"m_offset":5775,"id":4},{"m_offset":7170,"id":0},{"m_offset":7185,"id":1},{"m_offset":7200,"id":0},{"m_offset":7215,"id":4},{"m_offset":8610,"id":0},{"m_offset":8625,"id":1},{"m_offset":8640,"id":0},{"m_offset":8655,"id":4},{"m_offset":9360,"id":0},{"m_offset":10065,"id":1}],"zones":[{"id":1,"type":1,"modules":[],"temp":16,"hw":false},{"id":4,"type":5,"modules":[],"temp":16,"hw":false},{"name":"\u00c0 la maison","id":0,"type":0,"modules":[],"temp":20,"hw":true},{"type":3,"id":2,"temp":7,"hw":false}],"name":"Weekend","program_id":"xxxxxxxxxx"}],"measured":{"time":1670434791,"temperature":18.9,"setpoint_temp":20,"est_setpoint_temp":18}}],"last_sync_asked":1670434848,"syncing":true,"ebus_status":{"ebus_error":false,"boiler_error":false,"maintenance_status":false,"refill_water":false,"emf_avail":true}}],"user":{"mail":"xxx@xxxx","administrative":{"lang":"fr","reg_locale":"fr","country":"FR","unit":0,"windunit":0,"pressureunit":0,"feel_like_algo":0},"pending_user_consent":true,"app_telemetry":false}}
0491|[2022-12-07 18:40:47]DEBUG : syncFromWeb mesuresNow: {"Temperature":18.9,"Sp_Temperature":20,"BoilerOn":606,"BoilerOff":0,"flow_setpoint":69,"energy_gaz_heating":0,"energy_gaz_hot_water":0,"energy_elec_heating":0,"energy_elec_hot_water":0,"tx_on":100,"infos":{"function":"getNowMeasures","date_begin":null,"date_end":"last","units":"\u00b0C,\u00b0C,min,min,Wh,Wh,Wh,Wh","data_type":{"min_temp":"\u00b0C","max_temp":"\u00b0C","sum_boiler_on":"sec","sum_boiler_off":"sec","sum_energy_gaz_heating":"wh","sum_energy_gaz_hot_water":"wh","sum_energy_elec_heating":"wh","sum_energy_elec_hot_water":"wh","tx_on":"%","duree_on":"min"},"types":"Temperature,Sp_Temperature,BoilerOn,BoilerOff,flow_setpoint,energy_gaz_heating,energy_gaz_hot_water,energy_elec_heating,energy_elec_hot_water"}}
0492|[2022-12-07 18:40:47]DEBUG : outbasetemp(xx:xx:xx:xx:xx:xx): 2.0
0493|[2022-12-07 18:40:47]DEBUG : syncFromWeb calendar {"nowplanning":"Absent","nowplanid":"xxxxxxxxx","listplanning":"xxxxxxxxx|Default;xxxxxxxxxx|Present;xxxxxxxxx|Absent;xxxxxxxxxxx|Weekend","listprofil":"Nuit;18|Absent;18|\u00c0 la maison;20|HG;7","nowprofil":"Absent","nowprofil_temp":"18","nextprofil":"\u00c0 la maison","nextprofil_temp":"20","profil_endtime":"1670439600","profil_hwb":false}
0494|[2022-12-07 18:40:47]DEBUG : syncFromWeb mode program
0495|[2022-12-07 18:40:47]DEBUG : fin sync
0496|[2022-12-07 18:40:47]DEBUG : Fin cron10 ************************
0497|[2022-12-07 18:41:32]DEBUG : execute action: consigneset No Endtime
0498|[2022-12-07 18:41:32]WARNING : makeRequest API_Erreur at /api/setminormode : setpoint_endtime in past(21)
0499|[2022-12-07 18:41:32]ERROR : Erreur exécution de la commande [Chaufferie][HomeLolo][Consigne Chauffage] : API_Erreur at /api/setminormode : setpoint_endtime in past(21)
Si quelqu’un peut m’orienter
