J’utilise le plugin, pour me notifier la mise en service/arret de mon alarme.
Il fonctionne, mais depuis quelque temps, le temps entre l’envoi du mail par l’alarme et la prise en compte par Jeedom est devenu très long.
En vérifiant les log, je trouve :
imapDisconnected
(node:5875) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification.
(Use `nodejs --trace-warnings ...` to show where the warning was created)
imapConnected
Error: This socket has been ended by the other party
at Socket.writeAfterFIN [as write] (node:net:487:14)
at JSStreamSocket.doWrite (node:internal/js_stream_socket:175:19)
at JSStream.onwrite (node:internal/js_stream_socket:33:57)
at TLSSocket.Socket._final (node:net:457:28)
at callFinal (node:internal/streams/writable:694:27)
at prefinish (node:internal/streams/writable:723:7)
at finishMaybe (node:internal/streams/writable:733:5)
at TLSSocket.Writable.end (node:internal/streams/writable:631:5)
at TLSSocket.Socket.end (node:net:631:31) {
code: 'EPIPE',
source: 'socket'
imapDisconnected
(node:9121) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification.
imapConnected
De ce que je comprends, je dois :
Je suis bien incapable de trouver ou faire cela
Si quelqu’un pouvais m’aiguiller
