J’ai mon jeedom qui fait générer des logs en grand nombre dans journald à propos de droits sur le fichier cron_execution
mai 17 16:52:09 raspberrypi sudo[5336]: pam_unix(sudo:session): session opened for user root by (uid=0)
mai 17 16:52:09 raspberrypi sudo[5336]: pam_unix(sudo:session): session closed for user root
mai 17 16:52:10 raspberrypi sudo[5395]: www-data : TTY=unknown ; PWD=/var/www/html/core/ajax ; USER=root ; COMMAND=/bin/chmod 664 /var/www/html/core/class/../../log/cron_execution
mai 17 16:52:11 raspberrypi sudo[5395]: pam_unix(sudo:session): session opened for user root by (uid=0)
mai 17 16:52:11 raspberrypi sudo[5395]: pam_unix(sudo:session): session closed for user root
mai 17 16:52:12 raspberrypi sudo[5454]: www-data : TTY=unknown ; PWD=/var/www/html/core/ajax ; USER=root ; COMMAND=/bin/chmod 664 /var/www/html/core/class/../../log/cron_execution
mai 17 16:52:12 raspberrypi sudo[5454]: pam_unix(sudo:session): session opened for user root by (uid=0)
mai 17 16:52:12 raspberrypi sudo[5454]: pam_unix(sudo:session): session closed for user root
mai 17 16:52:13 raspberrypi sudo[5512]: www-data : TTY=unknown ; PWD=/var/www/html/core/ajax ; USER=root ; COMMAND=/bin/chmod 664 /var/www/html/core/class/../../log/cron_execution
mai 17 16:52:13 raspberrypi sudo[5512]: pam_unix(sudo:session): session opened for user root by (uid=0)
mai 17 16:52:13 raspberrypi sudo[5512]: pam_unix(sudo:session): session closed for user root
mai 17 16:52:14 raspberrypi sudo[5571]: www-data : TTY=unknown ; PWD=/var/www/html/core/ajax ; USER=root ; COMMAND=/bin/chmod 664 /var/www/html/core/class/../../log/cron_execution
mai 17 16:52:14 raspberrypi sudo[5571]: pam_unix(sudo:session): session opened for user root by (uid=0)
mai 17 16:52:14 raspberrypi sudo[5571]: pam_unix(sudo:session): session closed for user root
mai 17 16:52:16 raspberrypi sudo[5670]: www-data : TTY=unknown ; PWD=/var/www/html/core/ajax ; USER=root ; COMMAND=/bin/chmod 664 /var/www/html/core/class/../../log/cron_execution
mai 17 16:52:16 raspberrypi sudo[5670]: pam_unix(sudo:session): session opened for user root by (uid=0)
mai 17 16:52:16 raspberrypi sudo[5670]: pam_unix(sudo:session): session closed for user root
mai 17 16:52:17 raspberrypi sudo[5729]: www-data : TTY=unknown ; PWD=/var/www/html/core/ajax ; USER=root ; COMMAND=/bin/chmod 664 /var/www/html/core/class/../../log/cron_execution
Je suis sur Debian Buster sur rpi avec Jeedom V4.0.54.
J’aimerais les supprimer : je ne sais pas trop d’où çà vient.
au niveau du fichier en question, les droits sont déjà bons, me semble-t-il :
-rw-rw-r-- 1 www-data www-data 21624 mai 17 16:57 cron_execution
au niveau du fichier de log, j’ai beaucoup de log de ce type
PHP Warning: Invalid argument supplied for foreach() in /var/www/html/plugins/ghlocal/core/class/ghlocal.class.php on line 238
Même si supprimer le log en amont m’intéresse aussi, j’aimerais quand même éviter le log dans journald.
Une idée de comment faire ?
