Bonsoir j’ai un Zlinky depuis le début du week-end et je viens de jeter un coup d’oeil au log du plugin Zigbee. Il y a quelques erreurs qui remontent de temps à autre pour cet équipement. Quelqu’un aurait une idée ?
Ligne 5057: [2022-02-20 06:09:09][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1295,1288,1290,2312,2568,2314,2570],"allowCache":0} erreur : {"state":"error","result":"[0x8a03:1:0x0b04]: Message send failure","code":0}
Ligne 5058: [2022-02-20 06:09:14][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1293],"allowCache":0} erreur : {"state":"error","result":"[0x8a03:1:0x0b04]: Message send failure","code":0}
Ligne 5059: [2022-02-20 06:09:19][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":65382,"cluster_type":"in","attributes":[1,2,4,5,6,7,8],"allowCache":0} erreur : {"state":"error","result":"[0x8a03:1:0xff66]: Message send failure","code":0}
Ligne 5061: [2022-02-20 06:21:09][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[256,0,258,260,262,264,266],"allowCache":0} erreur : {"state":"error","result":"[0x8a03:1:0x0702]: Message send failure","code":0}
Ligne 5062: [2022-02-20 06:28:10][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[256,0,258,260,262,264,266],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5064: [2022-02-20 06:41:10][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[256,0,258,260,262,264,266],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5065: [2022-02-20 06:42:10][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[256,0,258,260,262,264,266],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5067: [2022-02-20 06:49:11][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":65382,"cluster_type":"in","attributes":[1,2,4,5,6,7,8],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5068: [2022-02-20 06:52:13][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1295,1288,1290,2312,2568,2314,2570],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5069: [2022-02-20 06:53:10][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1295,1288,1290,2312,2568,2314,2570],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5070: [2022-02-20 06:53:15][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":65382,"cluster_type":"in","attributes":[1,2,4,5,6,7,8],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5071: [2022-02-20 06:54:11][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1295,1288,1290,2312,2568,2314,2570],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5073: [2022-02-20 07:07:10][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1295,1288,1290,2312,2568,2314,2570],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5074: [2022-02-20 07:12:10][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1293],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5076: [2022-02-20 07:16:28][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[256,0,258,260,262,264,266],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5078: [2022-02-20 07:33:10][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[256,0,258,260,262,264,266],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5079: [2022-02-20 07:35:10][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[256,0,258,260,262,264,266],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5091: [2022-02-20 10:15:11][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[256,0,258,260,262,264,266],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5092: [2022-02-20 10:18:10][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[256,0,258,260,262,264,266],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5094: [2022-02-20 10:30:13][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":65382,"cluster_type":"in","attributes":[1,2,4,5,6,7,8],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5097: [2022-02-20 11:01:07][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[256,0,258,260,262,264,266],"allowCache":0} erreur : {"state":"error","result":"[0x8a03:1:0x0702]: Message send failure","code":0}
Ligne 5099: [2022-02-20 11:19:10][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1295,1288,1290,2312,2568,2314,2570],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5100: [2022-02-20 11:24:10][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1295,1288,1290,2312,2568,2314,2570],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5101: [2022-02-20 11:25:11][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[256,0,258,260,262,264,266],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5102: [2022-02-20 11:27:11][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1295,1288,1290,2312,2568,2314,2570],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5106: [2022-02-20 12:01:09][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[256,0,258,260,262,264,266],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5107: [2022-02-20 12:12:12][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[256,0,258,260,262,264,266],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5110: [2022-02-20 12:30:12][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[32],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5113: [2022-02-20 13:02:11][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[256,0,258,260,262,264,266],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5115: [2022-02-20 13:29:12][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[256,0,258,260,262,264,266],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5117: [2022-02-20 13:31:11][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":65382,"cluster_type":"in","attributes":[1,2,4,5,6,7,8],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5121: [2022-02-20 14:19:10][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[256,0,258,260,262,264,266],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5122: [2022-02-20 14:19:15][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1295,1288,1290,2312,2568,2314,2570],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5124: [2022-02-20 14:36:09][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[256,0,258,260,262,264,266],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5128: [2022-02-20 15:28:11][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[256,0,258,260,262,264,266],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5131: [2022-02-20 15:48:29][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":65382,"cluster_type":"in","attributes":[1,2,4,5,6,7,8],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5132: [2022-02-20 15:55:10][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[256,0,258,260,262,264,266],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5136: [2022-02-20 16:04:10][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[32],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5138: [2022-02-20 16:15:13][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1295,1288,1290,2312,2568,2314,2570],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5139: [2022-02-20 16:26:10][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":65382,"cluster_type":"in","attributes":[1,2,4,5,6,7,8],"allowCache":0} erreur : {"state":"error","result":"","code":0}
Ligne 5141: [2022-02-20 16:38:11][INFO] : [Maison][LiXee.ZLinky] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:15:8d:00:05:d2:85:70","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[32],"allowCache":0} erreur : {"state":"error","result":"","code":0}
