Le demon ne démarre pas correctement
je trouvais qu’il faisait chaud chez moi et effectivement c’était pas réglé a la normale, j’ai donc fait une commande manuel mais rien ne bouge, je me rends alors sur jeedom et la le démon ne veut pas démarrer j’ai tout désinstaller et réinstaller mais c’est pareil
J’ai changé le port passé de 59959 jusqu’a 59970 à chaque fois j’ai la meme remarque
[2026-05-11 19:15:14] INFO  : Starting daemon (lib version 1.2.9) with log level: debug
[2026-05-11 19:15:14] DEBUG  : Writing PID 1042061 to /tmp/jeedom/MyTado/MyTado.pid
[2026-05-11 19:15:14] INFO  : Send async started with a cycle of 0.5s
[2026-05-11 19:15:15] INFO  : Send async cancelled
[2026-05-11 19:15:15] ERROR  : Fatal error: [Errno 98] error while attempting to bind on address ('127.0.0.1', 59969): address already in use(<class 'OSError'>) in /usr/local/lib/python3.9/dist-packages/jeedomdaemon/base_daemon.py on line 90
[2026-05-11 19:15:15] INFO  : Shutdown
[2026-05-11 19:15:15] DEBUG  : Removing PID file /tmp/jeedom/MyTado/MyTado.pid
[2026-05-11 19:15:15] DEBUG  : Exit 0
[2026-05-11 19:20:09] INFO  : Starting daemon (lib version 1.2.9) with log level: debug
[2026-05-11 19:20:09] DEBUG  : Writing PID 1045489 to /tmp/jeedom/MyTado/MyTado.pid
[2026-05-11 19:20:09] INFO  : Listening on 127.0.0.1:59974
[2026-05-11 19:20:09] INFO  : Send async started with a cycle of 0.5s
[2026-05-11 19:20:10] DEBUG  : Received new message on socket
[2026-05-11 19:20:10] DEBUG  : Close connection
[2026-05-11 19:20:10] DEBUG  : Message received from jeedom
[2026-05-11 19:20:10] INFO  : Configuration updated - sync_temperature_offset: False
[2026-05-11 19:20:10] INFO  : Transmitted revert_to_auto_on_next_schedule=False to 0 API clients
[2026-05-11 19:20:10] DEBUG  : Message for callback: {'MyTadoDaemonCmd': 'update_config', 'revert_to_auto_on_next_schedule': False, 'api_call_count': 0, 'succeeded': True}
[2026-05-11 19:20:10] DEBUG  : Try sending to jeedom: {'MyTadoDaemonCmd': 'update_config', 'revert_to_auto_on_next_schedule': False, 'api_call_count': 0, 'succeeded': True}
J’ai finalement réussi en mettant le demon 59974 mais aucun equipement n’apparait mis a part « maison »
[2026-05-11 20:30:09] DEBUG  : Received new message on socket
[2026-05-11 20:30:09] DEBUG  : Close connection
[2026-05-11 20:30:09] DEBUG  : Message received from jeedom
[2026-05-11 20:30:09] DEBUG  : Synchronization parameters - weather: True, mobile_devices: False
[2026-05-11 20:30:09] ERROR  : Error while executing the command 'MyTadoDaemonCmd.REFRESH_HOME_DATA': No home connected (MyTadod.py (241) -> MyTadod.py (241))
[2026-05-11 20:30:09] DEBUG  : Message for callback: {'MyTadoDaemonCmd': 'refresh_home_data', 'succeeded': False, 'message': 'No home connected'}
[2026-05-11 20:30:09] DEBUG  : Try sending to jeedom: {'MyTadoDaemonCmd': 'refresh_home_data', 'succeeded': False, 'message': 'No home connected'}
[2026-05-11 20:30:37] DEBUG  : Received new message on socket
[2026-05-11 20:30:37] DEBUG  : Close connection
[2026-05-11 20:30:37] DEBUG  : Message received from jeedom
[2026-05-11 20:30:37] DEBUG  : Message for callback: {'MyTadoDaemonCmd': 'synchronize', 'homes': [], 'api_call_count': 0, 'succeeded': True}
[2026-05-11 20:30:37] DEBUG  : Try sending to jeedom: {'MyTadoDaemonCmd': 'synchronize', 'homes': [], 'api_call_count': 0, 'succeeded': True}
finalement résolu c’est revenu tout seul au bout de quelques heures
