je post une partie du log pour m’aider à résoudre mon problème.
Je précise première installe avec version beta - testé avec stable même problème.
Starting new HTTPS connection (1): raw.githubusercontent.com:443
[2023-07-23 06:12:12]DEBUG : ConnectionThread : https://raw.githubusercontent.com:443 "GET /Mips2648/servers-list/main/ip?v=c86e1a42-a1f3-4506-958c-8c662b4af486 HTTP/1.1" 200 109
[2023-07-23 06:12:12]DEBUG : ConnectionThread : list from github: ['52.19.21.230', '34.251.177.90', '63.33.85.181', '54.154.127.85', '63.33.174.219', '54.194.192.138', '34.251.156.146', '108.129.51.6', '34.243.27.151', '52.17.147.35', '34.243.17.90', '52.212.121.142']
[2023-07-23 06:12:15]WARNING : ConnectionThread : 52.212.121.142 is invalid: timed out
[2023-07-23 06:12:15]WARNING : ConnectionThread : 34.243.27.151 is invalid: ("hostname 'ocapi-app.arlo.com' doesn't match either of 'biilz.com', '*.biilz.com'",)
[2023-07-23 06:12:15]WARNING : ConnectionThread : 54.194.192.138 is invalid: ("hostname 'ocapi-app.arlo.com' doesn't match '*.odis-remote-qs1.vwapps.run'",)
[2023-07-23 06:12:15]WARNING : ConnectionThread : 34.251.156.146 is invalid: ("hostname 'ocapi-app.arlo.com' doesn't match '*.euwest-1-https-canary.waf.aws.dev'",)
[2023-07-23 06:12:15]WARNING : ConnectionThread : 54.154.127.85 is invalid: ("hostname 'ocapi-app.arlo.com' doesn't match either of 'loadapp.kiwaimpact.com', 'loadapi.kiwaimpact.com'",)
[2023-07-23 06:12:15]WARNING : ConnectionThread : 52.17.147.35 is invalid: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self signed certificate in certificate chain (_ssl.c:1056)
[2023-07-23 06:12:15]DEBUG : ConnectionThread : Found candidate, testing availability
[2023-07-23 06:12:15]DEBUG : ConnectionThread : Starting new HTTPS connection (1): 34.243.17.90:443
[2023-07-23 06:12:15]DEBUG : ConnectionThread : https://34.243.17.90:443 "POST /api/auth HTTP/1.1" 200 240
[2023-07-23 06:12:15]INFO : ConnectionThread : Selected backup authentication host 34.243.17.90
[2023-07-23 06:12:15]DEBUG : ConnectionThread : ip mode
[2023-07-23 06:53:03][DEBUG] : Heartbeat: no check, daemon started less than 3 minutes ago
[2023-07-23 06:59:14][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=arlo function=pre_update callInstallFunction=1
[2023-07-23 06:59:16][INFO] : Début d'activation du plugin
[2023-07-23 06:59:19][INFO] : Info sur le démon : {"log":"arlo","state":"nok","launchable":"ok","launchable_message":"Gestion automatique d\u00e9sactiv\u00e9e","auto":"0","last_launch":"2023-07-23 06:50:10"}
[2023-07-23 06:59:19][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=arlo function=update callInstallFunction=1
[2023-07-23 06:59:23][INFO] : Lancement démon
[2023-07-23 06:59:24][DEBUG] : test from daemon
[2023-07-23 07:01:50][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=arlo function=pre_update callInstallFunction=1
[2023-07-23 07:01:53][INFO] : Début d'activation du plugin
[2023-07-23 07:01:56][INFO] : Info sur le démon : {"log":"arlo","state":"nok","launchable":"ok","launchable_message":"Gestion automatique d\u00e9sactiv\u00e9e","auto":"0","last_launch":"2023-07-23 06:50:10"}
[2023-07-23 07:01:56][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=arlo function=update callInstallFunction=1
[2023-07-23 07:02:00][INFO] : Lancement démon
[2023-07-23 07:02:01][DEBUG] : test from daemon
[2023-07-23 07:03:12][INFO] : Lancement démon
[2023-07-23 07:03:13][DEBUG] : test from daemon
[2023-07-23 07:04:03][DEBUG] : Heartbeat: no check, daemon started less than 3 minutes ago
Peux-tu copier/coller le contenu dans un Texte préformaté comme sur le premier post stp ?
Je suis sur mobile et c’est nettement plus simple pour moi pour lire le log.
bonsoir, ok je mettrais mes copies de log comme j’ai fait précédemment.
En faite la je me rencontre que le démon ne démarre pas.
J’ai crée une adresse gmail comme demandé dans la doc. créé un mot de passe pour l’application … donc là je ne vois pas ce qui cloche.
il faut bien mettre la même adresse mail pour les 2 authentifications, on est d’accord ?
pour info j’étais au vert pour le démon à mon premier post !
On se connecte à arlo avec un compte mail et arlo va envoyer le code sur ce mail donc oui il faut que le plugin se connecte ensuite sur cette boîte mail.
Bonjour Mips,
Alors j’ai crée une nouvelle adresse mail spéciale jeedom sur gmail donc sans vérification en 2 étapes (enfin non activé) et voici mon log car le démon ne démarre pas.
j’ai bien rajouté sur mon compte arlo principal cette nouvelle adresse, enfin suivi la doc.
[2023-07-24 05:28:26]INFO : MainThread : Start daemon
[2023-07-24 05:28:26]INFO : MainThread : Log level : debug
[2023-07-24 05:28:26]DEBUG : MainThread : Socket port : 55064
[2023-07-24 05:28:26]DEBUG : MainThread : Socket host : localhost
[2023-07-24 05:28:26]DEBUG : MainThread : PID file : /tmp/jeedom/arlo/daemon.pid
[2023-07-24 05:28:26]DEBUG : MainThread : Writing PID 8190 to /tmp/jeedom/arlo/daemon.pid
[2023-07-24 05:28:26]DEBUG : MainThread : Init request module v2.31.0
[2023-07-24 05:28:26]DEBUG : MainThread : Starting new HTTP connection (1): 127.0.0.1:80
[2023-07-24 05:28:26]DEBUG : MainThread : http://127.0.0.1:80 "GET /plugins/arlo/core/php/jeeArlo.php?test=1&apikey=EKAb2Yc6OhYJ8v8pTUllmrqd0kqYfFSxLWQgeX2klxWIrpP7lG7OSw9KntyDWFYB HTTP/1.1" 200 2
[2023-07-24 05:28:26]INFO : MainThread : ffmpeg loglevel: debug->debug
[2023-07-24 05:28:26]INFO : ConnectionThread : Init connection...
[2023-07-24 05:28:26]INFO : MainThread : Start listening
[2023-07-24 05:28:26]DEBUG : ConnectionThread : session file not read
[2023-07-24 05:28:26]DEBUG : ConnectionThread : user agent used:Mozilla/5.0 (iPhone; CPU iPhone OS 11_1_2 like Mac OS X) AppleWebKit/604.3.5 (KHTML, like Gecko) Mobile/15B202 NETGEAR/v1 (iOS Vuezone)
[2023-07-24 05:28:26]DEBUG : ConnectionThread : old session, getting a new one
[2023-07-24 05:28:26]INFO : ConnectionThread : cloudscraper version:1.2.71
[2023-07-24 05:28:26]DEBUG : MainThread : Socket interface started
[2023-07-24 05:28:26]DEBUG : Thread-1 : LoopNetServer Thread started
[2023-07-24 05:28:26]DEBUG : Thread-1 : Listening on: [localhost:55064]
[2023-07-24 05:28:26]DEBUG : ConnectionThread : Starting new HTTPS connection (1): ocapi-app.arlo.com:443
[2023-07-24 05:28:26]DEBUG : ConnectionThread : https://ocapi-app.arlo.com:443 "OPTIONS /api/auth HTTP/1.1" 403 None
[2023-07-24 05:28:26]WARNING : ConnectionThread : Using fallback authentication host due to: 403 Client Error: Forbidden for url: https://ocapi-app.arlo.com/api/auth
[2023-07-24 05:28:26]DEBUG : ConnectionThread : Starting new HTTPS connection (1): raw.githubusercontent.com:443
[2023-07-24 05:28:26]DEBUG : ConnectionThread : https://raw.githubusercontent.com:443 "GET /Mips2648/servers-list/main/ip?v=7c5a283b-7c2e-4b26-9e10-2acfa2182cfd HTTP/1.1" 200 109
[2023-07-24 05:28:26]DEBUG : ConnectionThread : list from github: ['52.19.21.230', '34.251.177.90', '63.33.85.181', '54.154.127.85', '63.33.174.219', '54.194.192.138', '34.251.156.146', '108.129.51.6', '34.243.27.151', '52.17.147.35', '34.243.17.90', '52.212.121.142']
[2023-07-24 05:28:27]WARNING : ConnectionThread : 34.251.156.146 is invalid: ("hostname 'ocapi-app.arlo.com' doesn't match '*.euwest-1-https-canary.waf.aws.dev'",)
[2023-07-24 05:28:27]WARNING : ConnectionThread : 52.17.147.35 is invalid: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self signed certificate in certificate chain (_ssl.c:1056)
[2023-07-24 05:28:27]WARNING : ConnectionThread : 34.243.27.151 is invalid: ("hostname 'ocapi-app.arlo.com' doesn't match either of 'biilz.com', '*.biilz.com'",)
[2023-07-24 05:28:30]WARNING : ConnectionThread : 34.251.177.90 is invalid: timed out
[2023-07-24 05:28:30]WARNING : ConnectionThread : 63.33.85.181 is invalid: ("hostname 'ocapi-app.arlo.com' doesn't match '*.fundrecs.com'",)
[2023-07-24 05:28:30]DEBUG : ConnectionThread : Found candidate, testing availability
[2023-07-24 05:28:30]DEBUG : ConnectionThread : Starting new HTTPS connection (1): 34.243.17.90:443
[2023-07-24 05:28:30]DEBUG : ConnectionThread : https://34.243.17.90:443 "POST /api/auth HTTP/1.1" 200 240
[2023-07-24 05:28:30]INFO : ConnectionThread : Selected backup authentication host 34.243.17.90
[2023-07-24 05:28:30]DEBUG : ConnectionThread : ip mode
[2023-07-24 05:28:30]DEBUG : ConnectionThread : https://34.243.17.90:443 "OPTIONS /api/auth HTTP/1.1" 204 0
[2023-07-24 05:28:30]DEBUG : ConnectionThread : https://34.243.17.90:443 "POST /api/auth HTTP/1.1" 200 67
[2023-07-24 05:28:30]ERROR : ConnectionThread : Login to Arlo failed. Please check user and password
[2023-07-24 05:28:30]INFO : ConnectionThread : Shutting down daemon
[2023-07-24 05:28:30]DEBUG : ConnectionThread : Removing PID file /tmp/jeedom/arlo/daemon.pid
[2023-07-24 05:28:31]DEBUG : Thread-1 : LoopNetServer Thread stopped
[2023-07-24 05:28:31]DEBUG : ConnectionThread : Exit 0
