Depuis la mise à jour du plugin (version du 2/12), le daemon ne redémarre plus.
J’ai réinstallé plusieurs fois les dépendances, refait la mise à jour mais rien n’y fait.
[2023-12-08 17:50:10][INFO] : Lancement démon meross : /usr/bin/python3 /var/www/html/plugins/MerosSync/resources/MerossIOTd/MerossIOTd.py --muser "xxx" --mpswd "xxx" --callback http://127.0.0.1:80/plugins/MerosSync/core/php/jeeMerosSync.php --apikey fXFHtKGJLOHduVDhy9aAtM8t9RpOFHyTglpbhYl1UdnWKHOBPKTuSjwWm2uU4hQs --loglevel debug --pid /tmp/jeedom/MerosSync/daemon.pid --errorfile /tmp/jeedom/MerosSync/errordaemon.pid --socket /tmp/jeedom/MerosSync/daemon.sock --logfile /var/www/html/core/class/../../log/MerosSync
[2023-12-08 16:50:13][DEBUG][meross_iot] : Test logger merossIOT
[2023-12-08 16:50:13][INFO][DemonPython] : Current version is : 0.4.6.0
[2023-12-08 16:50:13][INFO][DemonPython] : Start MerossIOTd
[2023-12-08 16:50:13][INFO][DemonPython] : Log level : debug
[2023-12-08 16:50:13][INFO][DemonPython] : Socket : /tmp/jeedom/MerosSync/daemon.sock
[2023-12-08 16:50:13][INFO][DemonPython] : PID file : /tmp/jeedom/MerosSync/daemon.pid
[2023-12-08 16:50:13][INFO][DemonPython] : Error file : /tmp/jeedom/MerosSync/errordaemon.pid
[2023-12-08 16:50:13][INFO][DemonPython] : Apikey : fXFHtKGJLOHduVDhy9aAtM8t9RpOFHyTglpbhYl1UdnWKHOBPKTuSjwWm2uU4hQs
[2023-12-08 16:50:13][INFO][DemonPython] : Callback : http://127.0.0.1:80/plugins/MerosSync/core/php/jeeMerosSync.php
[2023-12-08 16:50:13][INFO][DemonPython] : Python version : 3.9.2 (default, Feb 28 2021, 17:03:44)
[GCC 10.2.1 20210110]
[2023-12-08 16:50:13][DEBUG][DemonPython] : Mise en place signal
[2023-12-08 16:50:13][DEBUG][DemonPython] : Test Callback
[2023-12-08 16:50:13][DEBUG][DemonPython] : Envoi un test à jeedom
[2023-12-08 16:50:13][DEBUG][DemonPython] : Envoie à jeedom : {'action': 'test'}
[2023-12-08 17:50:13][DEBUG] : Array ( [action] => test )
[2023-12-08 16:50:13][DEBUG][DemonPython] : Réponse de jeedom : {'success': True}
[2023-12-08 16:50:13][DEBUG][DemonPython] : Démarrage socket
[2023-12-08 16:50:13][DEBUG][DemonPython] : Test connection Meross
[2023-12-08 16:50:13][DEBUG][DemonPython] : Connecting with user xxxxxxx@gmail.com
[2023-12-08 16:50:13][DEBUG][meross_iot.http_api] : Logging in with email: xxxxxxx@gmail.com, password: XXXXX
[2023-12-08 16:50:13][DEBUG][meross_iot.http_api] : Performing HTTP request against https://iotx-eu.meross.com/v1/Auth/signIn, headers: {'AppVersion': '0.4.6.0', 'Authorization': 'Basic', 'vender': 'meross', 'AppType': 'MerossIOT', 'AppLanguage': 'EN', 'User-Agent': 'MerossIOT/0.4.6.0', 'Content-Type': 'application/json'}, post data: {'params': 'eyJlbWFpbCI6ICJzLmN1Y2hldmFsQGdtYWlsLmNvbSIsICJwYXNzd29yZCI6ICIwZWFlMmI4NWI2ZDZmNGZhNjc3ZjE0NDllZjM5YmQzOCIsICJhY2NvdW50Q291bnRyeUNvZGUiOiAidXMiLCAiZW5jcnlwdGlvbiI6IDEsICJhZ3JlZSI6IDAsICJtb2JpbGVJbmZvIjogeyJkZXZpY2VNb2RlbCI6ICJhYXJjaDY0IiwgIm1vYmlsZU9zVmVyc2lvbiI6ICIjMTAxIFNNUCBXZWQgU2VwIDE0IDAxOjQ5OjIzIFVUQyAyMDIyIiwgIm1vYmlsZU9zIjogIkxpbnV4IiwgInV1aWQiOiAiNWQwMzc4Y2NiOTdiZWI3ZTI0NmZlNjNlMDYyMjJjZGI0ZWQwYjYtNTExOC00OGJmLThkNzAtODE2MmM2ZTY3NDg4IiwgImNhcnJpZXIiOiAiIn19', 'sign': '6e2f3b600c00563ba9b8f26b681302d9', 'timestamp': 1702054213433, 'nonce': 'NCA7J9QCKGGX20MD'}
[2023-12-08 16:50:13][DEBUG][meross_iot.http_api] : Response Status Code: 200
[2023-12-08 16:50:13][ERROR][meross_iot.http_api] : Received non-ok API status code: MFA_CODE_REQUIRED. Failed request to API. Response was: {'apiStatus': 1033, 'sysStatus': 0, 'info': '', 'timestamp': 1702054213, 'data': {}}
[2023-12-08 16:50:13][ERROR][DemonPython] :
[2023-12-08 16:50:13][DEBUG][DemonPython] : Ecriture du PID 1255555 dans /tmp/jeedom/MerosSync/errordaemon.pid
Si quelqun connait une solution ?
