Bonjour à tous dans mon log jeedoredeamon j’ai
12/28/2021 08:27:01 - An error occurred while sending the request.
12/28/2021 08:27:13 - An expected message has been received from DeltaDore 1640676387542
12/28/2021 08:27:13 - Sending DeltaDore response to Jeedom, command : 'box'...
12/28/2021 08:27:14 - Command 'Info' has been posted to Jeedom successfully!
12/28/2021 08:36:27 - Sending command 1640676987514 to DeltaDore....
12/28/2021 08:36:27 - An expected message has been received from DeltaDore 1640676987514
12/28/2021 08:36:27 - Sending DeltaDore response to Jeedom, command : 'box'...
12/28/2021 08:36:27 - Command 'Info' has been posted to Jeedom successfully!
12/28/2021 08:46:27 - Sending command 1640677587514 to DeltaDore....
12/28/2021 08:46:27 - An expected message has been received from DeltaDore 1640677587514
12/28/2021 08:46:27 - Sending DeltaDore response to Jeedom, command : 'box'...
12/28/2021 08:46:27 - Command 'Info' has been posted to Jeedom successfully!
12/28/2021 08:56:27 - Sending command 1640678187514 to DeltaDore....
12/28/2021 08:56:27 - An expected message has been received from DeltaDore 1640678187514
12/28/2021 08:56:27 - Sending DeltaDore response to Jeedom, command : 'box'...
12/28/2021 08:56:27 - Command 'Info' has been posted to Jeedom successfully!
12/28/2021 09:06:27 - Sending command 1640678787514 to DeltaDore....
12/28/2021 09:06:27 - An expected message has been received from DeltaDore 1640678787514
12/28/2021 09:06:27 - Sending DeltaDore response to Jeedom, command : 'box'...
12/28/2021 09:06:27 - Command 'Info' has been posted to Jeedom successfully!
12/28/2021 09:16:27 - Sending command 1640679387516 to DeltaDore....
12/28/2021 09:16:27 - An expected message has been received from DeltaDore 1640679387516
12/28/2021 09:16:27 - Sending DeltaDore response to Jeedom, command : 'box'...
12/28/2021 09:16:27 - Command 'Info' has been posted to Jeedom successfully!
12/28/2021 09:26:27 - Sending command 1640679987516 to DeltaDore....
12/28/2021 09:26:27 - An expected message has been received from DeltaDore 1640679987516
12/28/2021 09:26:27 - Sending DeltaDore response to Jeedom, command : 'box'...
12/28/2021 09:26:27 - Command 'Info' has been posted to Jeedom successfully!
12/28/2021 09:36:27 - Sending command 1640680587519 to DeltaDore....
12/28/2021 09:36:27 - An expected message has been received from DeltaDore 1640680587519
12/28/2021 09:36:27 - Sending DeltaDore response to Jeedom, command : 'box'...
12/28/2021 09:36:27 - Command 'Info' has been posted to Jeedom successfully!
12/28/2021 09:46:27 - Sending command 1640681187514 to DeltaDore....
12/28/2021 09:46:27 - An expected message has been received from DeltaDore 1640681187514
12/28/2021 09:46:27 - Sending DeltaDore response to Jeedom, command : 'box'...
12/28/2021 09:46:27 - Command 'Info' has been posted to Jeedom successfully!
12/28/2021 09:56:27 - Sending command 1640681787515 to DeltaDore....
12/28/2021 09:56:27 - An expected message has been received from DeltaDore 1640681787515
12/28/2021 09:56:27 - Sending DeltaDore response to Jeedom, command : 'box'...
12/28/2021 09:56:27 - Command 'Info' has been posted to Jeedom successfully!
12/28/2021 10:06:27 - Sending command 1640682387514 to DeltaDore....
12/28/2021 10:06:27 - An expected message has been received from DeltaDore 1640682387514
12/28/2021 10:06:27 - Sending DeltaDore response to Jeedom, command : 'box'...
12/28/2021 10:06:27 - Command 'Info' has been posted to Jeedom successfully!
12/28/2021 10:16:27 - Sending command 1640682987514 to DeltaDore....
12/28/2021 10:16:27 - An expected message has been received from DeltaDore 1640682987514
12/28/2021 10:16:27 - Sending DeltaDore response to Jeedom, command : 'box'...
12/28/2021 10:16:27 - Command 'Info' has been posted to Jeedom successfully!
12/28/2021 10:26:27 - Sending command 1640683587514 to DeltaDore....
12/28/2021 10:26:27 - An expected message has been received from DeltaDore 1640683587514
12/28/2021 10:26:27 - Sending DeltaDore response to Jeedom, command : 'box'...
12/28/2021 10:26:27 - Command 'Info' has been posted to Jeedom successfully!
12/28/2021 10:36:27 - Sending command 1640684187513 to DeltaDore....
12/28/2021 10:36:27 - An expected message has been received from DeltaDore 1640684187513
12/28/2021 10:36:27 - Sending DeltaDore response to Jeedom, command : 'box'...
12/28/2021 10:36:27 - Command 'Info' has been posted to Jeedom successfully!
12/28/2021 10:46:27 - Sending command 1640684787514 to DeltaDore....
12/28/2021 10:46:27 - An expected message has been received from DeltaDore 1640684787514
12/28/2021 10:46:27 - Sending DeltaDore response to Jeedom, command : 'box'...
12/28/2021 10:46:27 - Command 'Info' has been posted to Jeedom successfully!
12/28/2021 10:56:27 - Sending command 1640685387514 to DeltaDore....
12/28/2021 10:56:27 - An expected message has been received from DeltaDore 1640685387514
12/28/2021 10:56:27 - Sending DeltaDore response to Jeedom, command : 'box'...
12/28/2021 10:56:27 - Command 'Info' has been posted to Jeedom successfully!
12/28/2021 11:06:27 - Sending command 1640685987517 to DeltaDore....
12/28/2021 11:06:27 - An expected message has been received from DeltaDore 1640685987517
12/28/2021 11:06:27 - Sending DeltaDore response to Jeedom, command : 'box'...
12/28/2021 11:06:27 - Command 'Info' has been posted to Jeedom successfully!
12/28/2021 11:16:27 - Sending command 1640686587516 to DeltaDore....
12/28/2021 11:16:27 - An expected message has been received from DeltaDore 1640686587516
12/28/2021 11:16:27 - Sending DeltaDore response to Jeedom, command : 'box'...
12/28/2021 11:16:27 - Command 'Info' has been posted to Jeedom successfully!
12/28/2021 11:26:27 - Sending command 1640687187517 to DeltaDore....
12/28/2021 11:26:27 - An expected message has been received from DeltaDore 1640687187517
12/28/2021 11:26:27 - Sending DeltaDore response to Jeedom, command : 'box'...
12/28/2021 11:26:27 - Command 'Info' has been posted to Jeedom successfully!
jeedom 4.1.28 rpi 3b amr64
