Ok.
La conf avec une caméra:
"platform": "Camera-ffmpeg",
"cameras": [
"name": "SUD",
"serialNumber": "648-192.168.1.18",
"videoConfig": {
"source": "-fflags +discardcorrupt+igndts -err_detect ignore_err -rtsp_transport tcp -i rtsp://admin:Camxxx1200@192.168.1.18/cam/realmonitor?channel=1&subtype=00&authbasic=YWRtaW46TDIyODc1RjE",
"maxStreams": 2,
"maxWidth": 1920,
"maxHeight": 1080,
"maxFPS": 30,
"vcodec": "libx264",
"audio": true,
"debug": true
J’ai testé avec 15 et 30 fps, le résultat est le meme, après plus de 30s d’attente j’ai ceci que ce soit sur mon tel en 5G ou mon mac.
Les logs pendant que je tente à avoir le flux:
046|[2/19/2024, 9:57:10 AM] [Camera-ffmpeg] [SUD] Snapshot requested: 640 x 360
2047|[2/19/2024, 9:57:10 AM] [Camera-ffmpeg] [SUD] Snapshot command: ffmpeg -fflags +discardcorrupt+igndts -err_detect ignore_err -rtsp_transport tcp -i rtsp://admin:Cam151200@192.168.1.18/cam/realmonitor?channel=1&subtype=00&authbasic=YWRtaW46TDIyODc1RjE -frames:v 1 -f image2 - -hide_banner -loglevel error
2048|[2/19/2024, 9:57:11 AM] [Camera-ffmpeg] [SUD] Fetching snapshot took 1.554 seconds.
2049|[2/19/2024, 9:57:11 AM] [Camera-ffmpeg] [SUD] Sending snapshot: 640 x 360
2050|[2/19/2024, 9:57:11 AM] [Camera-ffmpeg] [SUD] Resize command: ffmpeg -i pipe: -frames:v 1 -filter:v scale='min(640,iw)':'min(360,ih)':force_original_aspect_ratio=decrease -f image2 -
2051|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] Video stream requested: 1280 x 720, 30 fps, 299 kbps
2052|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] Starting video stream: 1280 x 720, 30 fps, 299 kbps (AAC-eld)
2053|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] Stream command: ffmpeg -fflags +discardcorrupt+igndts -err_detect ignore_err -rtsp_transport tcp -i rtsp://admin:Cam151200@192.168.1.18/cam/realmonitor?channel=1&subtype=00&authbasic=YWRtaW46TDIyODc1RjE -an -sn -dn -codec:v libx264 -pix_fmt yuv420p -color_range mpeg -r 30 -f rawvideo -preset ultrafast -tune zerolatency -filter:v scale='min(1280,iw)':'min(720,ih)':force_original_aspect_ratio=decrease,scale=trunc(iw/2)*2:trunc(ih/2)*2 -b:v 299k -payload_type 99 -ssrc 10390372 -f rtp -srtp_out_suite AES_CM_128_HMAC_SHA1_80 -srtp_out_params UG9wJ++OXrzsFoUqSNWsOH1pCOeTahu4UUmd8yey srtp://192.168.1.251:65113?rtcpport=65113&pkt_size=1316 -vn -sn -dn -codec:a libfdk_aac -profile:a aac_eld -flags +global_header -f null -ar 16k -b:a 24k -ac 1 -payload_type 110 -ssrc 7366091 -f rtp -srtp_out_suite AES_CM_128_HMAC_SHA1_80 -srtp_out_params ODFw+zdyBGNYepdH0zSpD2UKy+HG3TURufXA4AxP srtp://192.168.1.251:64076?rtcpport=64076&pkt_size=188 -loglevel level+verbose -progress pipe:1
2054|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] [info] ffmpeg version 4.3.6-0+deb11u1 Copyright (c) 2000-2023 the FFmpeg developers
2055|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] [info] built with gcc 10 (Debian 10.2.1-6)
2056|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] [info] configuration: --prefix=/usr --extra-version=0+deb11u1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-pocketsphinx --enable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
2057|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] [info] libavutil 56. 51.100 / 56. 51.100
2058|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] [info] libavcodec 58. 91.100 / 58. 91.100
2059|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] [info] libavformat 58. 45.100 / 58. 45.100
2060|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] [info] libavdevice 58. 10.100 / 58. 10.100
2061|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] [info] libavfilter 7. 85.100 / 7. 85.100
2062|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] [info] libavresample 4. 0. 0 / 4. 0. 0
2063|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] [info] libswscale 5. 7.100 / 5. 7.100
2064|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] [info] libswresample 3. 7.100 / 3. 7.100
2065|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] [info] libpostproc 55. 7.100 / 55. 7.100
2066|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] [verbose] Routing option err_detect to both codec and muxer layer
2067|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] [tcp @ 0x55f42a394ac0] [verbose] Starting connection attempt to 192.168.1.18 port 554
2068|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] [tcp @ 0x55f42a394ac0] [verbose] Successfully connected to 192.168.1.18 port 554
2069|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] [rtsp @ 0x55f42a392900] [verbose] SDP:
2070|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] v=0
2071|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] o=- 2229913047 2229913047 IN IP4 0.0.0.0
2072|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] s=Media Server
2073|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] c=IN IP4 0.0.0.0
2074|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] t=0 0
2075|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] a=control:*
2076|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] a=packetization-supported:DH
2077|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] a=rtppayload-supported:DH
2078|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] a=range:npt=now-
2079|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] m=video 0 RTP/AVP 98
2080|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] a=control:trackID=0
2081|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] a=framerate:25.000000
2082|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] a=rtpmap:98 H265/90000
2083|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] a=fmtp:98 profile-id=1;sprop-sps=QgEBAUAAAAMAAAMAAAMAAAMAmaADwIARB8uWu5Gwa5VE2BAAAAMAEAAAAwGQgA==;sprop-pps=RAHAc8BMkA==;sprop-vps=QAEMAf//AUAAAAMAAAMAAAMAAAMAmawJ
2084|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] a=recvonly
2085|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] m=audio 0 RTP/AVP 97
2086|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] a=control:trackID=1
2087|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] a=rtpmap:97 MPEG4-GENERIC/16000
2088|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] a=fmtp:97 streamtype=5;profile-level-id=1;mode=AAC-hbr;sizelength=13;indexlength=3;indexdeltalength=3;config=1408
2089|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] a=recvonly
2090|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD]
2091|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] [rtsp @ 0x55f42a392900] [verbose] setting jitter buffer size to 0
2092|[2/19/2024, 9:57:16 AM] [Camera-ffmpeg] [SUD] [rtsp @ 0x55f42a392900] [verbose] setting jitter buffer size to 0
2093|[2/19/2024, 9:57:17 AM] [Camera-ffmpeg] [SUD] [info] Input #0, rtsp, from 'rtsp://admin:Cam151200@192.168.1.18/cam/realmonitor?channel=1&subtype=00&authbasic=YWRtaW46TDIyODc1RjE':
2094|[2/19/2024, 9:57:17 AM] [Camera-ffmpeg] [SUD] [info] Metadata:
2095|[2/19/2024, 9:57:17 AM] [Camera-ffmpeg] [SUD] [info] title : Media Server
2096|[2/19/2024, 9:57:17 AM] [Camera-ffmpeg] [SUD] [info] Duration: N/A, start: 0.000000, bitrate: N/A
2097|[2/19/2024, 9:57:17 AM] [Camera-ffmpeg] [SUD] [info] Stream #0:0: Video: hevc (Main), 1 reference frame, yuvj420p(pc), 1920x1080 (1920x1088), 25 fps, 25 tbr, 90k tbn, 25 tbc
2098|[2/19/2024, 9:57:17 AM] [Camera-ffmpeg] [SUD] [info] Stream #0:1: Audio: aac (LC), 16000 Hz, mono, fltp
2099|[2/19/2024, 9:57:17 AM] [Camera-ffmpeg] [SUD] [fatal] Unknown encoder 'libfdk_aac'
2100|[2/19/2024, 9:57:17 AM] [Camera-ffmpeg] [SUD] [AVIOContext @ 0x55f42a39fb00] [verbose] Statistics: 0 seeks, 0 writeouts
2101|[2/19/2024, 9:57:17 AM] [Camera-ffmpeg] [SUD] FFmpeg exited with code: 1 and signal: null (Error)
2102|[2/19/2024, 9:57:17 AM] [Camera-ffmpeg] [SUD] Stopped video stream.
2112|[2/19/2024, 9:58:07 AM] [Camera-ffmpeg] [SUD] Snapshot requested: 640 x 360
2113|[2/19/2024, 9:58:07 AM] [Camera-ffmpeg] [SUD] Snapshot command: ffmpeg -fflags +discardcorrupt+igndts -err_detect ignore_err -rtsp_transport tcp -i rtsp://admin:Cam151200@192.168.1.18/cam/realmonitor?channel=1&subtype=00&authbasic=YWRtaW46TDIyODc1RjE -frames:v 1 -f image2 - -hide_banner -loglevel error
2114|[2/19/2024, 9:58:19 AM] [Camera-ffmpeg] [SUD] Snapshot requested: 640 x 360
2115|[2/19/2024, 9:58:19 AM] [Camera-ffmpeg] [SUD] Snapshot command: ffmpeg -fflags +discardcorrupt+igndts -err_detect ignore_err -rtsp_transport tcp -i rtsp://admin:Cam151200@192.168.1.18/cam/realmonitor?channel=1&subtype=00&authbasic=YWRtaW46TDIyODc1RjE -frames:v 1 -f image2 - -hide_banner -loglevel error
2116|[2/19/2024, 9:58:20 AM] [Camera-ffmpeg] [SUD] Fetching snapshot took 1.319 seconds.
2117|[2/19/2024, 9:58:20 AM] [Camera-ffmpeg] [SUD] Sending snapshot: 640 x 360
2118|[2/19/2024, 9:58:20 AM] [Camera-ffmpeg] [SUD] Resize command: ffmpeg -i pipe: -frames:v 1 -filter:v scale='min(640,iw)':'min(360,ih)':force_original_aspect_ratio=decrease -f image2 -
2119|[2/19/2024, 9:58:30 AM] [Camera-ffmpeg] [SUD] Snapshot requested: 640 x 360
2120|[2/19/2024, 9:58:30 AM] [Camera-ffmpeg] [SUD] Snapshot command: ffmpeg -fflags +discardcorrupt+igndts -err_detect ignore_err -rtsp_transport tcp -i rtsp://admin:Cam151200@192.168.1.18/cam/realmonitor?channel=1&subtype=00&authbasic=YWRtaW46TDIyODc1RjE -frames:v 1 -f image2 - -hide_banner -loglevel error
2121|[2/19/2024, 9:58:32 AM] [Camera-ffmpeg] [SUD] Fetching snapshot took 1.242 seconds.
2122|[2/19/2024, 9:58:32 AM] [Camera-ffmpeg] [SUD] Sending snapshot: 640 x 360
2123|[2/19/2024, 9:58:32 AM] [Camera-ffmpeg] [SUD] Resize command: ffmpeg -i pipe: -frames:v 1 -filter:v scale='min(640,iw)':'min(360,ih)':force_original_aspect_ratio=decrease -f image2 -
2124|[2/19/2024, 9:58:42 AM] [Camera-ffmpeg] [SUD] Snapshot requested: 640 x 360
2125|[2/19/2024, 9:58:42 AM] [Camera-ffmpeg] [SUD] Snapshot command: ffmpeg -fflags +discardcorrupt+igndts -err_detect ignore_err -rtsp_transport tcp -i rtsp://admin:Cam151200@192.168.1.18/cam/realmonitor?channel=1&subtype=00&authbasic=YWRtaW46TDIyODc1RjE -frames:v 1 -f image2 - -hide_banner -loglevel error
2126|[2/19/2024, 9:58:43 AM] [Camera-ffmpeg] [SUD] Fetching snapshot took 1.234 seconds.
2127|[2/19/2024, 9:58:43 AM] [Camera-ffmpeg] [SUD] Sending snapshot: 640 x 360
2128|[2/19/2024, 9:58:43 AM] [Camera-ffmpeg] [SUD] Resize command: ffmpeg -i pipe: -frames:v 1 -filter:v scale='min(640,iw)':'min(360,ih)':force_original_aspect_ratio=decrease -f image2 -
2129|[2/19/2024, 9:58:54 AM] [Camera-ffmpeg] [SUD] Snapshot requested: 640 x 360
2130|[2/19/2024, 9:58:54 AM] [Camera-ffmpeg] [SUD] Snapshot command: ffmpeg -fflags +discardcorrupt+igndts -err_detect ignore_err -rtsp_transport tcp -i rtsp://admin:Cam151200@192.168.1.18/cam/realmonitor?channel=1&subtype=00&authbasic=YWRtaW46TDIyODc1RjE -frames:v 1 -f image2 - -hide_banner -loglevel error
2131|[2/19/2024, 9:58:55 AM] [Camera-ffmpeg] [SUD] Fetching snapshot took 1.253 seconds.
2132|[2/19/2024, 9:58:55 AM] [Camera-ffmpeg] [SUD] Sending snapshot: 640 x 360
2133|[2/19/2024, 9:58:55 AM] [Camera-ffmpeg] [SUD] Resize command: ffmpeg -i pipe: -frames:v 1 -filter:v scale='min(640,iw)':'min(360,ih)':force_original_aspect_ratio=decrease -f image2 -
2134|[2/19/2024, 9:59:05 AM] [Camera-ffmpeg] [SUD] Snapshot requested: 640 x 360
2135|[2/19/2024, 9:59:05 AM] [Camera-ffmpeg] [SUD] Snapshot command: ffmpeg -fflags +discardcorrupt+igndts -err_d
Est ce que je peux regarder ailleurs pour un début de piste ?
