Merci bien pour le soutien.
En fait je pense qu j’ai le même souci que ici, les dépendances du plugin pyenv4jeedom ne s’installent pas correctement.
Néanmoins j’arrive bien à la finalité citée plus haut, à savoir que pyenv est installé (page pluginbpyenv4Jeedom).
Mais l’installation des dépendances dans le plugin MyModbus ne fonctionne toujours pas:
+ touch /tmp/jeedom_install_in_progress_mymodbus
+ echo 1
+ echo 2
apt: no process found
apt-get: no process found
+ sudo apt update
Get:1 http://security.debian.org/debian-security buster/updates InRelease [34.8 kB]
Get:2 http://deb.debian.org/debian buster InRelease [122 kB]
Get:3 http://deb.debian.org/debian buster-updates InRelease [56.6 kB]
Get:4 https://repos.influxdata.com/debian buster InRelease [12.9 kB]
Ign:5 https://packages.grafana.com/oss/deb stable InRelease
Err:6 https://packages.grafana.com/oss/deb stable Release
Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate. Could not handshake: Error in the certificate verification. [IP: 199.232.170.217 443]
Err:7 https://deb.nodesource.com/node_18.x nodistro InRelease
502 Bad Gateway [IP: 143.204.15.127 443]
Err:4 https://repos.influxdata.com/debian buster InRelease
The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
Reading package lists...
E: The repository 'https://packages.grafana.com/oss/deb stable Release' no longer has a Release file.
E: Repository 'http://security.debian.org/debian-security buster/updates InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
E: Repository 'http://deb.debian.org/debian buster InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
E: Repository 'http://deb.debian.org/debian buster-updates InRelease' changed its 'Suite' value from 'oldstable-updates' to 'oldoldstable-updates'
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
+ echo 3
+ sudo apt install -o Dpkg::Options::=--force-confdef -y git
Building dependency tree...
Reading state information...
Suggested packages:
git-daemon-run | git-daemon-sysvinit git-doc git-el git-email git-gui gitk
gitweb git-cvs git-mediawiki git-svn
The following packages will be upgraded:
git
1 upgraded, 0 newly installed, 0 to remove and 292 not upgraded.
Need to get 5634 kB of archives.
After this operation, 150 kB of additional disk space will be used.
Err:1 http://security.debian.org/debian-security buster/updates/main amd64 git amd64 1:2.20.1-2+deb10u6
404 Not Found [IP: 199.232.170.132 80]
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/g/git/git_2.20.1-2+deb10u6_amd64.deb 404 Not Found [IP: 199.232.170.132 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
+ echo 4
+ sudo apt install -o Dpkg::Options::=--force-confdef -y libbz2-dev
libbz2-dev is already the newest version (1.0.6-9.2~deb10u2).
0 upgraded, 0 newly installed, 0 to remove and 293 not upgraded.
+ echo 5
+ sudo apt install -o Dpkg::Options::=--force-confdef -y libreadline-dev
The following additional packages will be installed:
libncurses-dev libncurses6 libncursesw6 libtinfo6
Suggested packages:
ncurses-doc readline-doc
libncurses-dev libreadline-dev
3 upgraded, 2 newly installed, 0 to remove and 290 not upgraded.
Need to get 892 kB/1025 kB of archives.
After this operation, 3029 kB of additional disk space will be used.
Err:1 http://security.debian.org/debian-security buster/updates/main amd64 libncurses6 amd64 6.1+20181013-2+deb10u3
Err:2 http://security.debian.org/debian-security buster/updates/main amd64 libtinfo6 amd64 6.1+20181013-2+deb10u3
Err:3 http://security.debian.org/debian-security buster/updates/main amd64 libncursesw6 amd64 6.1+20181013-2+deb10u3
Err:4 http://security.debian.org/debian-security buster/updates/main amd64 libncurses-dev amd64 6.1+20181013-2+deb10u3
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/n/ncurses/libncurses6_6.1+20181013-2+deb10u3_amd64.deb 404 Not Found [IP: 199.232.170.132 80]
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/n/ncurses/libtinfo6_6.1+20181013-2+deb10u3_amd64.deb 404 Not Found [IP: 199.232.170.132 80]
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/n/ncurses/libncursesw6_6.1+20181013-2+deb10u3_amd64.deb 404 Not Found [IP: 199.232.170.132 80]
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/n/ncurses/libncurses-dev_6.1+20181013-2+deb10u3_amd64.deb 404 Not Found [IP: 199.232.170.132 80]
+ echo 6
+ sudo apt install -o Dpkg::Options::=--force-confdef -y libsqlite3-dev
libsqlite3-dev is already the newest version (3.27.2-3+deb10u2).
+ echo 7
+ sudo apt install -o Dpkg::Options::=--force-confdef -y libncurses5-dev
Suggested packages:
ncurses-doc
libncurses-dev libncurses5-dev
Need to get 893 kB of archives.
After this operation, 2307 kB of additional disk space will be used.
Err:5 http://security.debian.org/debian-security buster/updates/main amd64 libncurses5-dev amd64 6.1+20181013-2+deb10u3
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/n/ncurses/libncurses5-dev_6.1+20181013-2+deb10u3_amd64.deb 404 Not Found [IP: 199.232.170.132 80]
+ echo 8
+ sudo apt install -o Dpkg::Options::=--force-confdef -y libncursesw5-dev
Suggested packages:
ncurses-doc
libncurses-dev libncursesw5-dev
Err:5 http://security.debian.org/debian-security buster/updates/main amd64 libncursesw5-dev amd64 6.1+20181013-2+deb10u3
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/n/ncurses/libncursesw5-dev_6.1+20181013-2+deb10u3_amd64.deb 404 Not Found [IP: 199.232.170.132 80]
+ echo 9
+ sudo apt install -o Dpkg::Options::=--force-confdef -y libffi-dev
libffi-dev is already the newest version (3.2.1-9).
+ echo 10
+ sudo apt install -o Dpkg::Options::=--force-confdef -y liblzma-dev
liblzma-dev is already the newest version (5.2.4-1+deb10u1).
+ echo 11
+ sudo chmod +x /var/www/html/core/class/../../plugins/mymodbus/ressources/post-install.sh
+ sudo /var/www/html/core/class/../../plugins/mymodbus/ressources/post-install.sh
* Nettoyage de l'ancienne version *
Wed May 15 10:22:44 CEST 2024
* Installation terminée *
+ echo 12
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end mymodbus
+ echo 13
+ rm /tmp/jeedom_install_in_progress_mymodbus
