Depuis mon passage en BOX ATLAS, impossible de récupérer les mails :
imapDisconnected
(node:25523) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification.
(Use `nodejs --trace-warnings ...` to show where the warning was created)
imapConnected
Error: read ECONNRESET
at TCP.onStreamRead (internal/stream_base_commons.js:209:20) {
errno: -104,
code: 'ECONNRESET',
syscall: 'read',
source: 'socket'
imapDisconnected
(node:2900) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification.
imapConnected
Si vous avez une idée
Et si je passe le " Logs et surveillance" en mode Warning, je n’ai rien de plus
Merci d’avance
Benoit
