Au démarrage de Jeedom, nous avons été plusieurs à remarquer que le daemon passait en OK après un certains temps. Dans son log on visualise bien 2 étapes:
ETAPE 1 :
> zigbee2mqtt@1.36.1 start
> node index.js
Zigbee2MQTT:error 2024-04-15 01:36:05: Failed to load external converter file '/var/www/html/plugins/z2m/core/class/../config/converters/Danfoss/icon.js' (Cannot find module 'zigbee-herdsman-converters/lib/extend'
Require stack:
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/dist/util/utils.js
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/dist/util/settings.js
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js)
Zigbee2MQTT:error 2024-04-15 01:36:05: Probably there is a syntax error in the file or the external converter is not compatible with the current Zigbee2MQTT version
Zigbee2MQTT:error 2024-04-15 01:36:05: Note that external converters are not meant for long term usage, it's meant for local testing after which a pull request should be created to add out-of-the-box support for the device
Zigbee2MQTT:error 2024-04-15 01:36:17: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-04-15 01:36:17: Failed to start zigbee
Zigbee2MQTT:error 2024-04-15 01:36:17: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-04-15 01:36:17: Exiting...
Zigbee2MQTT:error 2024-04-15 01:36:18: Error: Failure send getNetworkParameters:{"type":"Buffer","data":[24,0,1,40,0]}
at /var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:664:23
at Queue.execute (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20)
at Driver.needsToBeInitialised (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:288:27)
at Driver.startup (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:224:13)
at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
at Zigbee.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/zigbee.ts:62:27)
at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/controller.ts:109:27)
at start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js:107:5)
ETAPE 2 :
> node index.js
Zigbee2MQTT:error 2024-04-15 01:40:04: Failed to load external converter file '/var/www/html/plugins/z2m/core/class/../config/converters/Danfoss/icon.js' (Cannot find module 'zigbee-herdsman-converters/lib/extend'
Require stack:
Zigbee2MQTT:error 2024-04-15 01:40:04: Probably there is a syntax error in the file or the external converter is not compatible with the current Zigbee2MQTT version
Zigbee2MQTT:error 2024-04-15 01:40:04: Note that external converters are not meant for long term usage, it's meant for local testing after which a pull request should be created to add out-of-the-box support for the device
Si je comprend bien au premier lancement cela échoue. (appeler ETAPE1)
La première ligne en erreur signale Danfoss pourquoi ?
La 2 ème et 3ème ligne en erreur : problème de compatibilité de version + un pull request à créer ?
De la 4 à 9 erreurs : le daemon échoue à démarrer.
2 à 3 minutes après le daemon est relancé , on passe à l’ETAPE 2:
1ère, 2ème, 3ème ligne en erreur : Idem ETAPE1
Puis plus d’erreurs :Le daemon est OK, les équipements remontent bien sur Jeedom.
Donc serait il possible :
1- Serait il possible que le daemon passe en OK au premier lancement
Remarque : Des personnes ne voyant pas le daemon passer en OK vont relancer le daemon ou les dépendances alors que le daemon est en train de s’initialiser. Un message « patienter » pourrait convenir par exemple.
2- Lorsque le daemon est en ETAPE 2, il passe en OK. Par contre 3 messages d’erreurs sont affichés, ce qui est troublant, est t’il possible de ne pas les afficher.
3- Est 'il possible dans le journal d’afficher Daemon active (running) pour confirmer.
Ce n’est pas une critique mais une demande d’amélioration si possible.
Peut être que ma configuration génère ces messages et l’échec systématique au premier lancement.
Config.: 4.4.3
- VM sur Proxmox
- Page santé tout en vert
- Broker mqtt en local
