Suite à la migration de Jeedom vers Debian 12, il n’y a plus de dépendances.
Merci de me tenir informé de la procédure à suivre afin que le plugin puisse fonctionner correctement.
* Installation des dépendances *
Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
Hit:2 https://deb.nodesource.com/node_22.x nodistro InRelease
Hit:3 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
Reading package lists...
W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
error: externally-managed-environment
× This environment is externally managed
╰─> To install Python packages system-wide, try apt install
python3-xyz, where xyz is the package you are trying to
install.
If you wish to install a non-Debian-packaged Python package,
create a virtual environment using python3 -m venv path/to/venv.
Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
sure you have python3-full installed.
For more information visit http://rptl.io/venv
note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
hint: See PEP 668 for the detailed specification.
Building dependency tree...
Reading state information...
Package 'python3-serial' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
python3-pip is already the newest version (23.0.1+dfsg-1+rpt1).
python3 is already the newest version (3.11.2-1).
python3-requests is already the newest version (2.28.1+dfsg-1).
python3-pyudev is already the newest version (0.24.0-1).
install.
Lancement de la synchronisation des templates LegrandIoblMyhome
Changement du répertoire courant
Récupération des templates (cette étape peut durer quelques minutes)
Cloning into 'pluginjeedom-legrandioblmyhomePub'...
Suppression des templates LegrandIoblMyhome existants
Recopie des nouveaux templates LegrandIoblMyhome
Nettoyage du répertoire temporaire
Vos templates sont maintenant à jour !
* Installation terminée *
Informations Jeedom
Core : 4.5.2 (master)
DNS Jeedom : non
Plugin : Legrand IOBL and MyHome
Version : 2025-06-15 01:01:28 (beta)
Statut Démon : Stoppé - (Inconnue)
