Salut @Flobul
Mon log http.error est plein d’erreur remontées sur le plugin. Je n’ai rien dans les log du plugin lui même (suis pas en débug).
ma conf :
jeedom v4.2.12 (VM debian 10 sous proxmox)
plugin smartthing beta v1.096 (2022-02-26 12:16:44)
tout au vert (santé & package)
les erreurs remontées :
[Sun Mar 06 16:57:12.950486 2022] [php7:warn] [pid 15039] [client 192.168.1.91:38688] PHP Warning: Declaration of smartthingsCmd::execute(&$_options = Array) should be compatible with cmd::execute($_options = Array) in /var/www/html/plugins/smartthings/core/class/smartthingsCmd.class.php on line 0, referer: http://192.168.1.3/index.php?v=d&p=administration
[06-Mar-2022 16:56:48 Europe/Brussels] PHP Warning: Declaration of smartthingsCmd::execute(&$_options = Array) should be compatible with cmd::execute($_options = Array) in /var/www/html/plugins/smartthings/core/class/smartthingsCmd.class.php on line 0
[Sun Mar 06 18:01:19.801682 2022] [php7:warn] [pid 27965] [client 192.168.1.91:39896] PHP Warning: Declaration of smartthingsCmd::execute(&$_options = Array) should be compatible with cmd::execute($_options = Array) in /var/www/html/plugins/smartthings/core/class/smartthingsCmd.class.php on line 0, referer: http://192.168.1.3/index.php?v=d&p=dashboard
[Sun Mar 06 18:01:25.071555 2022] [php7:warn] [pid 17975] [client 192.168.1.91:39898] PHP Warning: Declaration of smartthingsCmd::execute(&$_options = Array) should be compatible with cmd::execute($_options = Array) in /var/www/html/plugins/smartthings/core/class/smartthingsCmd.class.php on line 0, referer: http://192.168.1.3/index.php?v=d&p=update
[Sun Mar 06 18:01:33.633385 2022] [php7:warn] [pid 27965] [client 192.168.1.91:39896] PHP Warning: Declaration of smartthingsCmd::execute(&$_options = Array) should be compatible with cmd::execute($_options = Array) in /var/www/html/plugins/smartthings/core/class/smartthingsCmd.class.php on line 253, referer: http://192.168.1.3/index.php?v=d&p=update
[06-Mar-2022 18:01:41 Europe/Brussels] PHP Warning: Declaration of smartthingsCmd::execute(&$_options = Array) should be compatible with cmd::execute($_options = Array) in /var/www/html/plugins/smartthings/core/class/smartthingsCmd.class.php on line 253
(pas forcément dans cet ordre, j’ai fait du ménage pour la lisibilité, là ce sont des lignes « « uniques » »)
'ya un truc avec le passage de l’argument par référence
C’est pas plus em*****t que ça, mais ça rend le log illisible pour le reste!
