Afin de faire des tests, j’ai installé une VM proxmox avec debian 12 et ai installé Jeedom alpha.
Durant l’installation voici ce qui est écrit dans http.error :
0000|Created directory: /var/lib/snmp/cert_indexes
0001|[Fri Dec 20 15:36:51.810448 2024] [mpm_prefork:notice] [pid 25417:tid 25417] AH00163: Apache/2.4.62 (Debian) configured -- resuming normal operations
0002|[Fri Dec 20 15:36:51.810490 2024] [core:notice] [pid 25417:tid 25417] AH00094: Command line: '/usr/sbin/apache2'
0003|warning: commands will be executed using /bin/sh
0004|job 2 at Fri Dec 20 15:51:00 2024
0005|WARNING: The directory '/var/www/.cache/pip' or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you should use sudo's -H flag.
C’est surtout la dernière ligne qui peut paraitre étrange. Je n’ai rien trouvé sur community concernant ce message et souhaitais simplement remonter l’info.
A+
Michel
