Le deamon ne démarre plus suite Maj
Tu m’as demandé pourquoi j’utilise les DNS Jeedom
[2025-09-10 16:36:37] DEBUG  : Starting new HTTP connection (1): 127.0.0.1:80
[2025-09-10 16:36:37] DEBUG  : http://127.0.0.1:80 "GET /plugins/ttscast/core/php/jeettscast.php?apikey=wuumCGyT4nLqfz5DjMKTfeD65fWlFC1OxTppi4xv22huzfTNtRmz7GNr1JKoBapZ HTTP/1.1" 403 199
[2025-09-10 16:36:37] ERROR  : [DAEMON][COM][TEST] Callback result as a unknown error :: 'Response' object has no attribute 'status'. Please check your network configuration page
[2025-09-10 16:36:37] ERROR  : [DAEMON][JEEDOMCOM] sendToJeedom :: Network communication ERROR (Daemon to Jeedom)
[2025-09-10 16:36:37] INFO  : [DAEMON] Shutdown :: Begin...
[2025-09-10 16:36:37] INFO  : [DAEMON] Shutdown :: Devices Disconnect :: Begin...
[2025-09-10 16:36:37] INFO  : [DAEMON] Shutdown :: Devices Disconnect :: OK
[2025-09-10 16:36:37] INFO  : [DAEMON] Shutdown :: Browser Stop :: OK
[2025-09-10 16:36:37] INFO  : [DAEMON] Shutdown :: ZeroConf Close :: OK
[2025-09-10 16:36:37] DEBUG  : [DAEMON] Removing PID file /tmp/jeedom/ttscast/deamon.pid
[2025-09-10 16:36:37] INFO  : [DAEMON] Shutdown :: Exit 0
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] Start Daemon
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] Plugin Version: 1.6.5
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] Log level: debug
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] Socket port: 55111
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] Socket host: localhost
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] CycleFactor: 1.0
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] CycleMain: 2.0
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] CycleComm: 0.5
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] CycleEvent: 0.5
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] PID file: /tmp/jeedom/ttscast/deamon.pid
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] ApiKey: ***
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] ApiTTSKey: ***
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] Google Cloud ApiKey: my-project-1504517455208-6bbe7f4e97f4.json
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] VoiceRSS ApiKey: ***
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] TTS Disable Cache: False
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] App Disable Ding: False
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] App Convert Single Quote: False
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] AI Enabled: False
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] AI Auth Mode: noMode
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] AI Project ID: noProjectID
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] AI ApiKey: N/A
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] AI Model: noModel
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] AI Use Custom System Prompt: False
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] AI Custom System Prompt:
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] AI Default Tone: Enthousiaste et humoristique
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] Cmd Wait Timeout: 60
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] CallBack: http://127.0.0.1:80/plugins/ttscast/core/php/jeettscast.php
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] Jeedom WebSrvCache: http:///plugins/ttscast/data/cache/
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] Jeedom WebSrvMedia: http:///plugins/ttscast/data/media/
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] Jeedom WebSrvImages: http:///plugins/ttscast/data/images/
[2025-09-10 16:40:09] INFO  : [DAEMON][MAIN] Jeedom WebSrvJeeTTS: http:///core/api/
[2025-09-10 16:40:09] DEBUG  : [DAEMON][UTILS] Writing PID 3768121 to /tmp/jeedom/ttscast/deamon.pid
[2025-09-10 16:40:09] INFO  : [DAEMON][COM] Start thread changes async
[2025-09-10 16:40:09] INFO  : [DAEMON][COM] Init request module v2.32.5
[2025-09-10 16:40:09] DEBUG  : Starting new HTTP connection (1): 127.0.0.1:80
[2025-09-10 16:40:09] DEBUG  : http://127.0.0.1:80 "GET /plugins/ttscast/core/php/jeettscast.php?apikey=wuumCGyT4nLqfz5DjMKTfeD65fWlFC1OxTppi4xv22huzfTNtRmz7GNr1JKoBapZ HTTP/1.1" 403 199
[2025-09-10 16:40:09] ERROR  : [DAEMON][COM][TEST] Callback result as a unknown error :: 'Response' object has no attribute 'status'. Please check your network configuration page
[2025-09-10 16:40:09] ERROR  : [DAEMON][JEEDOMCOM] sendToJeedom :: Network communication ERROR (Daemon to Jeedom)
[2025-09-10 16:40:09] INFO  : [DAEMON] Shutdown :: Begin...
[2025-09-10 16:40:09] INFO  : [DAEMON] Shutdown :: Devices Disconnect :: Begin...
[2025-09-10 16:40:09] INFO  : [DAEMON] Shutdown :: Devices Disconnect :: OK
[2025-09-10 16:40:09] INFO  : [DAEMON] Shutdown :: Browser Stop :: OK
[2025-09-10 16:40:09] INFO  : [DAEMON] Shutdown :: ZeroConf Close :: OK
[2025-09-10 16:40:09] DEBUG  : [DAEMON] Removing PID file /tmp/jeedom/ttscast/deamon.pid
[2025-09-10 16:40:09] INFO  : [DAEMON] Shutdown :: Exit 0
Déjà fait, c’est ce qui est préconisé dans la doc.
Non
Est ce que c’est normal çà ?
pyv
Re,
On voit via cette log, que la requête du démon vers jeedom est refusée (le « 403 »), ce qui confirme un soucis de communication réseau (au niveau configuration) lorsque le démon essaie de communiquer avec jeedom.
Regarde dans la configuration de ton jeedom, au niveau des API, si elles sont bien actives et accessibles (notamment pour le plugin ttscast)
Sinon, tu n’as pas modifié la conf de ton serveur apache (httpd.conf) pour ce jeedom ? (en mettant des restrictions sur l’accès à l’adresse 127.0.0.1) ? ou bien des directives pour modifier (restreindre ou étendre) l’accès à certains répertoires de jeedom et/ou de certains plugins) ?
Sinon, Concernant ton système, peux tu lancer en SSH, un sudo apt update pour voir le nombre de mises à jour en attente ?
oui car tu es en Debian 12, donc pas besoin de PyEnv avec cette version de Debian, le Python du système est assez récent pour être utilisé par le plugin.
TiTidom.
pi
Je mets à jour ?
Non, il n’a pas demandé cela !
Il a demandé pourquoi tu avais coché « Utiliser l’adresse externe » alors que ce n’est pas nécessaire avec les dns jeedom.
Ok désolé pour mon ignorance.
Quoi qu’il en soit c’est toujours pareil.
J’ai fait les MAJ du système, ce n’est pas mieux, le deamon ne démarre pas
Si tu veux.
