bonjour sur mon jeedom en version 4.2.20 sur vmware
j 'ai depuis un long moment un systeme avec node red qui tourne pour recuperer les valeur de mon system solaire emphase
je m 'apercoit aujourd’hui que j 'ai des messages d 'erreur a la remonte des infos dans le plugin jmqtt
je laisse le log
[2022-07-13 08:18:06][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][envoy][consomation1:wNow]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1351-consomation1:wNow' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:06][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][envoy][consomation0:whToday]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1351-consomation0:whToday' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:06][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][envoy 2][production:wNow]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1352-production:wNow' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:06][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][envoy 2][production:WhLiifetime]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1352-production:WhLiifetime' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:10][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p1:Puissance max]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p1:Puissance max' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:10][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p2:Puissance max]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p2:Puissance max' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:10][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p3:power]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p3:power' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:10][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p3:Puissance max]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p3:Puissance max' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:10][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p4:power]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p4:power' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:10][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p4:Puissance max]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p4:Puissance max' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:10][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p5:power]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p5:power' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:10][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p5:Puissance max]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p5:Puissance max' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:10][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p6:power]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p6:power' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:10][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p6:Puissance max]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p6:Puissance max' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:10][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p7:power]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p7:power' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:10][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p7:Puissance max]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p7:Puissance max' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:10][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p0:power]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p0:power' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:10][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p0:Puissance max]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p0:Puissance max' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:36][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][envoy][consomation1:wNow]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1351-consomation1:wNow' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:36][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][envoy][consomation0:whToday]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1351-consomation0:whToday' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:36][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][envoy 2][production:wNow]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1352-production:wNow' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:36][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][envoy 2][production:WhLiifetime]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1352-production:WhLiifetime' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:40][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p1:Puissance max]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p1:Puissance max' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:40][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p2:Puissance max]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p2:Puissance max' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:40][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p3:power]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p3:power' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:40][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p3:Puissance max]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p3:Puissance max' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:40][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p4:power]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p4:power' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:40][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p4:Puissance max]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p4:Puissance max' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:40][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p5:power]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p5:power' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:40][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p5:Puissance max]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p5:Puissance max' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:40][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p6:power]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p6:power' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:40][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p6:Puissance max]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p6:Puissance max' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:40][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p7:power]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p7:power' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:40][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p7:Puissance max]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p7:Puissance max' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:40][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p0:power]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p0:power' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2022-07-13 08:18:40][ERROR] : L'enregistrement de la nouvelle commande #[JMQTT][panneaux][p0:Puissance max]# a levé l'Exception: [MySQL] Error code : 23000 (1062). Duplicate entry '1353-p0:Puissance max' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
je ne sais pas ce que veut dire ce message
cdt
