* Installation des dépendances *
Hit:1 http://deb.debian.org/debian buster InRelease
Hit:2 http://security.debian.org/debian-security buster/updates InRelease
Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
Hit:4 https://repo.homebridge.io stable InRelease
Reading package lists...
Building dependency tree...
Reading state information...
python3-pip is already the newest version (18.1-5).
python3-setuptools is already the newest version (40.8.0-1).
python3-dev is already the newest version (3.7.3-1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Requirement already satisfied: requests in /usr/local/lib/python3.7/dist-packages (2.31.0)
Requirement already satisfied: charset-normalizer<4,>=2 in /usr/local/lib/python3.7/dist-packages (from requests) (3.3.2)
Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.7/dist-packages (from requests) (3.6)
Requirement already satisfied: urllib3<3,>=1.21.1 in /usr/local/lib/python3.7/dist-packages (from requests) (2.0.7)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.7/dist-packages (from requests) (2023.11.17)
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
Requirement already satisfied: asyncio in /usr/local/lib/python3.7/dist-packages (3.4.3)
Requirement already satisfied: websockets in /usr/local/lib/python3.7/dist-packages (11.0.3)
Requirement already satisfied: aiohttp in /usr/local/lib/python3.7/dist-packages (3.8.6)
Requirement already satisfied: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (23.2.0)
Requirement already satisfied: charset-normalizer<4.0,>=2.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (3.3.2)
Requirement already satisfied: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (6.0.4)
Requirement already satisfied: async-timeout<5.0,>=4.0.0a3 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (4.0.3)
Requirement already satisfied: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (1.9.4)
Requirement already satisfied: frozenlist>=1.1.1 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (1.3.3)
Requirement already satisfied: aiosignal>=1.1.2 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (1.3.1)
Requirement already satisfied: asynctest==0.13.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (0.13.0)
Requirement already satisfied: typing-extensions>=3.7.4 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (4.7.1)
Requirement already satisfied: importlib-metadata in /usr/local/lib/python3.7/dist-packages (from attrs>=17.3.0->aiohttp) (6.7.0)
Requirement already satisfied: idna>=2.0 in /usr/local/lib/python3.7/dist-packages (from yarl<2.0,>=1.0->aiohttp) (3.6)
Requirement already satisfied: zipp>=0.5 in /usr/local/lib/python3.7/dist-packages (from importlib-metadata->attrs>=17.3.0->aiohttp) (3.15.0)
* Installation terminée *
As-tu trouvé une solution ? Je suis dans le même cas de figure depuis aujourd’hui. Suite à des mises à jour (apt update & upgrade) les activités ne sont plus remontées.
Dépendances :
Hit:1 http://ftp.debian.org/debian buster-backports InRelease
Hit:2 http://deb.debian.org/debian stable InRelease
Hit:3 https://download.docker.com/linux/debian bullseye InRelease
Hit:4 http://deb.debian.org/debian stable-updates InRelease
Hit:5 https://packages.sury.org/php bullseye InRelease
Hit:6 http://deb.debian.org/debian-security stable-security/updates InRelease
Hit:7 https://repo.mosquitto.org/debian stretch InRelease
Hit:8 https://deb.nodesource.com/node_18.x nodistro InRelease
Hit:9 http://repo.zabbix.com/zabbix/3.4/debian stretch InRelease
python3-pip is already the newest version (23.0.1+dfsg-1).
python3-dev is already the newest version (3.11.2-1+b1).
python3-setuptools is already the newest version (66.1.1-1).
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
Requirement already satisfied: requests in /usr/local/lib/python3.9/site-packages (2.31.0)
Requirement already satisfied: charset-normalizer<4,>=2 in /usr/local/lib/python3.9/site-packages (from requests) (3.3.2)
Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.9/site-packages (from requests) (3.6)
Requirement already satisfied: urllib3<3,>=1.21.1 in /usr/local/lib/python3.9/site-packages (from requests) (2.2.0)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.9/site-packages (from requests) (2023.11.17)
Requirement already satisfied: asyncio in /usr/local/lib/python3.9/site-packages (3.4.3)
Requirement already satisfied: websockets in /usr/local/lib/python3.9/site-packages (12.0)
Requirement already satisfied: aiohttp in /usr/local/lib/python3.9/site-packages (3.9.3)
Requirement already satisfied: aiosignal>=1.1.2 in /usr/local/lib/python3.9/site-packages (from aiohttp) (1.3.1)
Requirement already satisfied: attrs>=17.3.0 in /usr/local/lib/python3.9/site-packages (from aiohttp) (23.2.0)
Requirement already satisfied: frozenlist>=1.1.1 in /usr/local/lib/python3.9/site-packages (from aiohttp) (1.4.1)
Requirement already satisfied: multidict<7.0,>=4.5 in /usr/local/lib/python3.9/site-packages (from aiohttp) (6.0.4)
Requirement already satisfied: yarl<2.0,>=1.0 in /usr/local/lib/python3.9/site-packages (from aiohttp) (1.9.4)
Requirement already satisfied: async-timeout<5.0,>=4.0 in /usr/local/lib/python3.9/site-packages (from aiohttp) (4.0.3)
Requirement already satisfied: idna>=2.0 in /usr/local/lib/python3.9/site-packages (from yarl<2.0,>=1.0->aiohttp) (3.6)
Mise à jour du fichier de configurations :
[2024-02-02 19:11:26]ALERT : ########Recherche de la config en cours########
[2024-02-02 19:11:26]ALERT : ######### Dispositifs trouvés 192.168.10.90
[2024-02-02 19:11:26]ALERT : ######### Activités trouvées 192.168.10.90
[2024-02-02 19:11:26]ALERT : #### Fin de la recherche 192.168.10.90
Oui, cela refonctionne, mais en passant par la case reset du hub Harmony et reconfiguration complète (les équipements et les scenarios d’allumage et d’extinction) …
