quand je fais dimmer_on j’ai ça >>
Error 2024-07-23 00:54:11z2m: Failed to configure '0x000474000025adfe', attempt 3 (Error: Device 0x000474000025adfe has no input cluster genLevelCtrl at getEndpointsWithCluster (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:57:15) at setupAttributes (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:98:55) at configure (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:1006:23) at Object.configure (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman-converters/src/index.ts:190:21) at Configure.configure (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/extension/configure.ts:126:13) at EventEmitter.wrappedCallback (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/eventBus.ts:174:17))
Error 2024-07-23 00:56:25z2m: Publish 'set' 'device_mode' to '0x000474000025adfe' failed: 'Error: ZCL command 0x000474000025adfe/1 manuSpecificLegrandDevices.write({"0":{"value":257,"type":9}}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":4129,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Status 'UNSUPPORTED_ATTRIBUTE')'
Error 2024-07-23 00:56:32z2m: Publish 'set' 'device_mode' to '0x000474000025adfe' failed: 'Error: ZCL command 0x000474000025adfe/1 manuSpecificLegrandDevices.write({"0":{"value":256,"type":9}}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":4129,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Status 'UNSUPPORTED_ATTRIBUTE')'
Error 2024-07-23 00:56:35z2m: Publish 'set' 'device_mode' to '0x000474000025adfe' failed: 'Error: ZCL command 0x000474000025adfe/1 manuSpecificLegrandDevices.write({"0":{"value":257,"type":9}}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":4129,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Status 'UNSUPPORTED_ATTRIBUTE')'
j’ai ré-ré-appairé plusieurs fois c’est pareil
