Rien de bloquant ni pénalisant mais j’ai ca dans le log scenario_execution quand je lance une attestation par un scenario
Array
[background] => 0
convert-im6.q16: profile 'icc': 'RGB ': RGB color space not permitted on grayscale PNG `/var/www/html/plugins/CovidAttest/EXPORT/AG_941/attestation-2020-11-27_12-09_XXXXXXXXXXXXX.png' @ warning/png.c/MagickPNGWarningHandler/1667.
Le debug
[2020-11-27 12:12:05][DEBUG] : ╔═══════════════════════ execute CMD : 11633 | [Maison][Attestation Célia][Envoi motif ENFANTS], logical id : send_motif_ENFANTSoptions : 1
[2020-11-27 12:12:05][DEBUG] : ╠════ createDirectPDF called for motif :enfants
[2020-11-27 12:12:05][DEBUG] : ╠════ Id equipement :941
[2020-11-27 12:12:05][DEBUG] : ╠════ date :27/11/2020 / time : 12h12 / motif : enfants
[2020-11-27 12:12:05][DEBUG] : ╠════ Cree le: 27/11/2020; Nom: XXXXXXX; Prenom: XXX; Naissance: XXXXXX a XXX; Adresse: XXXXXXXXXXXXXXXXXXXXXX; Sortie: 27/11/2020 Motifs: enfants
[2020-11-27 12:12:05][DEBUG] : ╠════ ajout de la seconde page :0
[2020-11-27 12:12:05][DEBUG] : ╠════ Certificat utilisé :certificate_20_11_20.pdf
[2020-11-27 12:12:05][DEBUG] : ╠════ ## change certif name to :certificate_20_11_20.pdf
[2020-11-27 12:12:05][DEBUG] : ║ ╔══════════════════════ Start Generating Attestation ════════════════════
[2020-11-27 12:12:05][DEBUG] : ║ ╠════ json file to be used :certificate_20_11_20.json
[2020-11-27 12:12:05][DEBUG] : ║ ╠════ json def file file :/var/www/html/plugins/CovidAttest/3rdparty/Certificate/certificate_20_11_20.json
[2020-11-27 12:12:05][DEBUG] : ║ ╠════ QR code generated filepath :/var/www/html/plugins/CovidAttest/EXPORT/AG_941/qrcode_attest-2020-11-27_12-12_XXXXXXXXXXXXXXXXXXXXX.png
[2020-11-27 12:12:05][DEBUG] : ║ ╠════ pdf source copies
[2020-11-27 12:12:05][DEBUG] : ║ ╠════ motif testé :enfants
[2020-11-27 12:12:05][DEBUG] : ║ ╚═══════════════════════ Fin génération Attestation :/var/www/html/plugins/CovidAttest/EXPORT/AG_941/attestation-2020-11-27_12-12_XXXXXXXXXXX.pdf
[2020-11-27 12:12:05][DEBUG] : ╠════ pdf url :/var/www/html/plugins/CovidAttest/EXPORT/AG_941/attestation-2020-11-27_12-12_XXXXXXXXXXXXXXXXXXX.pdf
[2020-11-27 12:12:05][DEBUG] : ╠════ png url :/var/www/html/plugins/CovidAttest/EXPORT/AG_941/qrcode_attest-2020-11-27_12-12_XXXXXXXXXXXXXXXXX.png
[2020-11-27 12:12:05][DEBUG] : ╠════ ## Convert file attestation-2020-11-27_12-12_XXXXXXXXXXXXXXX.pdf to image attestation-2020-11-27_12-12_XXXXXXXXXXXXXXX.png by commande convert -density 200 /var/www/html/plugins/CovidAttest/EXPORT/AG_941/attestation-2020-11-27_12-12_XXXXXXXXXXXXXXXX.pdf -fill "#FFFFFFFF" -opaque none -flatten -alpha flatten -alpha remove /var/www/html/plugins/CovidAttest/EXPORT/AG_941/attestation-2020-11-27_12-12_XXXXXXXXXXXXXXX.png
[2020-11-27 12:12:07][DEBUG] : ╠════ choix des fichiers à envoyer - pdf :0 | png : 1 | QRcode : 1
[2020-11-27 12:12:07][DEBUG] : ╠════ url des fichiers à envoyer - pdf :/var/www/html/plugins/CovidAttest/EXPORT/AG_941/qrcode_attest-2020-11-27_12-12_XXXXXXXXXXXXXX.png, /var/www/html/plugins/CovidAttest/EXPORT/AG_941/attestation-2020-11-27_12-12_XXXXXXXXXXXXXXX.png
[2020-11-27 12:12:07][DEBUG] : ╠════ telegram : string envoyée :file=/var/www/html/plugins/CovidAttest/EXPORT/AG_941/qrcode_attest-2020-11-27_12-12_XXXXXXXXXXXXXXXXX.png,/var/www/html/plugins/CovidAttest/EXPORT/AG_941/attestation-2020-11-27_12-12_XXXXXXXXXXXXXXXXXX.png
[2020-11-27 12:12:07][DEBUG] : ╠════ commande d'envoi :#7615#
[2020-11-27 12:12:07][DEBUG] : ╠════ envoi des fichiers par la commande :[Jeedom][Télégram][Celia - 972708985]
[2020-11-27 12:12:09][DEBUG] : ╠════ suppression auto des fichiers statut :0
[2020-11-27 12:12:09][DEBUG] : ╠════ Suppression des fichiers : ok
[2020-11-27 12:12:09][DEBUG] : ╚═══════════════════════ Fin Commande
[2020-11-27 12:12:35][DEBUG] : pdf file found 30-10-2020-attestation-de-deplacement-derogatoire.pdf
[2020-11-27 12:12:35][DEBUG] : pdf file found certificate.301020.pdf
[2020-11-27 12:12:35][DEBUG] : pdf file found certificate_20_11_20.pdf
