Bonjour;
J’ai mon Demon qui reste sur NOK, j’imagine à cause d’une mauvaise version de Node js ?
Je pense que l’erreur s’est produite après avoir mis à jours d’un autre Plugins WifilightV2 mais je ne suis pas sûr, c’est possible ???
Merci d’avance pour votre aide
Wed Oct 04 2023 22:27:41 GMT+0200 (Central European Summer Time) - Jeedom url : http://127.0.0.1:80/plugins/rflink/core/api/rflink.php?apikey=7y2W39u0JJLDgyEn9B9lgX9bcfWSl0nZ, gwAddress : /dev/ttyUSB0
/var/www/html/plugins/rflink/resources/node_modules/bindings/bindings.js:121
throw e;
Error: The module '/var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/build/Release/bindings.node'
was compiled against a different Node.js version using
NODE_MODULE_VERSION 93. This version of Node.js requires
NODE_MODULE_VERSION 108. Please try re-compiling or re-installing
the module (for instance, using `npm rebuild` or `npm install`).
at Module._extensions..node (node:internal/modules/cjs/loader:1340:18)
at Module.load (node:internal/modules/cjs/loader:1119:32)
at Module._load (node:internal/modules/cjs/loader:960:12)
at Module.require (node:internal/modules/cjs/loader:1143:19)
at require (node:internal/modules/cjs/helpers:121:18)
at bindings (/var/www/html/plugins/rflink/resources/node_modules/bindings/bindings.js:112:48)
at Object. (/var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/lib/linux.js:2:36)
at Module._compile (node:internal/modules/cjs/loader:1256:14)
at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
at Object. (/var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/lib/index.js:14:22)
at Module._extensions..js (node:internal/modules/cjs/loader:1310:10) {
code: 'ERR_DLOPEN_FAILED'
Node.js v18.17.1
