très intéressant ce plugin, je viens de l’installer et malheureusement le démon ne se lance pas …
Error: importing module jeedom.jeedom
j’ai trouvé ce genre d’erreur dans d’autres plugins et on y parle de dépendances (pip3 par exemple) non remplies. Pourtant si je relance les dépendances j’ai la trace suivante :
* Launch install of dependencies *
Tue Nov 30 15:05:13 CET 2021
Hit:1 http://security.debian.org/debian-security buster/updates InRelease
Hit:2 http://deb.debian.org/debian buster InRelease
Hit:3 http://deb.debian.org/debian buster-updates InRelease
Hit:4 https://deb.nodesource.com/node_14.x buster InRelease
Reading package lists...
Install modules using apt-get
Building dependency tree...
Reading state information...
python3-bs4 is already the newest version (4.7.1-1).
python3-pip is already the newest version (18.1-5).
python3 is already the newest version (3.7.3-1).
python3-requests is already the newest version (2.21.0-1).
python3-voluptuous is already the newest version (0.11.1-1).
0 upgraded, 0 newly installed, 0 to remove and 181 not upgraded.
Install the required python libraries
Requirement already satisfied: aiohttp in /usr/local/lib/python3.7/dist-packages (3.8.1)
Requirement already satisfied: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (5.2.0)
Requirement already satisfied: frozenlist>=1.1.1 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (1.2.0)
Requirement already satisfied: asynctest==0.13.0; python_version < "3.8" in /usr/local/lib/python3.7/dist-packages (from aiohttp) (0.13.0)
Requirement already satisfied: async-timeout<5.0,>=4.0.0a3 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (4.0.1)
Requirement already satisfied: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (1.7.2)
Requirement already satisfied: charset-normalizer<3.0,>=2.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (2.0.8)
Requirement already satisfied: typing-extensions>=3.7.4; python_version < "3.8" in /usr/local/lib/python3.7/dist-packages (from aiohttp) (4.0.0)
Requirement already satisfied: aiosignal>=1.1.2 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (1.2.0)
Requirement already satisfied: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (21.2.0)
Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp) (2.6)
Tue Nov 30 15:05:16 CET 2021
* Install ended *
Tout semble ok, j’ai testé sur deux jeedom dont une V4.1.27 et j’ai la même erreur.
J’ai loupé quelque chose
