depuis le 19/3, le plugin teleinfo ne trouve plus le modem serie.
j’ai tenté de reinstaller le plugin, les dependances, des apt-get update et upgrade mais sans succès.
Je suis sur une VM freebox Delta.
Santé Jeedom :
Version Jeedom : 4.3.23
Version OS : debian 10.13
Version PHP : 7.3.31-1~deb10u5
Version OS: Linux Jeedom 5.10.0-0.deb10.16-cloud-arm64 #1 SMP Debian 5.10.127-2~bpo10+1 (2022-07-28) aarch64 GNU/Linux [10.13]
Version database : 10.3.39-MariaDB-0+deb10u2
Plugin Teleinfo :
Dépendances OK
Configuration démon OK
Statut démon NOK
Version plugin : 2024-03-14 07:40:33
Core Teleinfo 4.8.3
Diagnostic :
|Etape 1 :| Modem configuré : /dev/ttyS0| |---|---|
|Etape 2 :| Accès OK|
|Etape 3 :| OK|
|Etape 4 :| NOK|
|Etape 5 :| OK|
Log Téléinfo
[2024-03-27 15:25:57]ERROR : [TELEINFO_deamon_infoserial] le deamon port modem 1 n'est pas démarré
log Teleinfo_package
+ touch /tmp/jeedom_install_in_progress_teleinfo
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../plugins/teleinfo/ressources/post-install.sh
sudo: unable to resolve host Jeedom: Name or service not known
+ sudo /var/www/html/core/class/../../plugins/teleinfo/ressources/post-install.sh
Tue Mar 26 16:11:58 UTC 2024
* Installation des dépendances *
Hit:1 http://deb.debian.org/debian buster InRelease
Hit:2 http://security.debian.org buster/updates InRelease
Hit:3 http://deb.debian.org/debian buster-updates InRelease
Hit:4 http://deb.debian.org/debian buster-backports InRelease
Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
Reading package lists...
Building dependency tree...
Reading state information...
Calculating upgrade...
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Tue Mar 26 16:12:12 UTC 2024
libxml2-dev is already the newest version (2.9.4+dfsg1-7+deb10u6).
libxslt1-dev is already the newest version (1.1.32-2.2~deb10u2).
python3 is already the newest version (3.7.3-1).
Tue Mar 26 16:12:23 UTC 2024
python3-pip is already the newest version (18.1-5).
python3-dev is already the newest version (3.7.3-1).
python3-venv is already the newest version (3.7.3-1).
Tue Mar 26 16:12:25 UTC 2024
Tue Mar 26 16:12:32 UTC 2024
Requirement already satisfied: pip in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.7/site-packages (24.0)
Requirement already satisfied: wheel in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.7/site-packages (0.42.0)
Requirement already satisfied: pylibftdi in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.7/site-packages (0.21.0)
Requirement already satisfied: six in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.7/site-packages (1.16.0)
Requirement already satisfied: pyserial in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.7/site-packages (3.5)
Requirement already satisfied: setuptools in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.7/site-packages (40.8.0)
Requirement already satisfied: requests in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.7/site-packages (2.31.0)
Requirement already satisfied: charset-normalizer<4,>=2 in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.7/site-packages (from requests) (3.3.2)
Requirement already satisfied: idna<4,>=2.5 in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.7/site-packages (from requests) (3.6)
Requirement already satisfied: urllib3<3,>=1.21.1 in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.7/site-packages (from requests) (2.0.7)
Requirement already satisfied: certifi>=2017.4.17 in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.7/site-packages (from requests) (2024.2.2)
Requirement already satisfied: pyudev in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.7/site-packages (0.24.1)
Requirement already satisfied: paho-mqtt==1.6.1 in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.7/site-packages (1.6.1)
Tue Mar 26 16:12:54 UTC 2024
* Installation des dépendances OK *
+ echo 3
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end teleinfo
+ echo 4
+ rm /tmp/jeedom_install_in_progress_teleinfo
quelqu’un peut me guider ?
