Je suis en train de remonter un Jeedom V4.3.22 en Debian 11
J’ai un soucis avec le plugin Google Cast.
Les dépendances indiquent « OK »
Les log Cooglecast_Update
Launch install of googlecast dependancies
-- Current OS version :
Description: Debian GNU/Linux 11 (bullseye)
-- Updating repo...
Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
Hit:2 http://deb.debian.org/debian bullseye InRelease
Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
Reading package lists...
-- Installation of python3 and dependancies
Building dependency tree...
Reading state information...
python3 is already the newest version (3.9.2-3).
python-dev-is-python2 is already the newest version (2.7.18-9).
0 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
-- Installed version of Python :
Python 3.9.2
Your version of python is compatible with this plugin.
-- Installation of pip for python3 and necessary libraries
E: Unable to locate package python-requests
-- Installation of audio sox library
sox is already the newest version (14.4.2+git20190427-2+deb11u2).
-- Installation of TTS libraries
libttspico-utils is already the newest version (1.0+git20130326-11).
-- Installation of libav/ffmpeg libraries
ffmpeg is already the newest version (7:4.3.6-0+deb11u1).
-- Upgrade setuptools with command pip3.9 if not up to date
DEPRECATION: gpg 1.14.0-unknown has a non-standard version number. pip 24.0 will enforce this behaviour change. A possible replacement is to upgrade to a newer version of gpg or contact the author to suggest that they release a version with a conforming version number. Discussion can be found at https://github.com/pypa/pip/issues/12063
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
Requirement already satisfied: setuptools>=42.0.0 in /usr/local/lib/python3.9/dist-packages (69.0.3)
-- Installed version of pip :
pip 23.3.2 from /usr/local/lib/python3.9/dist-packages/pip (python 3.9)
-- Installation of python library 'requests' with command pip3.9
Requirement already satisfied: requests>=2.21.0 in /usr/local/lib/python3.9/dist-packages (2.31.0)
Requirement already satisfied: charset-normalizer<4,>=2 in /usr/local/lib/python3.9/dist-packages (from requests>=2.21.0) (3.3.2)
Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.9/dist-packages (from requests>=2.21.0) (3.6)
Requirement already satisfied: urllib3<3,>=1.21.1 in /usr/local/lib/python3.9/dist-packages (from requests>=2.21.0) (2.1.0)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.9/dist-packages (from requests>=2.21.0) (2023.11.17)
-- Installation of python library 'protobuf' with command pip3.9
Requirement already satisfied: protobuf>=3.11.0 in /usr/local/lib/python3.9/dist-packages (4.25.1)
-- Installation of python library 'zeroconf' with command pip3.9
Requirement already satisfied: zeroconf==0.31.0 in /usr/local/lib/python3.9/dist-packages (0.31.0)
Requirement already satisfied: ifaddr>=0.1.7 in /usr/local/lib/python3.9/dist-packages (from zeroconf==0.31.0) (0.2.0)
-- Installation of python library 'click, bs4 and six' for TTS with command pip3.9
Requirement already satisfied: click in /usr/local/lib/python3.9/dist-packages (8.1.7)
Requirement already satisfied: bs4 in /usr/local/lib/python3.9/dist-packages (0.0.1)
Requirement already satisfied: six in /usr/local/lib/python3.9/dist-packages (1.16.0)
Requirement already satisfied: beautifulsoup4 in /usr/lib/python3/dist-packages (from bs4) (4.9.3)
Requirement already satisfied: soupsieve>1.2 in /usr/lib/python3/dist-packages (from beautifulsoup4->bs4) (2.2.1)
-- Installation of python library 'tqdm, websocket-client, casttube' for plex/youtube with command pip3.9
Requirement already satisfied: tqdm in /usr/local/lib/python3.9/dist-packages (4.66.1)
Requirement already satisfied: websocket-client in /usr/local/lib/python3.9/dist-packages (1.7.0)
Requirement already satisfied: casttube in /usr/local/lib/python3.9/dist-packages (0.2.1)
Requirement already satisfied: requests in /usr/local/lib/python3.9/dist-packages (from casttube) (2.31.0)
Requirement already satisfied: charset-normalizer<4,>=2 in /usr/local/lib/python3.9/dist-packages (from requests->casttube) (3.3.2)
Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.9/dist-packages (from requests->casttube) (3.6)
Requirement already satisfied: urllib3<3,>=1.21.1 in /usr/local/lib/python3.9/dist-packages (from requests->casttube) (2.1.0)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.9/dist-packages (from requests->casttube) (2023.11.17)
-- Installation of dependencies is done !
Les log Cooglecast_Local
File "/var/www/html/plugins/googlecast/resources/googlecast.py", line 45, in <module>
import pychromecast.pychromecast as pychromecast
File "/var/www/html/plugins/googlecast/resources/pychromecast/pychromecast/__init__.py", line 14, in <module>
from . import socket_client
File "/var/www/html/plugins/googlecast/resources/pychromecast/pychromecast/socket_client.py", line 23, in <module>
from . import cast_channel_pb2
File "/var/www/html/plugins/googlecast/resources/pychromecast/pychromecast/cast_channel_pb2.py", line 33, in <module>
_descriptor.EnumValueDescriptor(
File "/usr/local/lib/python3.9/dist-packages/google/protobuf/descriptor.py", line 789, in __new__
_message.Message._CheckCalledFromGeneratedFile()
TypeError: Descriptors cannot be created directly.
If this call came from a _pb2.py file, your generated code is out of date and must be regenerated with protoc >= 3.19.0.
If you cannot immediately regenerate your protos, some other possible workarounds are:
1. Downgrade the protobuf package to 3.20.x or lower.
2. Set PROTOCOL_BUFFERS_PYTHON_IMPLEMENTATION=python (but this will use pure-Python parsing and will be much slower).
More information: https://developers.google.com/protocol-buffers/docs/news/2022-05-06#python-updates
La page santé
De ce que je comprends, il me semble que certaine chose sont à faire, mais je suis incapable de comprendre quoi ![]()
(Le second plugin NOK est WebOs TV, mais je verrais ça plus tard)
