voila le résultat du log « xiaomi home_dep » qui semble etre celui concerné par mon probleme.
0000|********************************************************
0001|* Installation des dépendances *
0002|********************************************************
0003|Get:1 http://security.debian.org/debian-security buster/updates InRelease [65.4 kB]
0004|Hit:2 http://deb.debian.org/debian buster InRelease
0005|Get:3 http://deb.debian.org/debian buster-updates InRelease [51.9 kB]
0006|Fetched 117 kB in 1s (107 kB/s)
0007|Reading package lists...
0008|Installation des dépendances apt
0009|Reading package lists...
0010|Building dependency tree...
0011|Reading state information...
0012|libffi-dev is already the newest version (3.2.1-9).
0013|libssl-dev is already the newest version (1.1.1d-0+deb10u7).
0014|python3-cryptography is already the newest version (2.6.1-3+deb10u2).
0015|python3-pip is already the newest version (18.1-5).
0016|python3-setuptools is already the newest version (40.8.0-1).
0017|python3-dev is already the newest version (3.7.3-1).
0018|0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
0019|Installation du module construct pour python
0020|Collecting construct
0021|Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/construct/
0022|Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/construct/
0023|Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/construct/
0024|Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/construct/
0025|Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/construct/
0026|Could not find a version that satisfies the requirement construct (from versions: )
0027|No matching distribution found for construct
0028|Installation du module pyserial pour python
0029|Collecting pyserial
0030|Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/pyserial/
0031|Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/pyserial/
0032|Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/pyserial/
0033|Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/pyserial/
0034|Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/pyserial/
0035|Could not find a version that satisfies the requirement pyserial (from versions: )
0036|No matching distribution found for pyserial
0037|Installation du module future pour python
0038|Collecting future
0039|Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/future/
0040|Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/future/
0041|Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/future/
0042|Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/future/
0043|Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/future/
0044|Could not find a version that satisfies the requirement future (from versions: )
0045|No matching distribution found for future
0046|Installation du module enum34 pour python
0047|Collecting enum34
0048|Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/enum34/
0049|Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/enum34/
0050|Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/enum34/
0051|Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/enum34/
0052|Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/enum34/
0053|Could not find a version that satisfies the requirement enum34 (from versions: )
0054|No matching distribution found for enum34
0055|Installation du module enum-compat pour python
0056|Collecting enum-compat
0057|Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/enum-compat/
0058|Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/enum-compat/
0059|Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/enum-compat/
0060|Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/enum-compat/
0061|Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/enum-compat/
0062|Could not find a version that satisfies the requirement enum-compat (from versions: )
0063|No matching distribution found for enum-compat
0064|Installation du module yeelight pour python
0065|Collecting yeelight
0066|Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/yeelight/
0067|Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/yeelight/
0068|Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/yeelight/
0069|Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/yeelight/
0070|Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/yeelight/
0071|Could not find a version that satisfies the requirement yeelight (from versions: )
0072|No matching distribution found for yeelight
0073|Installation du module miio pour python
0074|Collecting python-miio
0075|Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/python-miio/
0076|Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError(': Failed to establish a new connection: [Errno 101] Network is unreachable')': /simple/python-miio/
du coup des soucis de connection ?
mais meme si j’avais raison dans mon interprétation, je vois guère quoi modifier / améliorer …
je précise pour la suite : je ne suis pas du tout familier de linux et autre, donc pas e soucis pour les lignes de commande, mais donnez bien toute les précision des lignes de commandes, je ne saurais en écrire une « de moi meme ».
d’avance, merci encore pour votre interet
