bonsoir
j’ai passé la dernière MAJ de JeeZigbee (z2m) - stable en version 2.0.0. Depuis, le statut démon se met en arrêt.
log d’erreur:
> zigbee2mqtt@2.0.0 start
> node index.js
node:internal/modules/cjs/loader:1228
throw err;
Error: Cannot find module 'semver'
Require stack:
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js
at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
at Module._load (node:internal/modules/cjs/loader:1051:27)
at Module.require (node:internal/modules/cjs/loader:1311:19)
at require (node:internal/modules/helpers:179:18)
at Object.<anonymous> (/var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js:1:16)
at Module._compile (node:internal/modules/cjs/loader:1469:14)
at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
at Module.load (node:internal/modules/cjs/loader:1288:32)
at Module._load (node:internal/modules/cjs/loader:1104:12)
at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
code: 'MODULE_NOT_FOUND',
requireStack: [ '/var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js' ]
Node.js v20.18.1
Informations Jeedom
Core : 4.4.19 (master)
DNS Jeedom : non
Plugin : JeeZigbee
Version : 2024-12-17 01:01:46 (stable)
Statut Démon : Stoppé - (2025-01-04 21:25:26)
